2nd Gen Wiring Grill Lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jtorre972, Jan 26, 2021.
  1. Jan 26, 2021 at 6:18 PM
    jtorre972
    jtorre972 [OP] Member
    Jorge
    2013 Toyota Tacoma
    I recently bought a TRD Pro grill for my 2013 Toyota Tacoma. The kit came with the grill, LED lights, the wiring harness, and a fuse tap. I am pretty new to wiring so I am not sure what fuse do I have to replace with the fuse tap? I have seen some people use the interior fuses and others use the exterior fuse box. What are the differences? Any help is appreciated it thanks.
  2. Jan 26, 2021 at 6:24 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Depends when you want them on (all the time, with tail lights, with headlights, or independently switched).
  3. Jan 26, 2021 at 6:29 PM
    jtorre972
    Jorge
    2013 Toyota Tacoma
    I wanted either all the time or with the headlights. I not too familiar with wiring so if I could know the process for either those two options then I can get and idea of what I have to do.
  4. Jan 26, 2021 at 6:36 PM
    BeefedTacos
    BeefedTacos Well-Known Member
    Brian
    North Carolina
    2015 tacoma dcsb SR5 4x4
    None so far
    I t-tapped into my side markers
  5. Jan 26, 2021 at 6:42 PM
    jtorre972
    Jorge
    2013 Toyota Tacoma
    Is there a way where I don't have to spice into an existing wires ? I was hoping to use the fuse tap and connect it to a certain fuse, I am just confused which one I can use.
  6. Jan 26, 2021 at 7:04 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    If you have the towing package you can use the Towing Tail fuse otherwise you would have to go to the interior fuse box to tap the Tail fuse.
    TruKnight likes this.
  7. Jan 26, 2021 at 7:14 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Use an add a fuse and tap into any one of the fuses in the interior panel. No splicing or anything. That way, if the truck is on then the lights are always on.
