2RZ died and won't restart.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tikibutt, Jul 25, 2025 at 4:55 PM.
  1. Jul 26, 2025 at 9:38 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The pcm could have already been damaged tho
    Im not saying throw a new one at it.. but its worth looking into
  2. Jul 26, 2025 at 9:59 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If the ECM isn't online. You pretty much need to check power and grounds to the ECM.
    If all powers and grounds checkout, Then try an ECM.
    I'll see what I can find on the ECM. But I'm going to be honest.
    It might take me some time to respond. And 1999 service info SUCKS. (at least what I have does).
    #1 question is, Do you have the means to test wire pins CORRECTLY on a connector?
    Jamming the leads of a meter into the connector is NOT doing it correctly. And often times leads to creating more issues.
    It's not rocket science, a needle, smaller wire, safety pin will do........
  3. Jul 26, 2025 at 10:07 AM
    Tikibutt
    Tikibutt [OP] Well-Known Member
    Rich
    Knoxville, TN
    2004 Tacoma 4x4
    JBA UCAs, Radflo Coilovers, Lockrite mechanical Locker, All-Pro Offroad Skid Plates, 4x Innovations Sliders, Dakar Rear Springs, 37x13.50r17 Cooper SST Pro on Beadlocks
    Yes, I have the means to check the pins on the plugs. I have previously completed a 3.4 swap on a 2nd gen T4R and did all the wiring and such. I had obtained wiring diagrams for both the donor and the recipient vehicles and spent months making sure things were connected correctly.
    I'm currently trying to find a diagram for this ECU.
  4. Jul 26, 2025 at 10:40 AM
    TnShooter
    Deogee
    STOCK
    I got you.....
    Give me a few
  5. Jul 26, 2025 at 11:00 AM
    Tikibutt
    Rich
    Knoxville, TN
    2004 Tacoma 4x4
    I forgot to mention....I deleted the cat about a year ago and have had a CEL for it. When this shit started, the CEL went away.
  6. Jul 26, 2025 at 11:08 AM
    TnShooter
    Deogee
    STOCK
    CEL will go out when the ECM is off line.
    Which we have pretty much established by the scan tool not communicationg.
    If you don't have the CEL on with Engine OFF and Key ON, There is an ECM or power/ground issue to/from the ECM.
    wilcam47 likes this.
  7. Jul 26, 2025 at 11:12 AM
    Tikibutt
    Rich
    Knoxville, TN
    2004 Tacoma 4x4
    I've found enough already to know that it is the white/red wire that provides power. And I do have 12.48 V to the ECM.
  8. Jul 26, 2025 at 11:16 AM
    Tikibutt
    Rich
    Knoxville, TN
    2004 Tacoma 4x4
    And i just check all the ground wires from the plugs to the truck for continuity and all checked out fine. This is starting to look like the ecu took a shit.
  9. Jul 26, 2025 at 11:21 AM
    TnShooter
    Deogee
    STOCK
    Quick glace gives we this at the ECM.
    See if it matches what you checked
    E5 plug = Power at the following pins: 1,2, 16
    1 = Black/Yellow wire
    2 = Black/Red wire
    16 = White/Red wire
    All Grounds look to be BROWN in color
    E7 Plug Pins: 8, 17 (grounds)
    E8 Plug Pins: 21, 30, 31 (grounds)
  10. Jul 26, 2025 at 11:21 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    On my 2.4 it would die, and pop the am2 fuse when pulling away from stop....after it warmed up.
    It was the ignition switch going out...
    that has to power up am1 and am2 branch to start engine
    make sure you're getting power down line on those....far side of the switch
    and by the way the scanner....any scanner will not connect to my ecm without the engine running.....its been that way for 10yrs
  11. Jul 26, 2025 at 11:22 AM
    Tikibutt
    Rich
    Knoxville, TN
    2004 Tacoma 4x4
    With the ecm unplugged, should I be able to check continuity from 12+ to ground? I know there will be a load, but I would think there would be continuity if all was good.
  12. Jul 26, 2025 at 11:34 AM
    Tikibutt
    Rich
    Knoxville, TN
    2004 Tacoma 4x4
    I've got 4 plugs. 1 has a white/red wire that has 12.4 V and it's pin 12. All my grounds are in this same plug. Pins 13, 24, 25, and 26.
  13. Jul 26, 2025 at 11:35 AM
    Tikibutt
    Rich
    Knoxville, TN
    2004 Tacoma 4x4
    Here's the plug with all the grounds.
  14. Jul 26, 2025 at 11:38 AM
    Tikibutt
    Rich
    Knoxville, TN
    2004 Tacoma 4x4
    Manufacturing date is 09/98. So this might have some hold over wiring from a 98.
    The ecm part number is 89661-04470
  15. Jul 26, 2025 at 12:11 PM
    #35
    Tikibutt
    Rich
    Knoxville, TN
    2004 Tacoma 4x4
    This is a non-Cali truck. These pin outs don't line up with what I have.
    TnShooter[QUOTED] likes this.
  16. Jul 26, 2025 at 12:11 PM
    #36
    TnShooter
    Deogee
    STOCK
    You should see 12v from the pin to a ground.
    You can not do a continuity check on the powers.
    You can on the ground.
    So, pins with power when cheeked to a ground will show 12v.
    Ground pins when checked to ground will show continuity.
    I personally like to use a test light.
    Clip the end of a test light to a ground. (KNOWN GOOD GROUD)
    Check pins that are supposed to have power, it should light up the test light.
    For grounds, clip the light to a power.
    Test ground wires, they should light up.
  17. Jul 26, 2025 at 12:12 PM
    #37
    TnShooter
    Deogee
    STOCK
    Ok....my fault....
    Let me grab the right ones.....
  18. Jul 26, 2025 at 12:19 PM
    #38
    TnShooter
    Deogee
    STOCK
    Powers are on plug E5
    Pins: 2, 12
    2 - Black/Yellow
    12 - White/Red
    Grounds are on E8 all BROWN wires
    Pins - 13, 24, 25, 26
  19. Jul 26, 2025 at 12:25 PM
    #39
    Tikibutt
    Rich
    Knoxville, TN
    2004 Tacoma 4x4
    I have no power on E5 2 or 12. 12 goes back to junction J12 which i have no idea where that is. Not traced 2 yet.
  20. Jul 26, 2025 at 12:27 PM
    #40
    TnShooter
    Deogee
    STOCK
    I have to ask.....
    The key was ON when you checked them, Right?
