2RZ-FE Cylinder 3 intermittent misfire
Discussion in '1st Gen. Tacomas (1995-2004)' started by YOTASTEVEO318, Sep 4, 2017.
  1. Sep 12, 2017 at 7:57 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Thats alot over the full level. Compression ok? The oil fill cap does it have any chocolate milk shake looking stuff on the bottom? Maybe gas flooded engine oil. Not good for bearings. You should change your oil ASAP.
    YOTASTEVEO318[OP] likes this.
  2. Sep 12, 2017 at 11:19 AM
    Glamisman
    Glamisman Well-Known Member
    The engine on modern cars is a sealed unit meaning that excess oil and vapor HAS to go somewhere. It is either in liquid form in the crankcase or a vapor in suspension in the crankcase or cylinder head. I bet that the excess oil vapor is being introduced in the intake manifold via the PCV valve and is being burned, or trying to be burned in the motor. Replace the PCV valve and lower the oil level and drive her and see what happenes.
    YOTASTEVEO318[OP] and Dalandser like this.
  3. Sep 13, 2017 at 2:25 AM
    YOTASTEVEO318
    YOTASTEVEO318 [OP] Active Member
    1995.5 4X4 Tacoma (1st Gen) and Long Travel 1996 Toyota Tacoma 2WD (1ST GEN)
    4WDTACO: New paintjob, 3 inch coil spacer lift 2WDTACO: Long Travel , modeled after Total chaos kit , possibly early total chaos kit strapped at 14" , fiberglass fenders all the way around , bilstien coilovers
    That's what I read somewhere else too . I'll take a look at it whenever I get a break from work lol. And the fluid I saw that day wasn't there when I first pulled the spark plug from that cylinder. Also relooked over the wires and they're still in good condition.
  4. Sep 13, 2017 at 12:16 PM
    wolfpackbd22
    wolfpackbd22 Well-Known Member
    Brandon
    I just got the P0304 code on my 2003 V6 (misfire in cylinder 4). I had the same symptoms. On a cold start every time I shifted it would hesitate and then smooth out. Once my engine was up to temp it ran fairly well though. I'm taking it to Toyota tomorrow and see what they say. My best guess they will replace my spark plugs and wires (which is what I'm hoping fixes it). Next step would be coils. I'll let you know how it goes
  5. Sep 13, 2017 at 2:03 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    What did you actually do to test that the wires are still good?
  6. Sep 14, 2017 at 1:25 AM
    YOTASTEVEO318
    I just looked them over when I pulled them out . Haven't had time to test them myself or anything.
  7. Sep 14, 2017 at 7:14 AM
    DrZ
    Mesa, AZ
    96 2.4L 5-speed
    You can't tell if the wires are good just by looking at them. You can measure resistance, but even if they are within specs a wire can still be bad.
  8. Sep 14, 2017 at 7:34 AM
    wolfpackbd22
    Brandon
    Update: Dropped my truck off at the dealership this morning and within an hour he called and said the spark plugs were crap and he is going to replace them and hopefully that will fix the misfire. If it's not that I'm fucked
