2nd Generation Tacoma Navigation wont reset to current location!
Discussion in 'Audio & Video' started by Tacomaawayoflife, Apr 26, 2019.
  1. Apr 26, 2019 at 1:35 PM
    Tacomaawayoflife
    Tacomaawayoflife [OP] Well-Known Member
    Roy
    Eugene, Oregon 97405
    2013 Tacoma 4x4 Limited Crew Cab
    Stock
    No change after desk
    Letting personal data
  2. Apr 26, 2019 at 1:36 PM
    Tacomaawayoflife
    Roy
    Stock
    No change after deleting personal data
  3. Apr 26, 2019 at 1:39 PM
    Tacomaawayoflife
    Roy
    Stock
    I Tried it no change
  4. Apr 26, 2019 at 1:47 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Do you have the owners manual for the radio?
    Have you looked under troubleshooting for your issue?
  5. Apr 26, 2019 at 1:48 PM
    Tacomaawayoflife
    Roy
    Stock
    I will try to locate it and review troubleshooting.
  6. Apr 26, 2019 at 2:15 PM
    Tacomaawayoflife
    Roy
    Stock
    Located the radio/nav owners manual didn’t find anything in reference to problem.
  7. Apr 26, 2019 at 2:26 PM
    Tacomaawayoflife
    Roy
    Stock
    I have an appointment Monday with Toyota service department. Thanks for all your help.
  8. Apr 26, 2019 at 4:44 PM
    pinktaco808
    pinktaco808 Hot Steppa
    Let us know if worked
  9. Apr 26, 2019 at 7:32 PM
    Tacomaawayoflife
    Roy
    Stock
    I will let you know after I see Toyota Monday. Thanks
  10. Apr 29, 2019 at 5:46 PM
    Tacomaawayoflife
    Roy
    Stock
    I took it into Toyota today, they said they would need the 3 numbers off of a the original pamphlet with Toyota nd Hartman Beckler labels on the front to reset the Navigation through the USB drive. Part #TOYH-EXT01-16. They could order the booklet for $185.00 plus $140.00 to install it. I told them to forget it. I will first check to see if I can find this booklet they’re referring too, if not I will probably go with an aftermarket head unit. Thanks for all the help.
