2nd gen with icon stage 2 lift questions
Discussion in 'Suspension' started by 93yotasr5, Oct 8, 2019.
  1. Oct 8, 2019 at 11:11 PM
    93yotasr5
    93yotasr5 [OP] Well-Known Member
    Sacramento
    Those of you who installed the icon coil over lifts on your second gens, I have a question for you.
    What are you getting as far as droop goes?
    On the factory setting I was at:
    Drivers side: 21” center hub to fender on the ground and 24.5” droop.
    Passenger side:23” center hub to fender on the ground 25.5” droop.
    Has anyone been able to gain more of the lift from the icons and maintaining at least a 2” droop difference?
    I was thinking of running a 1/4” spacer on the drivers side and making adjustments accordingly to be at approx 22-22.5” height and have the 24.5-25.5” droop.
    Does this sound right or is something messed up on my end ?
