2RZ clutch orientation 2004 taco
Discussion in '1st Gen. Tacomas (1995-2004)' started by choopes, Aug 5, 2022.
  1. Aug 5, 2022 at 9:26 AM
    choopes
    choopes [OP] Well-Known Member
    Troy, Al.
    2004 reg cab
    Stock
    To my horror, it seems to mount either way. How can you tell what side goes to the pressure plate?
    thanks
  2. Aug 5, 2022 at 9:32 AM
    Jakuku Pahwheenis
    Jakuku Pahwheenis i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
    There should be a sticker saying "flywheel side". But if not, usually the side where the springs protrude the most goes to the flywheel.
  3. Aug 5, 2022 at 9:44 AM
    choopes
    Troy, Al.
    2004 reg cab
    Stock
    I went back over both the new one and the old one. I don't see any indication, or "flywheel side"
  4. Aug 5, 2022 at 9:47 AM
    Jakuku Pahwheenis
    J Phoenix
    South Carolina
    I think the top image would go to the flywheel.
    EDIT: I'm wrong, the bottom one! ITS THE BOTTOM ONE. QUICK BACK IT UP TERRY!
    Speedytech7, Key-Rei and tirediron like this.
  5. Aug 5, 2022 at 9:49 AM
    choopes
    Troy, Al.
    2004 reg cab
    Stock
    Thanks friend. i may dig around for more info
  6. Aug 5, 2022 at 9:58 AM
    Jakuku Pahwheenis
    J Phoenix
    South Carolina
    No prob. Hopefully someone else comes in to confirm or deny or give better advice.
  7. Aug 5, 2022 at 9:59 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Agree.
  8. Aug 5, 2022 at 10:02 AM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
  9. Aug 5, 2022 at 10:33 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Ha Ha Ha I learned this lesson well Changing my first Clutch .
    With the car parked across a low spot in the yard .64 Chevy Nova
    3 speed.
    I think we pulled the Transmission out 4 times till we got it correct.
    In this case the disc would work facing in either direction installed wrong it was just made noise but worked.
    Speedytech7[QUOTED] likes this.
  10. Aug 5, 2022 at 10:36 AM
    Jakuku Pahwheenis
    J Phoenix
    South Carolina
    Would the 3rz and 2rz orientation be the same then? If I recall, the sticker on the clutch I just installed matches the image above so I would like to recant my original statement to OP.
  11. Aug 5, 2022 at 10:39 AM
    Speedytech7
    Yessir according to the 04 FSM
  12. Aug 5, 2022 at 10:43 AM
    Bivouac
    All Clutch discs face the same direction in all the ones I have installed
  13. Aug 5, 2022 at 10:45 AM
    Speedytech7
    The toyota clutches are weird I've had them come from Exedy and Seco with the flywheel side labeled wrong which tells me its used on other vehicles that aren't as weird as toyota
  14. Aug 5, 2022 at 10:49 AM
    Bivouac
    Anymore good help is hard to find 2 clutch kits for the same application each kit had the the clutch disc label on a different side.
    I just go by how the disc coming out was installed. Though 5 speed swaps make me dig out the FSM to double Check.
  15. Aug 5, 2022 at 10:52 AM
    Jakuku Pahwheenis
    J Phoenix
    South Carolina
    To add to the confusion, the Haynes manual says to default to the spring side if not labeled. (I know I know don't trust haynes)
  16. Aug 5, 2022 at 11:38 AM
    choopes
    Troy, Al.
    2004 reg cab
    Stock
    I went ahead and put it in with the top picture I posted facing the pressure plate. Everything went fine. Torqued to 19f lbs. Looks like the 2RZ pic.
    I messaged Asian, where my clutch kit came from, but haven't heard back yet.
    If you find anything more definitive, please post here. i may be trying to put the tranny back in as early as in the morning. I don't know. Could be later. Thanks for the input.
    Jakuku Pahwheenis and Bivouac like this.
  17. Aug 5, 2022 at 1:07 PM
    Jakuku Pahwheenis
    J Phoenix
    South Carolina
    Im trying to install my transmission tomorrow too. We’ll see how it goes.
    choopes[QUOTED][OP] likes this.
  18. Aug 5, 2022 at 1:36 PM
    choopes
    Troy, Al.
    2004 reg cab
    Stock
    You're putting one in too! Awesome!
    It seems petty heavy to handle by ones self. I am going to try to get a helper.
  19. Aug 5, 2022 at 1:42 PM
    Jakuku Pahwheenis
    J Phoenix
    South Carolina
    I’m trying too in the regional forum, haven’t caught a bite yet.
  20. Aug 6, 2022 at 4:10 AM
    choopes
    Troy, Al.
    2004 reg cab
    Stock
    No word back from Asian yet. Likely won't until Monday. I am going to try to put the tranny in. i guess there is a 50-50 chance of getting it right. I hate gambling.
