2nd generation Re-Gearing
Discussion in '5 Lug' started by alexmxman185, Apr 19, 2011.
  1. Apr 19, 2011 at 12:31 PM
    alexmxman185
    alexmxman185 [OP] Keepin' it dirty in Texas
    Alex
    Waco, Texas
    08 toyota tacoma 2.7 4 cly 5 lug
    Black grille guard with mounted kc road lights, 31x9.5x15 AT on stock rims. My future mod list: new white front bumper, Fat Bobs 2.75 spacer lift with rear AAL, american racing Flat Black Rims, 32x11.5x15 BFG A/T, satoshi grille with road lights mounted behind it, 8000k HID for all lights, 1'' Body Lift, new window tint, blacked out headlights and taillights, custom hood scoop, weather tech floor liners, LED dash cluster replacement, Front bilstein shocks, 40 series flowmaster, paint all my badges black.
    so basically i want to know if 3.73 will fit on my 5 lugger with no modifications.
    Will 3.73's fit without having to mod anything? Id like to just install and it be done with. Any and all info helps. thanks!
  2. Apr 19, 2011 at 12:47 PM
    alexmxman185
    Alex
    Waco, Texas
    yea just the 3.73 gear and pinion
  3. Apr 19, 2011 at 12:49 PM
    2kool4school
    2kool4school Well-Known Member
    Beau
    Honolulu, HI
    '12 JKU Sport
    the real question is
    Why do you want to change your gears? and What is the stock ratio?
  4. Apr 19, 2011 at 12:57 PM
    alexmxman185
    Alex
    Waco, Texas
    cause when i got bigger tires 1st runs way to high and 5 way to low and alot of five luggers re=gear after getting bigger tires for a better ride
  5. Apr 19, 2011 at 5:51 PM
    2kool4school
    Beau
    Honolulu, HI
    '12 JKU Sport
    3.73 should help but it also depends on how much bigger your tires are. I would find someone that has the same size tires and 3.73s that will let you drive their truck to see how you like it. You might just want to goto 4.10 thats just my thought, i would be pissed and a waste of money if you went to 3.73 and it didnt give you what you wanted. OR goto a junk yard and score a whole 3rd member for cheap. Remember you will have to buy the gears and the master install kit. ~400 plus shipping, plus install time. OR have Chase do it for you and just slap it in when it shows up (yes i know the guy).
  6. Apr 19, 2011 at 5:56 PM
    2kool4school
    Beau
    Honolulu, HI
    '12 JKU Sport
    totoya.com says 4cy has 3.31
  7. Apr 19, 2011 at 6:32 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
  8. Apr 19, 2011 at 7:16 PM
    alexmxman185
    Alex
    Waco, Texas
    yea im not sure the number but were under 3.73 for sure. id do 4.10's but getting to look at the cost and time, i think id rather just deal with what i have, what else would it do besides give me a little smoother ride?
  9. Apr 19, 2011 at 7:18 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    5 lugs have 3.31s
  10. Apr 19, 2011 at 7:19 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    4.10 come with the 4 cylinder manual iirc and the automatic is different. I do not know if the gearing changes between 5 and 6 lug or not
  11. Apr 19, 2011 at 7:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The 5 lug uses a 7.5" diff ring gear. So the 3.73 from a 6 lug wont fit.
  12. Apr 19, 2011 at 7:21 PM
    alexmxman185
    Alex
    Waco, Texas
    5 lugs DO NOT have the 4.10's. unless its a 1st gen.
  13. Apr 19, 2011 at 7:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Wrong. Doesnt apply to the 5 luggers.
