2RZ/3RZ, 5VZ, 2UZ Valve Lash Inspection Sheet
Discussion in '1st Gen. Tacomas (1995-2004)' started by Reh5108, Dec 24, 2020.
  1. Dec 24, 2020 at 12:23 PM
    Reh5108
    Reh5108 [OP] Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Not sure if anyone is interested in this but it kind of speeds up the process when checking valve lash and not having to do the math to figure out the correct size shim. Green is within spec and red needs attention. It is also nice to have if you keep records of your maintenance.
    Just click the link and go to "file" > "make a copy" and its all yours.
    2RZ/3RZ
    https://docs.google.com/spreadsheets/d/1B4dRe3U4b2H-qAXb6LKdDKaDmFsVtSm5TMRx2UY82Wo/edit?usp=sharing
    5VZ
    https://docs.google.com/spreadsheets/d/1WyjsxfEJamxS5D8BVjG5jiZ6btPb83U_WGiSWwNoe0I/edit?usp=sharing
    2UZ non VVT (not sure if different spec or not, I don't have a VVT FSM to confirm.)
    https://docs.google.com/spreadsheets/d/1P-WxmPoK4z1AOjj7YtaSJl0kYtcb-gI2X6q7xRe36Co/edit#gid=0
    Currently waiting on a shim to finish my 5vz but here is an example.
    vtwoodchuck likes this.
  2. Dec 24, 2020 at 9:42 PM
    billybop90
    billybop90 Well-Known Member
    Bill
    Black Hills SD
    1996 Taco, 2.7, 4WD, 5 spd
    Good to have in the ol tool bag, thanks!
    Reh5108[OP] likes this.
  3. Aug 20, 2022 at 9:36 PM
    Reh5108
    Idaho
    Updated the original post to include the 2UZ. Not sure if anyone finds this helpful or not.:notsure:
    vtwoodchuck and Diablo169 like this.
  4. Aug 21, 2022 at 1:00 AM
    Toyotadilly
    Toyotadilly Well-Known Member
    Dillynn
    Sarasota,fl
    03 prerunner 2008 Toyota Sequoia limited w/tow package..01 echo 310k soon daily
    Bilstein 5100’s.eibach coils.stoptech cryogenic rotors.1.25in toytec blocks.tranmission cooler. Electric fan w/ relay.
    Very useful. Thankyou
  5. Aug 21, 2022 at 5:40 PM
    vtwoodchuck
    vtwoodchuck Well-Known Member
    New England
    2001 Reg Cab 4wd
    This needs to be a sticky
