2nd gens on 37" tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Spoonman, Mar 12, 2014.
  1. Aug 25, 2019 at 4:49 PM
    #801
    STravis
    STravis Well-Known Member
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    I have 3/4" spacers on the front to keep the tire off the uca, but nothing in the rear.
  2. Aug 25, 2019 at 5:02 PM
    #802
    05prerun82
    05prerun82 Your local friendly Taco Mule TTC#0202
    Brandon
    Fredericksburg
    2006 aclb prerun
    Memphis sound system volant cold air intake
    Oh wow if you get a string line and put it against the front tire run to the back pass rear tire you can measure how much of a spacer you need for the rear to even it out
  3. Aug 25, 2019 at 5:15 PM
    #803
    STravis
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    3/4" is the smallest spacer they make that is hub centric that I know of and the front is always naturally narrower when you lift the truck. And I like the rear to track just a bit narrower than the front anyways. The rubbing on the rear isn't really enough to be worried about. It just knocks the dust off the shock body.
    05prerun82[QUOTED] likes this.
  4. Aug 25, 2019 at 5:24 PM
    #804
    Spoonman
    Spoonman [OP] Granite Guru
    Jamie
    Alberta
    Wow listen to this party pooper
    We don’t do that here
  5. Aug 25, 2019 at 6:13 PM
    #805
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Lol oh I'm a party pooper
    JKU3000 likes this.
  6. Sep 7, 2019 at 7:55 AM
    #806
    Regcab05
    Regcab05 Well-Known Member
    David
    Atlanta
    05 regular cab 4x4
    What size and spec wheels are you running?
  7. Sep 7, 2019 at 8:48 AM
    #807
    STravis
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    They are @SCSPerformance Ray 10's. 17x8.5 4.30" BS
  8. Sep 7, 2019 at 8:57 AM
    #808
    81Trekker
    81Trekker Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    Loving this thread!
  9. Sep 7, 2019 at 9:15 AM
    #809
    Regcab05
    David
    Atlanta
    05 regular cab 4x4
    What uca’s are you running? Did you find it necessary to run the Bora 3/4 wheel spacer in the front?
  10. Sep 7, 2019 at 9:19 AM
    #810
    Regcab05
    David
    Atlanta
    05 regular cab 4x4
    Trying to decide between 17x9 3.5 bs & 17x8.5 4.3 bs.
  11. Sep 7, 2019 at 9:22 AM
    #811
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If you’re trying to fit 37s then I’d definitely go 3.5bs
  12. Sep 7, 2019 at 9:44 AM
    #812
    STravis
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    I'm running Dirt King uca's and I still rub the front of the uca at full lock with .75" spacers. Not bad at all, but it does rub a bit. I would definitely run 3.5 bs if I were buying wheels again.
  13. Sep 7, 2019 at 9:52 AM
    #813
    Regcab05
    David
    Atlanta
    05 regular cab 4x4
    Thanks, that’s what I needed to know.
  14. Sep 7, 2019 at 10:00 AM
    #814
    Regcab05
    David
    Atlanta
    05 regular cab 4x4
    I’m already running long extended wheel studs and can’t run wheel spacers. SCS 17x9 3.5 BS sounds like the way to go with a body mount relocate and tubbing for 37x12.5x17’s.
  15. Sep 7, 2019 at 10:03 AM
    #815
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Depending how long your studs are, you might want open ended lug nuts so you don’t bottom out on the studs. The ones from scs have a closed end.
  16. Sep 7, 2019 at 10:15 AM
    #816
    Regcab05
    David
    Atlanta
    05 regular cab 4x4
    My studs are so long they would bottom out touching the wheel if I tried to use wheel spacers.
  17. Sep 7, 2019 at 10:17 AM
    #817
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah I get that. I’m just saying that when you get the scs wheels, you may want to be conscious of your lugnut selection
  18. Sep 7, 2019 at 10:21 AM
    #818
    Regcab05
    David
    Atlanta
    05 regular cab 4x4
  19. Sep 7, 2019 at 9:17 PM
    #819
    MasterfulStu
    MasterfulStu Master Debater and Mechanic
    Stu
    North TX
    09 DB LB 4x4
    B 6112, 5125, Camburg UCAs, OME Leafs, TRD FJ wheels wrapped in Duratracs
  20. Sep 7, 2019 at 10:46 PM
    #820
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
    How do you know they're open ended?
