2nd generation new suspension
Discussion in 'General Tacoma Talk' started by Old dog's taco, May 16, 2024.
  1. May 16, 2024 at 8:48 AM
    Old dog's taco
    Old dog's taco [OP] Member
    Tony
    Oregon
    Mica 2dr base 4x4
    New interior, off road lights,wheels &tires , stereo smoked tail lights, tinted windows,fog lights off road shocks
    Installing 2in lift and rough country front struts and rear shocks today
  2. May 21, 2024 at 6:52 PM
    Old dog's taco
    Tony
    Oregon
    Mica 2dr base 4x4
    Installed new suspension today. Now I have a loud hum? Sounds like it is coming from the front. Any ideas?
  3. May 21, 2024 at 6:53 PM
    EMR
    EMR Well-Known Member
    So Cal.
    2012 Tx Pro
    tacoman45 and 303tacoma like this.
  4. May 21, 2024 at 6:59 PM
    Old dog's taco
    Tony
    Oregon
    Mica 2dr base 4x4
    Thanks for replying. Replaced both front wheel bearings in front. Still have a hum?
  5. May 21, 2024 at 7:12 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
  6. May 21, 2024 at 7:44 PM
    Old dog's taco
    Tony
    Oregon
    Mica 2dr base 4x4
    No. It hums until I stop.
  7. May 21, 2024 at 7:55 PM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    Did you pull your axles out & replace the inner needle bearings on the front diff? Or did you only replace the outer bearings behind the knuckle?
  8. May 21, 2024 at 8:05 PM
    Old dog's taco
    Tony
    Oregon
    Mica 2dr base 4x4
    Outer bearings behind the knuckle
  9. May 21, 2024 at 8:09 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    The needle bearing in the diff is a probably cause. Check 303Tacomas post above for troubleshooting.
  10. May 21, 2024 at 8:23 PM
    Old dog's taco
    Tony
    Oregon
    Mica 2dr base 4x4
    Just went for a test drive. The hum is in 2wd. Goes away when in 4wd.
  11. May 21, 2024 at 8:39 PM
    303tacoma
    Rebecca
    tacoman45 likes this.
  12. May 21, 2024 at 8:45 PM
    Old dog's taco
    Tony
    Oregon
    Mica 2dr base 4x4
    Oh man. That means I have to take it apart again. Do I need to do it right away or can I wait awhile. Thanks for your help.
  13. May 21, 2024 at 8:50 PM
    303tacoma
    Rebecca
    Id say you can wait a little while.
    I could be wrong though :rolleyes:
    I drove mine probably 2 weeks before i replaced the bushing.
  14. May 21, 2024 at 8:55 PM
    Old dog's taco
    Tony
    Oregon
    Mica 2dr base 4x4
    Thanks 303 will order the parts
    303tacoma likes this.
  15. May 22, 2024 at 7:25 AM
    Old dog's taco
    Tony
    Oregon
    Mica 2dr base 4x4
    I'm wondering if this hum is damaging or just annoying
  16. May 22, 2024 at 7:30 AM
    Clearwater Bill
    Billy
    Largo Florida
    It's the demise of the bearing.
    Thechief86 and 303tacoma like this.
  17. May 22, 2024 at 7:52 AM
    Old dog's taco
    Tony
    Oregon
    Mica 2dr base 4x4
  18. May 24, 2024 at 2:07 PM
    Old dog's taco
    Tony
    Oregon
    Mica 2dr base 4x4
    All good now. Thanks again for your help.
  19. May 30, 2024 at 12:09 PM
    Jonny_09_taco
    Jonny_09_taco Well-Known Member
    Jonathan
    2009 grey Tacoma off-road
    Prinsu roof rack Baja Ditch lights
    Yeah once I got my kings that happened untill I changed the needle bearing
    Thechief86 likes this.
  20. May 30, 2024 at 1:12 PM
    Old dog's taco
    Tony
    Oregon
    Mica 2dr base 4x4
    Yes, everything I have done made it better. Differential drop kit, fluid change. Still have a vibration. So thanks to 303 I ordered the ecgs bushings. Haven't had time to install yet. I'm sure it will be the cure.
