2nd Generation Tacoma 4WD 4" Suspension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by avanasch, Mar 29, 2008.
  1. Mar 29, 2008 at 7:10 PM
    avanasch
    avanasch [OP] Active Member
    Okay,
    Has anyone released a true 4" suspension lift for the 2nd gen. tacoma? I can't find one anywhere. I don't want to do a body lift or a 6" susp. lift. I also don't want spacers that change my CV axle angles. Any help would be much appreciated. Otherwise, it looks like I will have to make my own.
    Thanks in advance :)
    Andrew
  2. Mar 29, 2008 at 7:57 PM
    Dcrooks84
    Dcrooks84 Sir Anal Loin of Beef
    Ohio
    05 double cab SR5 Pkg #8 lng bd 4X4
    Removed secondary air filter, Fog light anytime, Map light mod, Scan Gauge II, Polished Stainless Steel Westin E-Series Bull Bar, Black GrilleCraft Grille, Borla CatBack Exhaust
    Have not seen any 4". If you are set on a 4 you might have to go with a 3" lift and then a little body.
  3. Mar 29, 2008 at 8:01 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Or 3" with a taller top spacer and block in the rear? Something along those lines.
  4. Mar 30, 2008 at 5:13 AM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    Like was said, to get to 4 inches, would require a 3" AAL rear with a 1" block, In the front, maybe billy 5100" set at 2.5" with a toytec leveling spacer which I believe is 1.5" (though I am not really sure if this can be done together)
    That said, a diff drop is reccomended by Toyota as well as the lift companies if you lift over 2 inches, so regardless, you are going to need a front diff drop, or to be prepared to be replacing CV joints on a regular basis.
    Regards,
  5. Mar 30, 2008 at 7:07 AM
    rick
    rick `
    you CANNOT use spacers with the 5100's on top notch.
    search "allied spindles" for a 4" lift.
  6. Mar 30, 2008 at 11:04 AM
    CrashTest
    CrashTest Member
    2008 Access Cab V6 MT TRD Offroad
    The spindles only work for 2WD vehicles.
  7. Mar 30, 2008 at 11:25 AM
    Big Guns
    Big Guns Well-Known Member
    Temecula, CA
    07 PreRunner SR5 4.0L Indigo Blue
    Aero Turbine 2525 exhaust, Black Headlight Mod, DO Rock Sliders
    I think the allied spindles are the only option at getting 4" like rick said. On the 4x4 models wouldn't going above 3" be damaging for the joints and what not. Unless some company is planning on running some 4" drop bracket kit, there prob won't be many options aside from body lift.
    This company claims 4" of lift, but they are running fox coilovers and some UCA's. Anad at almost $4000 it seems like a waste of money too. http://pure-performance.biz/
  8. Mar 30, 2008 at 12:14 PM
    rick
    rick `
    ty for correcting me. i forgot to add that
  9. Apr 2, 2008 at 7:34 PM
    smurf83
    smurf83 New Member
    PA
    2006 Double Cab Long Bed 4x4 TRD Sport
    I found one from this website. its pretty pricey and you'd be better off getting a 6" fabtech for the dough
    www.rockkrawler.com
  10. Apr 2, 2008 at 11:49 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    this is exactly the one i was gonna mention. they even have a link/coilover kit to replace the rear leafs. pretty awesome if you ask me- no more axle wrap and an awesome ride i'd expect. if their kit is run with glassworks fenders, then 35's will even fit!
    they actually call their truck line "pure performance" http://www.pure-performance.biz/
  11. Apr 3, 2008 at 11:54 AM
    Big Guns
    Temecula, CA
    I linked that 3 posts ago lol. But yeah, it is on the expensive side, and i don't know if i would trust their four link. Looks iffy. I would rather spend the 5G's on long travel or save money and buy the Fox's and some Deavers seperate. Save quite a few dollars.
  12. Apr 3, 2008 at 1:48 PM
    smurf83
    smurf83 New Member
    PA
    my bad big guns. i didnt click on the link until now and it looks like the exact same website just different url's. oops! damn newb's haha:frusty:
  13. Apr 3, 2008 at 1:49 PM
    Big Guns
    Temecula, CA
    Ah its chill. I skip posts sometimes and repost info. No worries.
  14. Apr 3, 2008 at 5:48 PM
    RelentlessFab
    Eric
    Sparks, NV
    me too. i didnt see the link down on the bottom.:frusty:
