2rz timing mark
Discussion in '4 Cylinder' started by boostfed, Aug 1, 2011.
  1. Aug 1, 2011 at 8:08 PM
    boostfed
    boostfed [OP] Well-Known Member
    STOCK!
    hey all,
    i'm not sure if this is normal but the timing mark on my 2rz crank pulley has 2 marks, one on the forward face of the pulley, and the other on the rearward face of the pulley ( about 15 degrees apart of each other). Which mark should i use? i believe i saw in the fsm that the keyway should be facing upwards while at TDC and aligned to 0 , which would allow me to line the rearward facing timing mark on the pulley, does this sound correct? not sure if anyone else has run into this but i haven't seen anything yet. anyone?
  2. Aug 3, 2011 at 11:38 AM
    boostfed
    STOCK!
    Bump!!! Which timing mark do most align it to? The FSM doesnt specify for a 2rz. Is the mark usually on the lip facing the block? Or the lip facing the radiator?
  3. Aug 3, 2011 at 2:09 PM
    boostfed
    STOCK!
    here's a picture of where i have it now:
    and here's a picture of where the other timing mark is (circled):
  4. Aug 16, 2011 at 9:52 PM
    Us3r
    Us3r Reading...
    Socali
    98 Tacoma Std. 2RZ-FE 2WD
    Axle wrap mod (Shackled), 140 Amp Alternator & Wires, HID Headlights, Brush Guard Grille, Hella 550 Driving Lights. |Saving:Total Chaos.|
    I too am curious and am having a hard time finding a definite answer..
  5. Aug 16, 2011 at 10:01 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    its the white mark CLOSEST TO THE BLOCK. --NOT FACING THE RADIATOR. the mark right next to the timing degree numbers is the one u pay attention to.
  6. Aug 16, 2011 at 10:04 PM
    tacobo670
    Ray
    Las Vegas
    if anything u can always check TDC by removing #1 spark plug, put a long screw driver in the plug hole and turn the crank till u see it reach its apex and also watch the crank pulley mark to make sure its on TDC
