2nd Impression Nitrocharger Sport Stiffness
Discussion in 'Suspension' started by james, May 25, 2011.
  1. May 25, 2011 at 11:30 PM
    james
    james [OP] In over my head...
    Friday Harbor, WA: Fairbanks, AK
    '98 Tacoma V6
    So...I switched over from a completely blown-out factory 160K stock suspension to an OME suspension. 881s, Nitrocharger Sport shocks on all four corners. Not knowing what to expect, I drove the new suspension and my first impression was that it was STIFF. E-Gads, was it stiff. I was driving it without a load in the back, only a canopy. I wondered how I was going to get used to how stiff it was.
    Today, it got better. A LOT better. Today on another part of the internet I read a thread talking about how a guy adjusted his tire pressure for the surfaces he drives on. I was running 35 lbs on an empty bed. He let the air out to 20 lbs when he knows he's going to drive on dirt/washboarded roads. I decided to do the same.
    On my Ride-Rite airbags, which I had adjusted so as to raise up the rear to match the front (I didn't replace the rear springs this time, since I had the airbags), I had about 40 lbs of pressure in them. I took it down to 10 lbs. What a difference both adjustments made on the truck: an INCREDIBLE difference!
    On dirt, this truck is smooth and safe. On the pavement, it's much more comfortable even when I run my tires at 26lbs psi.
    Comfortable, comfortable, comfortable. I was beginning to wonder if I had made the right decision. I am now amazed at how such a small adjustment could make my truck feel so much better. NOW, I am happy with my suspension replacement, and can recommend Nitrocharger Sports without reservation.
  2. Jun 17, 2011 at 1:13 PM
    04SilverTRD
    04SilverTRD Member
    Wisconsin
    04 Access cab 4x4 Silver - Stock
    None
    You went from 40# to 10# of pressure in the tires? am I reading this right?
  3. Jun 17, 2011 at 1:38 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    No, you read wrong, he went from 40# to 10# in his adjustable air bag rear suspension.
  4. Jun 17, 2011 at 2:54 PM
    04SilverTRD
    04SilverTRD Member
    Wisconsin
    None
    Ok, I see it now... I'm reading to fast.
    "On my Ride-Rite airbags...."
    Thanks,
