2nd generation "speed sensor"??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Clintmeister, Jul 27, 2024.
  1. Jul 27, 2024 at 9:00 AM
    Clintmeister
    Clintmeister [OP] New Member
    Clint
    tacoma
    none
    I am new here had my 2012 2.7L 5 speed for all its life and had no problems till now. All gauges are not working now they were just bouncing around for about 2 weeks. It seems there is SH$T for info on the 2nd generation. I pulled the truck up on the service ramps and went all over the trans (5 speed manual) and have not found the speed sensor. I have a repair manual (shit Hastings) and it don't say anything about speed sensor in there or have a picture. I need a factory repair manual download, and yes can't find on either. I tried to download the parts manual off this sight and it would not let me saying the file is corrupted. Oreillys ran a scan that said vehicle speed sensor "A", code P0500. Looking online I am very disappointed to see 6 different versions of a "vehicle speed sensor". I don't seem to have a good place to get "correct info", and I am hoping that I can get it here. THX in advance Clint
  2. Jul 27, 2024 at 9:04 AM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
  3. Jul 27, 2024 at 10:08 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Check passenger side of transfer case for your speed sensor. Thats why hasting manual lot great they are very generic. At 2012, it might have been relocated to the right rear ABS sensor from the tcase I don’t remember the exact year.
  4. Jul 27, 2024 at 10:23 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Tons of info here if you know where to look.
    See the post below for information on the vehicle speed circuit (scroll down to P0500)
    https://www.tacomaworld.com/threads/2nd-gen-information-diagnostics.784008/#post-28042157
    If all the gauges are going stupid on the Combination Meter (Instrument Cluster) though you have another issue and you can ignore the P0500 for now because if the Meter isn't working properly it likely isn't outputting a vehicle speed signal to the PCM either (thus the P0500).
    I think you should check power and grounds to the Meter as a first step.
  5. Jul 27, 2024 at 12:56 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    You came to the right place, TW forums will have the info & assist you need to get sorted.
    Dm93 likes this.
  6. Jul 28, 2024 at 9:00 AM
    Clintmeister
    Clint
    tacoma
    none
    Ok I still need to know WHERE the speed sensor is located. I also need a download of the factory 2012 tacoma 4cyl factory manual AND parts manual. The truck is 2X4.
  7. Jul 28, 2024 at 9:35 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Did you not read my post?
    There is no Vehicle Speed Sensor on a 2012 Tacoma.
    Vehicle speed is sent from the rear wheel speed sensors to the Skid Control ECU (ABS Module) to the Combination Meter (Instrument Cluster) which sends it to all the other modules.
    You said the whole cluster is going wonky therefore the easiest and most logical first step in diagnosing this issue would be checking powers and grounds to the cluster.
    But if you insist on looking for yourself https://partsouq.com/ for parts diagrams by VIN and https://techinfo.toyota.com for factory service info.
  8. Aug 13, 2024 at 2:50 PM
    Clintmeister
    Clint
    tacoma
    none
    I put the truck in the shop. I will work out a plan to pay it out. I will post info as it comes.
  9. Aug 25, 2024 at 12:55 PM
    Clintmeister
    Clint
    tacoma
    none
    Ok to finish this post. Truck got out of the shop with a BIG bill. The dash was out because of fuses under the hood out. Why, what caused, nobody knows. The AC compressor internally grenaded and that is where all the cost came from. One thing thats strange is in North America (last month, july) there is no condensor for a 2012 tacoma 4cyl 5sp base cab to be found,(Yes you heard right). I found a repair manual to download but yet to find a "parts manual" to download. That would help on finding the right parts (since my truck has unfindable parts).
