2nd generation front & back shocks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jureal, Dec 5, 2019.
  1. Dec 5, 2019 at 2:24 PM
    jureal
    jureal [OP] Member
    2014 Tacoma 4x4
    See some take offs from a 2019 Trd Offroad. Will these fit my 2014 Tacoma 4x4 Base model? 4 cyl automatic. Will the weight difference be a problem?
  2. Dec 5, 2019 at 2:26 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Someone correct me if I’m wrong, but I’m pretty sure the V6 shocks are different from the 4 cylinder shocks
  3. Dec 5, 2019 at 2:28 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Pretty sure the only difference that matters is 5 lug or 6lug
    could be wrong tho.
  4. Dec 5, 2019 at 2:39 PM
    jureal
    jureal [OP] Member
    2014 Tacoma 4x4
    Mine is a six lug.
  5. Dec 5, 2019 at 2:40 PM
    jureal
    jureal [OP] Member
    2014 Tacoma 4x4
    Wondering if the ride would change.
  6. Dec 5, 2019 at 2:45 PM
    Oldbusparts
    Oldbusparts Well-Known Member
    SE Oklahoma
    2015 MGM Double Cab TRD Offroad
    I put shocks from a 2018 on my 2015, Ride is much better and you get a little lift in the front.
  7. Dec 5, 2019 at 2:46 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    I wanna say the front springs are stiffer on the 3rd gens by 50 pounds or so. They also ride an inch taller, so IDK if bottom out issues may be had.
  8. Dec 5, 2019 at 4:29 PM
    jureal
    jureal [OP] Member
    2014 Tacoma 4x4
    I am not sure why bottoming out would be an issue at all if the shocks are stiffer.
  9. Dec 7, 2019 at 8:44 AM
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
  10. Dec 7, 2019 at 8:47 AM
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    Do you happen to have an Access cab?
    I also posted my running boards I'm giving away.
  11. Dec 7, 2019 at 9:25 AM
    grant318is
    grant318is Well-Known Member
    Connor
    Lovettsville, VA
    07 Tundra RCSB
    Yes. You will have a bit stiffer ride and get about 1" of lift in the front.
    74f46KChvVL-bYvDo_CqYBTH-a8T4Lq5i-sBjXfa_36edcd7b52aca35fa40f88d9e77eb2b1921f29b7.jpg
