2nd Generation preformance running 33" tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ermine, Oct 17, 2011.
  1. Oct 17, 2011 at 11:52 PM
    Ermine
    Ermine [OP] Well-Known Member
    Colorado
    V6 Tacoma
    3 inch OME Lift
    I have a 2011 DB Cab. V6 Auto. I have a 3 inch lift and was thinking about putting 255/85/r16 (33x10) tires on it. I have heard from some guys that I would need to regear as the bigger tire will put stress on the driveshaft. Also how much mpg would I loose. Not really worried about mpg but also dont want it to be a hog.
    Looking for more opinions. I could go with a smaller tire, but like the idea of the taller tire.
    Thanks
  2. Oct 18, 2011 at 12:24 AM
    jayridinfast
    jayridinfast Active Member
    minot nd
    06 taco eccess cab 4X4 v6..loaded
    20 in redlines wit 33 in mud tarrians<unichip chip>magnaflow exhuast>trd cold air>airraid throttle body spacer>bilstien shocks>billiet grill>SHORT THROW SHIFTER>skyjacker rear leafs>apline navigation wit jl w6
    i actually found better fuel milage on the highway with my 6sp but the driveshaft did give after to many hard days on her but 31's probaly woulda still broke it just not as fast.33's are fine but in four high its hard to keep the tires spining really fast throught thich mud or snow!
  3. Oct 18, 2011 at 10:38 AM
    Ermine
    Colorado
    V6 Tacoma
    3 inch OME Lift
    ok thanks that sounds good. Sounds like I won't lose too much in performance with the 255/85/r16. So I think I will go with that. I don't beat the truck up too much off road so alot of driving will be on the highway. I just like the look of tall tires.
  4. Oct 18, 2011 at 10:40 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    It'll ride no problem. You'll lose an MPG or two from the weight, but the 1GR can spin those babies just fine.
    I get 19mpg with my 285s which'll be heavier than your 255's. And that's with an ARB and a 10,000lb winch on.
  5. Oct 18, 2011 at 5:20 PM
    sicripp83
    sicripp83 Well-Known Member
    wboro
    sic
    no to hijack this thread OP but is their less trimming required for the 255 vs the 285 ??
  6. Oct 18, 2011 at 6:37 PM
    Ermine
    Colorado
    V6 Tacoma
    3 inch OME Lift
    I am guessing there is less trimming because the 255's are skinnier. Thats why I was going with them
