2rz/3rz whats the difference between them
Discussion in '1st Gen. Tacomas (1995-2004)' started by Honda Eater, Jan 13, 2010.
  1. Jan 13, 2010 at 6:29 AM
    Honda Eater
    Honda Eater [OP] Member
    what is the difference between the 2rz and the 3rz.how do i get the power of 3rz out of 2rz with out after market mods? is there an engine accessory i can pull off the 3rz?
  2. Jan 13, 2010 at 6:30 AM
    98tacoma27
    Ben
    Not Beech Creek
    Its compression ratio. The 3rz has balance shafts where the 2rz doesn't, also.
  3. Jan 13, 2010 at 6:31 AM
    Honda Eater
    so higher compression ratio?
  4. Jan 13, 2010 at 6:32 AM
    Honda Eater
    how did you find my thread so fast
  5. Jan 13, 2010 at 7:06 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, the 3rz has a higher ratio. 9.5:1 vs 9:1. IIRC. Someone will correct me if I am wrong on the ratio numbers.
    :spy:
  6. Jan 13, 2010 at 7:16 AM
    98tacoma27
    Ben
    Not Beech Creek
    There is only about a 10hp/20ftlb torque difference between the motors.
    You could get a set of headers and do the deck plate mod to gain about that, if not a little more.
  7. Jan 13, 2010 at 8:07 PM
    Honda Eater
    im sorry im unfamiliar with a "deck plate mod" im not oblivious to cars but in hawaii you dont come across that to often?
  8. Jan 13, 2010 at 8:11 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    Pretty sure the 3rz has forged rods as well...
  9. Jan 13, 2010 at 8:17 PM
    Honda Eater
    i see a deck plate is aka an air box.....
  10. Jan 13, 2010 at 8:43 PM
    Project.paradigm
    Project.paradigm Well-Known Member
    Oil Country,Alberta, Canada
    04 TRD 4X4 Dub cab
    Airlift rear air bags. Hood struts. sockmonkey bedside decal. TRD supercharger(not installed). Deckplate. Grey wire mod. Extended rear diff breather. 6000k HIDS. 18"Magnaflow. Truxxx 3" level kit. (Temporary) Wet Okole seat covers. BoxRocket bed rack. Bora 0.75 wheel spacers All pro sliders. BAMF BPV. B&M trans cooler.
