2nd gens on 37" tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Spoonman, Mar 12, 2014.
  1. May 28, 2020 at 3:50 PM
    #941
    Spoonman
    Spoonman [OP] Granite Guru
    Jamie
    Alberta
    Thought we were all talking 2nd gens No one better bring Their 3rd in here.
    Blacktacoma23 likes this.
  2. May 28, 2020 at 3:57 PM
    #942
    CGoss
    CGoss Well-Known Member
    Las vegas
    2006 rad red offroad
    Sorry I must've missed that you have a 2nd gen. I've only seen your first gen.
  3. May 28, 2020 at 5:09 PM
    #943
    Spoonman
    Jamie
    Alberta
    Had
    buddy I started this thread lol
    CGoss[QUOTED] likes this.
  4. May 28, 2020 at 6:01 PM
    #944
    CGoss
    Las vegas
    I know. Why did you get rid of the Best gen?
  5. May 28, 2020 at 10:10 PM
    #945
    Spoonman
    Jamie
    Alberta
    I was just tired of it. Needed to change it up.
  6. May 28, 2020 at 10:37 PM
    #946
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    Some dumbass put 40s on his IFS 2nd gen :anonymous:
  7. May 28, 2020 at 10:49 PM
    #947
    Spoonman
    Jamie
    Alberta
    Dumbass? I beg your pardon?! That’s fuckin awesome.
  8. May 28, 2020 at 10:58 PM
    #948
    tetten
    Andy
    Socal
    It'll be awesome if I can keep the OEM steering rack from breaking every 10 miles of rocks. :rofl:
  9. May 29, 2020 at 4:04 AM
    #949
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    Nothing comes to mind other than the first trail I hit last Sunday. Had 2 3ft ledges with sharp rocks that we bombed up. Ended up hitting something hard enough my ram shifted 2 inches so I could barely steer to get back to the trailer to fix it haha.
  10. May 29, 2020 at 4:07 AM
    #950
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    I will say other than the ram moving the full hydro was amazing. Ran 7psi locked in the front and could steer with no issues. Even forgot to turn the locker off after a couple climbs because it steers so easy.
    10tacotrooper and ovrlndkull like this.
  11. May 29, 2020 at 4:09 AM
    #951
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Hell yeah!!!
  12. May 29, 2020 at 7:13 AM
    #952
    la0d0g
    running for the hills
    For crawling not hauling
    Y'all don't have sarcasm up there in Canada eh?
  13. May 29, 2020 at 10:45 AM
    #953
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    Obviously pavement is not the first consideration when putting 40s on, but if I drove from Canada down to Utah to do a wheeling trip, how much would I regret 40s over 37s? Because I do a lot of pretty long road trips, but also a lot of wheeling. Have 4.88s
  14. May 29, 2020 at 11:07 AM
    #954
    Mike likes Tacos
    Mike likes Tacos Mod in Training
    Northridge,CA
    2014 4x4 DCSB
    Long travel with big tires and lights
    @tetten this guy wants to see your truck.
  15. May 29, 2020 at 12:01 PM
    #955
    tetten
    Andy
    Socal
    Can't make an statement based on experience yet since I only have a couple hundred miles on it with the 40s. Don't even have the gears broken in on it. Got a couple more things to wrap up before I hit any trails with it.
    Only thing I feel I have any insight to offer about 40s is how much work it is for someone working a 40 hour a week job. I've been working on multiple projects on the truck, some of the simultaneously, for about 4-5 months so far. I completely removed the wheel wells, tubbed all the way back to the door hinges, relocated all of the components in the engine bay higher and inboard closer to the engine. I still have a bunch of smaller jobs & minor problems to solve before I would call the whole fitting job "done"
    Odd ball things I ended up doing or had already been done:
    Had to modify the brackets for the engine ECU to mount it further away from the firewall, literally couldn't install it the original location due to the amount I tubbed
    Battery was already relocated but I probably would have had to do it for 40s, the driverside fuse box and the offroad brake booster assembly take up a lot of space
    Parking brake foot lever removed due to the tubbing, this wasn't an issue for me since I had already disabled mine.
    Wiring harness plug mounts at the corners of the foot well won't fit right and need modification. Passenger side doesn't have much wiring in that corner so it's not an issues but the driverside on a trd offroad has a retarded amount of wiring in that corner, I still need to make a guard or cover to protect the wad of wiring down there from my left foot.
    Relocated the driverside engine bay wiring harness firewall penetration/boot higher to match the fuse box's location
    Body mounts had to be relocated
  16. May 29, 2020 at 12:56 PM
    #956
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    AWESOME !
    Spoonman[OP] likes this.
  17. May 29, 2020 at 7:30 PM
    #957
    WormSquirts
    Braeden
    BC
    Thanks for sharing! I've already relocated my batteries to the cab, and relocated my body mounts, and I have JD fab's LCA relocate, but I haven't installed it yet. I'm hoping that means a bit less tubbing on the firewall end.
    Because of my business I have almost no time to work on my own truck during the spring/summer/fall, but come winter things slow down enough that I can usually get my own truck on the hoist for a good week straight if I time it right. I've just been debating between 37s or 40s. 37s are a lot less work, and probably easier on the truck, and better on the highway for long road trips to wheeling spots. Just thought I'd ask your thoughts on them so far, because it's super badass what you've done. I'm Also a big fan of your tail lights!
    Are you running 5.29?
  18. May 29, 2020 at 9:14 PM
    #958
    tetten
    Andy
    Socal
    5.29 front / 5.38 rear
    WormSquirts[QUOTED] likes this.
  19. Jun 4, 2020 at 4:57 PM
    #959
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    How is the combination of 5.38 & 40s with an automatic on the road?
  20. Jun 4, 2020 at 10:03 PM
    #960
    tetten
    Andy
    Socal
    37s on 4.56 at 6500+ lbs sluggish as fuck and couldn't use over drive
    40s on 5.38 at 5000lbs don't have to smash the gas pedal to get pushed into the seat. Haven't driven it much on the interstate so I can't say anything there yet.
    It'll probably be around 5500lbs after I put everything I need back on, don't expect it to feel much different though
    The_Black_Pearl likes this.
