2RZ possible woes
Discussion in '1st Gen. Tacomas (1995-2004)' started by Idrivetoys, Jul 1, 2011.
  1. Jul 1, 2011 at 5:49 PM
    Idrivetoys
    Idrivetoys [OP] Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    I have a 1996 2WD ext cab 5 speed 2RZ,
    Just rolled 233k on my way back from Florida last night, went to change my oil and noticed after i backed it off the ramp a fan type black mark right where my exhaust would be pointed. so i had my wife come start the truck and right at startup it covers my hand in black liquid like powder stuff. doesnt really smell like oil, doesnt smell like fuel.
    It never did this prior to my trip, i would have known since my tip is about 4" from the wall in my garage when i park.
    The oil was still amber when drained to a certain extent, no chunks, no shavings, no grit. Solid mpg (avg 26 at 75-80mph) When i had my wife rev it a little, maybe to 3k it covered my hand more so than on start up.
    The only thing that really come to mind are seals leaking oil into the combustion chamber (which seems odd if i had full oil) and on top of that it doesnt smoke at all, ever. Any help is greatly appreciated.
  2. Jul 1, 2011 at 5:55 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2001 TRD Off-road Prerunner V6
    Icons, Konig Countersteers, BFG A/T's
    im totally inexperienced with this but maybe ur catalytic converter is bad? as far as i know it's supposed to gather "pollutants" and it seems that in ur case it's not doing so... just a guess though.
  3. Jul 1, 2011 at 6:09 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Sounds like carbon build up coming loose. It could be running a little rich or it might be from the long drive. How long has it been since you last changed your spark plugs?
    I'd give it a few days of "normal" driving and check again.
  4. Jul 1, 2011 at 7:19 PM
    Idrivetoys
    Yuma AZ
    I appreciate the quick replies,
    I will be doing some routine driving the next couple days to see if it goes away. Also i don't even have a cat. converter but i also have never had any of this before, so perhaps the drive did loosen up some nastiness
    the plugs were changed a few thousand miles ago
    Seeing as how it doesn't smell like anything at all really, im confident it will go away shortly, if not i know the muffler could also use a replacement, maybe its all nasty in there considering its the original
  5. Jul 2, 2011 at 9:14 AM
    Idrivetoys
    Yuma AZ
    Twenty Min of around town driving and no more nasty soot like exhaust stuff. Guess it was the no cat and 13 hour drive
