2nd time the bolts sheered off
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04v6trd, Jan 12, 2014.
  1. Jan 12, 2014 at 11:49 PM
    04v6trd
    04v6trd [OP] Well-Known Member
    tylor
    port moody
    silver double cab ted
    this is the 2nd time the bolts from my lower control arm to wheel assembly/ lower ball joint have sheered off in the last 4 month. first time i was in the sand so i could see maybe somthing happening. fixed it replaced the bolts with some that were supposed to be really strong grade 8 bolts.
    happy it was in the sand and not 20 min later on the way home on the highway
    last night driving home at 2am, back street, smooth pavement, doing 10mph BAM passenger side drops into the pavement. EXACT SAME THING. luckily i didnt replace the fender from the last time it happened so i just wrecked a already wrecked fender. people were saying loose bolts or hitting the trails to hard. havnt been in the bush a whole lot since last time it happened and i just checked all the bolts last week when i changed my rotors.
    i had a alignment done about a month ago. steering wheel was centred perfectly. last night before this happenedi noticed my steering wheel was at almost 9pm going straight. huge red flag, figured id check in the morning. didnt make it home to check.
    if any mechanics can give me any insight into why it has happened twice to the passenger side??
  2. Jan 12, 2014 at 11:52 PM
    04v6trd
    tylor
    port moody
    only theory i can think of is maybe my rack and pinion is fucked and the passenger tire is slightly turning right while my left tire stays straight. causing pressure on the bolts and all of them just ripping away :(
  3. Jan 13, 2014 at 6:49 AM
    604YOTA
    604YOTA Well-Known Member
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Grey wire mod, eibach, 5100's & 5125's, ome Dakar leafs, 1.25 rear shackle, Gibson exhaust, ram air intake, throttle body spacer, boot slide mod, poly bushing kit, extended brake lines.
    Well you are probably on the right place to hopefully shed some light on the situation.
  4. Jan 13, 2014 at 6:56 AM
    gearcruncher
    Canadain bumper technician
    Are you lifted ?
    hard to tell by the pics
  5. Jan 13, 2014 at 7:48 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    Maybe your LBJ bolts loosened up a bit? If you get any slop in there, an impact can shear them off...
  6. Jan 13, 2014 at 7:53 AM
    04v6trd
    tylor
    port moody
    the first time it happened i was stock in the front. now i have billy 5100 set to the middle setting
  7. Jan 13, 2014 at 8:09 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Can't tell from the picture is it shearing the stud off the ball joint or just the bolts holding it to the control arm? If it's the bolts on the control arm it should have done damage to the control arm it's a lot softer than the bolts. The shear force of the bolt is probably close to 30,000# so they must have been lose.
  8. Jan 13, 2014 at 8:35 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Looks like the ball joint itself broke away in the 'on pavement' incident. What brand joint did you replace the original with?
  9. Jan 13, 2014 at 11:02 AM
    04v6trd
    tylor
    port moody
    The first time it happened i didnt replace the ball joint. There was no damage to it. Only the bolts and cv axle. It was just the 4 bolts that sheered away. Pretty sure ill need a new ball joint this time because the ball joint stud did alot of damage to the pavement haha.
  10. Jan 13, 2014 at 1:16 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Are you the original owner? Do you know for sure if before the 1st failure, the original factory installed 4 LBJ bolts have ever been disturbed, for any reason?
  11. Jan 13, 2014 at 2:13 PM
    04v6trd
    tylor
    port moody
    I am the 3rd owner. I have no clue if the anything happened with the first owner. Defiently didnt happened with the 2nd owner cuz he put like 50km on it and owned it for 2 weeks before toyota told him you cant tow them
  12. Jan 13, 2014 at 2:40 PM
    mick478
    mick478 He is The STig
    Bott
    Stockton, CACA
    2011 White TRD Sport, 4x4 doublemint cab
    Ome 885 coils Ome n9000 front shocks Ome n182 rear shocks K&n drop in filter Duratracs Kenwood kac 90210d Kicker 12" Alpine 800 watt 4 channel Pioneer 430w 6x9 Firestone ride rite air springs
    If the bolts going into the knuckle we're loose for any amount of time, the threads will definitely be donezo
  13. Jan 13, 2014 at 4:09 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    Before anything else, be aware that metric grade 8 is more or less a standard or general purpose bolt and not up to the job for LBJ fasteners.
    I asked the questions in my initial reply because in monitoring Tacoma forums since Tacoma day one, I have never heard of a LBJ bolt failure with respect to the original factory build. This means that (IMO) all 1st gen LBJ bolt failures are a result of an installer falling short of the correct required process to one degree or another or a poor quality replacement joint. Racing/jumping is not part of this discussion.
    Outside of poor quality aftermarket parts (frankly all but OEM), not observing all the following points for an install can result in the bolts loosening followed by shearing and catastrophic failure.
    The somewhat flawed design by Toyota of having the 4 mount bolts in a constant state of tension dictates that every degree of TLC must be applied.
    In no particular order.
    #1 Use thread locker.
    #2 Use the thread locker properly. Things must be CLEAN. One pinhead sized crumb of greasy crud in the bolt hole can negate the effectiveness of the thread locker. Old thread locker debris left in the bolt holes can "wipe" away the fresh stuff as the bolts are installed.
    #3 Correct torque, 59 ft lbs, correctly applied to NEW bolts.
    #4 clean and inspect the mounting surfaces for burrs or nicks, clean with solvent. OEM replacement joints come with a coating of rust preventative that must be removed.
    #5 Dry fit the joint and check for any rocking and proper fit of the single alignment sleeve, the little collar around one of the bolt bores.
    Properly installed these bolts will not "just loosen".
  14. Jan 13, 2014 at 4:21 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    There's no such thing as "metric grade 8" fastener. Grade 8 is a US bolt grade. The closest metric equivalent would be a class 10.9 which actually has a slightly higher minimum yield and minimum tensile strengths. And that is perfectly acceptable for the LBJ as that's precisely what comes from the factory.
    Other than that I'm in agreement with you. Threadlocker is the key (even comes that way from the factory).
  15. Jan 13, 2014 at 4:39 PM
    04v6trd
    tylor
    port moody
    ok so thread locker is always good. so if bolts started falling out on my drive home would that be why my alignment suddenly went to shit 10 minutes before it failed??
  16. Jan 13, 2014 at 4:46 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Most likely.
    Loose bolts means the spindle is flopping around. Tie rod is connected directly to the spindle, tie rods to your rack, rack to your steering wheel, steering wheel to your hands.
    Loose bolts = shit alignment, crooked steering wheel, sheered bolts...and most likely fucked threads in the spindle. I'd be surprised if you don't need a new spindle after this little endeavor.
  17. Jan 13, 2014 at 5:39 PM
    04v6trd
    tylor
    port moody
    oh im very sure ill need a new one. probably no threads left.
  18. Jan 14, 2014 at 8:58 PM
    Mattb114
    Mattb114 Member
    Agua Dulce
    04 Tacoma PreRunner Build
    Suspension/Drivetrain: - Daystar Leveling Kit - KMC XD Hoss 16" Wheels - Falken High Country Tires Lighting: - Digi Diodes 3x3" Led Pods - 3x 7" HID Lights w/ weather pack connectors - Soon to be 40" Roof Mounted LED Bar from TruxTech LED Lighting - Phillips Xtreme vision Halogen bulb replacements - Blinkers relocated to running lights/headlight housings Stereo: - Kenwood Head unit (Single DIN) - JL Audio Speakers (both boors and rear cabin sides) - JL Audio HD 900/5 5 channel amplifier - JL Audio CS110WXv2 Subwoofer - Rockford Fosgate 1 Farad Capacitor - Standard 4 awg wiring kit - Two in line AGU Fuseholders - Digital Voltage meter for battery readout Core/Body Mods: - Custom Bumper & Skid Plate by AP Camera Cars - K&N Cold Air Intake - Plasti dipped Emblems and Grille
    if it was me I would just take a hit and uprage the lower control arms to camburgs or total chaos's... that shit wont ever happen again. That's a strange issue because ive never had that problem on my tacoma.
  19. Jan 14, 2014 at 9:02 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Neither Camburg nor TC make aftermarket lower control arms for first gens unless you buy a full long travel kit. Furthermore the bolts that are sheering off are not part of the LCA. They are bolted through the LBJ into the spindle. So even if you did replace the LCA, nothing would change from the original problem the OP posted about.
  20. Jan 14, 2014 at 9:03 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    F911 bolts, fuck yeah
