2nd Tacoma Class 5 hitch?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco Pastor, Aug 27, 2022.
  1. Aug 27, 2022 at 7:45 PM
    Taco Pastor
    Taco Pastor [OP] Well-Known Member
    Brian
    2009 Tacoma V6 access cab 6spd Barcelona rec
    Hey Anyone,
    I might need to upgrade my hitch from a class 4(the factory toyota hitch 5,000lbs) to a class 5
    https://www.extremeterrain.com/tacoma-class-v-multi-fit-trailer-hitch-15511.html
    Can anyone tell me if this will fit and has anyone done this? I thought about taking mine to a fab shop and having them beef it up and sandblast it and repowder coat it, but I might as well get the one above if it will fit.
    I know, I need WxLxH......I don't know.
    I had another thought........do the offroad bumpers have better towing capacity? As you can tell I need HEEEELP! LOL!
  2. Aug 27, 2022 at 7:57 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    What do you need a class 5 hitch on a Tacoma for?
    Those are generally for 3/4 ton and up trucks and a class 4 will tow way more than a Tacoma will pull.
    Too Stroked, Sprig and Key-Rei like this.
  3. Aug 27, 2022 at 8:17 PM
    Taco Pastor
    Brian
    I am thinking about weight, my factory hitch only goes to 5,000lbs. I just don't want my hitch to give out, bend when I'm going down the road if I do tow more than 5,500 lbs which I very well might have to.
    Suggestion?
    Can the factory hitch be beefed up, like putting more square tube in the hitch and adding 1/2 steel on top so it won't warp, bend? Will something like that work?
  4. Aug 27, 2022 at 8:22 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    Jfc. Your hitch is rated for what the Tacoma can tow (give or take 1000lbs). There's a safety factor of about 2-2.5 built into those ratings. Don't tow heavy shit with your Tacoma if you like your Tacoma. Get a full size if you need to regularly tow heavy stuff.
  5. Aug 27, 2022 at 8:27 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    V6 Tacoma's with the Tow package are rated to tow 6400#, they wouldn't have put a hitch on them that wasn't capable of at least that.
    As far as the hitch goes tongue weight is what you have to be concerned about with that big of a trailer.
    Not that it's ideal to tow that much with one but the hitch would be the last thing I would be worried about failing.
    I've never seen a Class V hitch on anything smaller than a 3/4 ton truck.
    Sprig likes this.
  6. Aug 27, 2022 at 8:31 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    If your truck has the tow package then your hitch is rated for 7000 lbs plus. Class 4 hitches can handle up to 10,000 lbs. If you don’t have the tow package then you shouldn’t be towing more than about 3500 lbs. no matter what hitch you have.
    Dm93 likes this.
  7. Aug 27, 2022 at 9:13 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I’ve towed an illegal amount of weight with our trucks and the hitch is not the limiting factor. You won’t be able to handle the truck/trailer safely FAR before the hitch breaks. I would actually think you’d break a leaf spring or damage the rear axle before breaking the hitch.
  8. Aug 28, 2022 at 1:36 PM
    Taco Pastor
    Brian
    So I've seen all your stuff now I have decide what to do. My hitch had a sticker on it that said 5,000 lbs, before it fell off. Not sure if that was towing, tongue weight (seems a little high, you tell me).
    All I want is a little more towing capacity.
    And I will not get rid of my Tacoma, I have the frame recall, and tons of new parts. Tundras pull 8,000 lbs and Tacoma's pull 6,500 lbs. My tow bar and ball says, " 6,000" tow rating.
    I'm probably going to upgrade to the Z36 brake package before I tow.
    Later and comment....thanks....Brian
    Alexely999 likes this.
  9. Aug 28, 2022 at 2:14 PM
    Sprig
    Ken
    Do you have the tow package on your truck?????
    Dm93 likes this.
  10. Aug 28, 2022 at 3:12 PM
    Taco Pastor
    Brian
    Apparently, I have a trailer light hook up and a hitch. If that is not it,how do I find our. TIPS?
  11. Aug 28, 2022 at 3:14 PM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    You’ll have an oil cooler line connected to your oil filter housing, and also a pink fan clutch. Also a transmission fluid cooler/tiny radiator looking thing in front of your radiator behind your grill.
    Dm93 likes this.
  12. Aug 28, 2022 at 4:53 PM
    Taco Pastor
    Brian
    Ok, so I do have a pink fan clutch, and I just now checked, I do have the smaller radiator. So would you say I have the tow package? I would say so....you?
  13. Aug 28, 2022 at 6:20 PM
    Sprig
    Ken
  14. Aug 28, 2022 at 7:08 PM
    Taco Pastor
    Brian
    Thanks a bunch man
    I just put my vin in....no dice about the hitch. I don't live too far from Bill Walsh Toyota in Ottawa, IL. I'll call them. Thanks.
  15. Aug 29, 2022 at 8:11 AM
    westport toyota
    westport toyota Well-Known Member
    Look under your truck where the rear of the leaf spring is mounted to. see that thin metal mount? mine are bent just from years of lumber in the bed. No where near 4k pounds. I cant imagine what a trailer wound do to them. tacomas are great trucks except if you want to haul shit them. then they suck. People talk about the rear end wavey feeling when hauling thats because those mounts are under there flexing back and forth .
  16. Aug 29, 2022 at 8:13 AM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    If you have the transmission cooler then you have the tow package, or someone just added it for fun.
  17. Aug 29, 2022 at 8:27 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Your towing capacity is based on way more than just what the hitch will handle. If you upgrade the capacity of the hitch, many other things (some that you cannot see) will now be under capacity. And if you're towing more than the rated capacity of the truck and get stopped, it's going to get dangerous and expensive.
    If your truck has the towing package, leave everything as is and you'll be far better off.
  18. Aug 29, 2022 at 10:55 AM
    Sprig
    Ken
    I believe you have a manual tranny not an automatic. Manual trans do not have tranny coolers. That smaller radiator is for the a/c. You absolutely need to determine for sure if you have the tow package. If you have it then you tow capacity is about 6500 lbs. The you don’t need to do or change anything. If you don’t have the tow package then your tow capacity is around 3500 lbs. There is nothing you can do to increase the manufacturer’s tow rate capacity.
  19. Aug 29, 2022 at 11:16 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    This is really easy. With tow package it’s 6500lbs, w/o it’s 3500lbs. No matter what you do you can’t tow more than those #s. We’ll you could but not safely.
  20. Aug 31, 2022 at 4:46 PM
    Taco Pastor
    Brian
    Thanks gents...thanks. I might call my local yocal toyota stealer and find out through my vin # if I have it.
    I do have the pink cllutch fan though is what I think somone said.
