2nd vs 3rd Gen reliability
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Coopsdaddy, Jul 26, 2024.
  1. Jul 26, 2024 at 10:03 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    The 2nd gen may be slightly more reliable (and less complex.) They're both great trucks.. go with the best deal you can find for a lower mileage clean and low/few owner non-modified truck.
    2024OffRoad likes this.
  2. Jul 26, 2024 at 10:30 AM
    Brikan
    Brikan Well-Known Member
    2018 Inferno Tacoma TRD Offroad
    B&M shifter Hood gas strut Injen Intake OSC catch can
    The none modified is a big thing, a lot of tacoma owners talk big, but will do anything to avoid paying. IE: hack up wires, cut corners with cheap modifications, otherwise they would have gotten something other than an tacoma.
    Previous owner of mine tapped the harness and solder a reverse light into the main body loom right before, instead of at the pin, and had a diff drop kit installed when he should have gotten a bushing to replace the needle bearing.
  3. Jul 26, 2024 at 10:30 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    What do you feel is unreliable?
    I do not see any real trends since some early TSBs sorted some teething pains.
    Pwakchop and Chew like this.
  4. Jul 26, 2024 at 10:46 AM
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    Why would you buy a used truck modded like that in the first place unless you got an insane deal...
    Chew likes this.
  5. Jul 26, 2024 at 10:51 AM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    The 1gr 4.0 that was in the second gen Tacoma is still used in the 4Runner and 70series Land Cruiser in some parts of the world. Toyota would have kept it in the third gen Tacoma had cafe standards not forced them to go to the 2gr 3.5
    The sienna minivan and Camry used the 3.5. The 4.0 is a truck motor and the 3.5 is a car motor
    also the 4.0 is more reliable, the 3.5 is a decent engine but not as reliable nor is it anything remotely similar to the 3.5
    2024OffRoad and slossboss like this.
  6. Jul 26, 2024 at 10:56 AM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    We're splitting hairs with reliability but there's no argument that a 3rd gen has more longevity simply because they're newer.
    If OP truly is intending to keep the truck to 300K miles it makes sense to have something that's doesn't already have 150K miles of unknown history.
  7. Jul 26, 2024 at 11:25 AM
    lit_taco4x4
    lit_taco4x4 IG and YT: @2a_crawlcamper
    Louie
    2018 Tacoma TRD Pro
    JD fab LT, Archive and Deavers, King shocks, Dual locked, Dual T case, Tundra steering rack, 39’s
    can definitely last more than 300k, someone just posted earlier of one crossing over to 400k.
    Pwakchop likes this.
  8. Jul 26, 2024 at 12:20 PM
    Coopsdaddy
    Coopsdaddy [OP] Well-Known Member
    Quinton
    2012 dclb tacoma
    6112/5160 Deaver stage 1 Are topper Steelies,255/80/17
    Great comparison.
    I have looked at some nice 2nd Gen with low miles(40000-70000)and all were rusty.
    Some guys act like it’s no big deal but im holding out.
    I have also passed on a few that were definitely cared for by there owner that just wasn’t exactly what I wanted.
    I’ll just hold out as they seem to pop up every month or so.
    MGM low mileage manual access cab is my preference.
    POOLGUY and slossboss like this.
  9. Jul 26, 2024 at 12:38 PM
    waffleiron
    waffleiron Well-Known Member
    Washington
    I think its easier to put a 3rd gen fron end and interior in a 2nd gen, both have been done actually.
  10. Jul 26, 2024 at 12:39 PM
    kwanjangnihm
    kwanjangnihm Timeout Terminator
    Jeff
    Central Florida
    13 DCLB TRD SP PR OTT
    "If it ain't a longbed it ain't shit! :)
    2.5nd gen, low mileage, 13-15 just don't be in a rush!
    Autotrader 118K 6sp manual $17.5K
    Used 2013 Toyota Tacoma 4x4 Access Cab V6
  11. Jul 26, 2024 at 5:26 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    A lot less to go wrong. 4.0 and no "atkinsons cycle" nonsense.
    POOLGUY, 2024OffRoad and kwanjangnihm like this.
  12. Jul 26, 2024 at 6:17 PM
    Pwakchop
    Pwakchop Well-Known Member
    Nate
    Georgia
    2021 Cement DCSB TRD Sport
    Whole lotta' momentum
    :confused:
    I will eat my words if there's a single post about the "atkinsons cycle nonsense" causing an issue with 3rd gens.
  13. Jul 27, 2024 at 10:26 AM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    It does not cause any issues, but i as a old fart can't get past the intake valve staying open at the start of the compression stroke. that's all
    Pwakchop[QUOTED] likes this.
  14. Jul 28, 2024 at 5:47 AM
    Ryeguy
    Ryeguy Well-Known Member
    43* North
    2021 TRD Off Road 4X4 Blackout
    OEM Bed Extension, Bed Mat, Lomax Bed Cover, Auto lock tailgate (OEM)
    Had a 2010. Now own a 2021.
    The only reason I would buy a 15+ year old vehicle would be because I was passionate about it. I would know everything about the model, be searching the internet for unicorn examples from low rust zones, and not coming on a forum to ask which is better. I would know exactly what I wanted and why.
    I’d also have a second vehicle as a daily because any 15+ year old rig is going to likely have electrical gremlins as wires and sensors reach the end of their service life expectancy.
  15. Jul 28, 2024 at 5:48 AM
    #35
    Coopsdaddy
    Quinton
    2012 dclb tacoma
    That’s ok but more miles for price than I want.
  16. Jul 28, 2024 at 5:53 AM
    #36
    Coopsdaddy
    Quinton
    2012 dclb tacoma
