2nd Generation (2005+) Toyota Tacoma 5-Lug Lowering Information
Discussion in 'Street Trucks' started by Kelson, May 6, 2012.
  1. May 6, 2012 at 11:51 AM
    Kelson
    Kelson [OP] Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    How To: Lower Your 2nd Generation (2005+) Toyota Tacoma 5-Lug
    Here I’m going to list parts available to drop your truck. Some parts have advantages and disadvantages over others, and some of these may be matters of opinion; so therefore I have chosen not to include mine in the original post. Please, if you are looking to drop your truck, use this as a guide but research a little on your own about other member’s reviews as well as my own about these products. I will be happy to answer your questions in the subsequent posts about my opinion if you so wish to. And remember, I am in no way responsible for what you do to your truck. Kden.
    Front:
    Things to Remember:
    1. When upping the spring rate, it would be wise to upgrade the front struts. The OEM Tokicos tend to not handle a stiff spring very well, and will wear out very fast. Currently, to my knowledge, the only suitable replacement are OEM Bilstien shocks designed for the XRunner. All other aftermarket front strut replacements are for a lifted or stock application.
    2. 6 Lug trucks (4x4 & PreRunners) have a completely different front suspension setup. Nothing to my knowledge is interchangeable.
    OEM XRunner Springs (Nominal Drop)
    Will fit and stiffen up the front end and improve handling.
    XII Drop Springs (1.25”-1.75”) http://www.xiiperformance.com/?page_id=1007
    These drop springs were designed for the XRunner in mind, but can be used with all 5 lug trucks. Very high spring rate; ride will be firmer. The drop also depends on the weight of your truck. (aka XRunners w/ the heavy V6 will get closer to 1.75” than a regular cab, with lighter I4 and less weight in general)
    SOS/Tundra Racing Spring Perch (1.5”) http://tundraracing.com/xrunnerdropkit.htm
    Lowers the perch on the strut, dropping the truck. Primarily used by XRunners, but should work on all 5 lug trucks. Same concept as a coilover sleeve, but non adjustable.
    C2C (or custom brand) Spindle Spacer
    Metal spacer and extended bolt between the balljoint and spindle.
    DJM Upper and Lower Control Arms (3”) http://djmsuspension.com/applications/toyota/2005-2011-toyota-tacoma/
    Replaces the upper and lower control arms with powdercoated aftermarket, greasable units with polyurethane bushings. Utilizes stock ball joints, which need to be pressed in, and are not included with the kit.
    johnneg123 likes this.
  2. May 6, 2012 at 11:51 AM
    Kelson
    Kelson
    Honolulu, Hawaii
    reserved
  3. May 6, 2012 at 11:52 AM
    Kelson
    Kelson
    Honolulu, Hawaii
    reserved too.
  4. Jun 2, 2012 at 9:15 AM
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
  5. Jun 5, 2012 at 3:26 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    will the tundra racing spring perch work with the djm arms?
  6. Sep 28, 2012 at 6:28 PM
    Headcase
    Headcase Active Member
    Mitchell
    Medina
    '10 Access Cab Manual-5 2.7L
    245 70 R 17's on Aluminum stuffed into the wheel wells
    Two questions for anyone...
    1. Does anyone have pictures of how the TundraRacing "Perch" is mounted?? :confused: I know it slides over the strut but I want to see where it lands and how the stock x-runner spring sits if you know what I mean...
    2. Who sells the
    C2C (or custom brand) Spindle Spacer ?? Anyone have pix??
    Thx:popcorn:
  7. Sep 29, 2012 at 5:16 AM
    07TacoRidah
    1. You need to have the XR shocks to do this. With the base model shocks you can't do this because the perch is fixed. with the XR shock, you can take off the perch and swap.
    2. I don't think it's in production anymore, but peep my lowering thread, I have the bolt size posted in there, all you would need is for someone to machine you the spacers (keep in mind that once you hit 1.75" you will be entering into the negative camber area).
  8. Sep 29, 2012 at 11:19 AM
    Headcase
    Mitchell
    Medina
    I appreciate the information. Thanks for your time.
    H
    :cool:
  9. Sep 29, 2012 at 11:56 AM
    07TacoRidah
    no worries :cool:
  10. Jun 12, 2013 at 8:43 PM
    4WheelSteel
    4WheelSteel Active Member
    Jaime
    Chico, California
    2005 Tacoma access cab base model 4cyl 5 lug
    Slim's HID 6000K, JVC double din stereo, 2 12" Kicker Comp, 3" rear blocks Future list: FatBob's strut spacer lift and AAL's, Series 51 pro comp 15x8, Dynomax super turbo muffler, ultra gauge, 31x10.5x15 General Grabbers
    Would you be able to get away with only using the DJM arms or do you have to use the XII Drop Springs and OEM Bilstien shocks?
  11. Jun 13, 2013 at 11:07 AM
    Brendo Ballz808
    Brendo Ballz808 Slammed or lifted.. ANYTHING IS BETTER THAN STOCK
    BRENDEN
    Oahu
    SNOFLAKE
    Check out my build:)
    You can run DJM by itself it was designed to just give a true 3" drop without changing ride quality or anything however upgrading to x runner billys and x runner stock could would help the truck handle better
    Just don't run the stiffer coil with stock struts it will kill it like mines are pretty much shot
  12. Oct 24, 2018 at 3:35 AM
    johnneg123
    johnneg123 New Member
    johnne
    2015 tacoma access cab
    none
    Thank u do u think this will work on my 2015 access cab??
  13. Oct 24, 2018 at 3:36 AM
    johnneg123
    johnne
    none
    I have a 2015 access cab looking to lower I it 2 or 3 inch front and 3 in back do u think this will work 4 me?
  14. Oct 25, 2018 at 7:36 AM
    pinktaco808
    pinktaco808 Hot Steppa
    We need pics of all setups
  15. Nov 4, 2018 at 8:54 AM
    07TacoRidah
    pinktaco808 likes this.
