2nd gens on 37" tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Spoonman, Mar 12, 2014.
  1. Dec 12, 2021 at 7:04 PM
    #1161
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    39s? REQUIRE PICTURES I DO.
  2. Dec 13, 2021 at 8:06 PM
    #1162
    Evergreen_Offroad
    Evergreen_Offroad Well-Known Member
    Andrew
    2009 Tacoma TRD Offroad Access Cab
    35s, armor, mid travel etc.
    Heres ya go!
  3. Dec 13, 2021 at 8:38 PM
    #1163
    Oreo Cat
    I want 39s now.. anything break?
    Junkhead likes this.
  4. Dec 13, 2021 at 9:34 PM
    #1164
    Evergreen_Offroad
    Andrew
    Nah not yet but cannot verify until snow season is over and rocks come into play.
  5. Dec 14, 2021 at 4:45 AM
    #1165
    Pizzasteve5717
    Pizzasteve5717 Well-Known Member
    Steven
    Marietta, GA
    2005 Tacoma TRD prerunner
    So if I at least want 37s what should I regear to??
  6. Dec 14, 2021 at 6:48 AM
    #1166
    la0d0g
    running for the hills
    For crawling not hauling
    5.29 if AT, 4.88 if MT should get you back close to stock RPM levels.
    6 gearT444E likes this.
  7. Dec 14, 2021 at 7:06 AM
    #1167
    DG92071
    DG92071 Well-Known Member
    I definitely don't agree. 2500 RPM at GPS'ed 70 mph with 37's and an auto trans is higher RPM's than stock. 4.88 would be closer to stock on a 2nd gen.
    I purposely overgeared for towing which my truck does almost daily.
    DocME likes this.
  8. Dec 14, 2021 at 7:14 AM
    #1168
    Evergreen_Offroad
    Andrew
    4.88s IMO. I wouldnt even want to run 5.29s with 39s, not worth the loss in strength for a minimal gain in gearing.
  9. Dec 14, 2021 at 7:18 AM
    #1169
    DG92071
    Good point. The shop that did the ring and pinion install on my truck mentioned 5.29 is the lowest gear they'll install on a Tacoma due to the little gear getting so little. They also told me 37's was the largest tire they'd recommend on a Tacoma due to tire/wheel weight and the bearings but you have 39's so...
    edit: the little gear is the pinion, I had a brain fart lmao
    Pizzasteve5717 likes this.
  10. Dec 14, 2021 at 7:51 AM
    #1170
    bhigbee
    bhigbee Well-Known Member
    Barney
    Hayden Id
    Wrecked 07 DCSB
    35s, flatbed, rhino liner paint, SOS front bumper, JD Fab lca pivot, JD Fab inner fenders and some other stuff.
    Yes, I regeared when I went to 35s and was very glad I did. I have the manual transmission and it was like getting a whole lower gear(in the transmission) going from 3.73 or whatever it came from stock to the 4.88s. It was not fun to drive in the mountains with the fasctory gearing. You'd have to slip the clutch way too much to get going on any kind of hill.
    Edit: sorry I miss read your question, I'd recommend 4.88 like others on here have said.
  11. Dec 14, 2021 at 8:09 AM
    #1171
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Numerically higher gear ratios being appreciably weaker is pretty well debunked at this point on stuff short of a race application that struggles with heat management. Old internet lore isn’t always true.
    That being said, getting a good setup and pattern is much more important on a 5.71 compared to a 4.10 gearset :)
  12. Dec 14, 2021 at 8:26 AM
    #1172
    la0d0g
    That's not too far off base though. Not like you're at 1k over.
  13. Dec 14, 2021 at 8:57 AM
    #1173
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
    So, whatcha doing with your 37s?
    I'd be interested if your selling them. :thumbsup:
  14. Dec 14, 2021 at 10:41 AM
    #1174
    LardOfTheTacos
    LardOfTheTacos Member
    Diego
    2009 Tacoma TRD offroad with extra cheese and super spices!!
    285/70/17 on evo dakars GTS lift kit with adjustable control arms. ARB bumper aluminum RCI skids rockslides comeup winch
    I KNOW you did not ask me, but I broke my rear ring and pinion on 39s. it was really kind of a fluke, but I went for the ECGS dana 60 upgrade on that. its pretty nice I can't complain.
    Pizzasteve5717 and DG92071 like this.
  15. Dec 14, 2021 at 12:12 PM
    #1175
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    Guys on 37s.... are you balancing with regular stick-on wheel weights or balancing beads or a combination of both?
  16. Dec 14, 2021 at 2:36 PM
    #1176
    6 gearT444E
    Deep South
    Herculiner Hootus
    This VVVV. Even on 5.71s, ZUK has proven they are no more "weak" than another lower gear ratio set.
    http://www.gearinstalls.com/410suck.htm
    whatstcp likes this.
  17. Dec 14, 2021 at 3:38 PM
    #1177
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    Just threw beads in mine and they run super smooth actually. Might have just got lucky though as I'm running beadlocks too which don't always balance nice
  18. Dec 14, 2021 at 5:50 PM
    #1178
    Evergreen_Offroad
    Andrew
    Sold ;(
    TacoEspecial[QUOTED] likes this.
  19. Dec 14, 2021 at 6:18 PM
    #1179
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    How did you like them?
    I'm trying to decide between the geolander g003 and toyo mt's, curious which one you'd prefer.
  20. Dec 14, 2021 at 7:23 PM
    #1180
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    I’m literally try to decide on the same two tires right now. I’ve had excellent experiences with the Toyo’s but they’re like 84#’s compared to the 76#’s on the geolandars. Moving into 37’s has me prioritizing weights a little more these days then a bullet proof tire.
