2rz timing chain tensioner
Discussion in '1st Gen. Tacomas (1995-2004)' started by paiamaui, Sep 22, 2019.
  1. Sep 22, 2019 at 8:23 PM
    paiamaui
    paiamaui [OP] New Member
    Marcus
    96 tacoma 2rz
    So I’ve been chasing this oil leak under my distributor and I found this metal plate under it and of course I didn’t know what it was so I loosened it up then I found out it was the timing chain tensioner. I tightened it back up and drove it around and when I came back there was oil everywhere. So I found the cause of my oil leak. Can I just take out the tensioner and replace it or so I have to take off the valve cover and timing cover ???
  2. Feb 2, 2024 at 4:23 PM
    CalderFH
    CalderFH Member
    1995.5 Tacoma Xtra Cab 2.4l 2rzfe
    ya, me too. were you able to remove, clean, and reseal the chain tensioner without pulling anything else?
  3. Feb 2, 2024 at 7:32 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    I’m interested as well
    I bought T tensioner during big job
    Zero slack in T chain…..so
    I returned the tensioner
    Just making sure paiamaui…..
    You replaced the distributor O-ring in search of your oil leak?
    During that ‘big job’ i eluded too, every gasket replaced including h20/oil pumps
    After 1st test drive…..
    had fresh oil seeping from high up on passenger side of block
    After distributor O-ring RR’d
    I was golden
  4. Feb 2, 2024 at 9:57 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  5. Feb 3, 2024 at 3:00 PM
    CalderFH
    CalderFH Member
    Pretty good vid, but he's got it tore open. I wanna know if I can just take off the two nuts securing the chain tensioner, clean up the mating surfaces, install a new gasket, and either replace or reuse the tensioner without getting into the head or timing cover.
