2rz to 3rz swap questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by Broke Okie Ty, Jan 31, 2025.
  1. Jan 31, 2025 at 5:29 PM
    Broke Okie Ty
    Broke Okie Ty [OP] Well-Known Member
    Ty
    California/Oregon/ Now in Montana
    01 trd with some stuff
    Armor, winch, other stuff
    I have a 2wd with a 2rz/auto that's locked up from sitting. I happened upon a wrecked 3rz/auto truck and I'm wondering if I can run the 3rz in place of the 2rz. The 2wd is a 96 xc and the 3rz is a 98. I am researching but I'm also trying to move on this thing as fast as possible, so I figured I'd post a thread. Also, I've never owned an rz motor so I'm not super familiar with them.
    My question is basically can I drop the 3rz in place of the 2rz?
    What kinda stuff might I run into?
  2. Jan 31, 2025 at 6:08 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    This is based on my limited knowledge of 1st gens and looking at service info/wiring diagrams/pinouts, there's people far more knowledgeable than me on the 1st gen platform that can likely give you a definite yes/no answer but from my research:
    Not that easy, you would basically need all the guts, harnesses, and ECM from the donor truck.
    2RZ uses a different transmission (A43D) which is fully mechanical aside from the electronic overdrive, the 3RZ uses the A340E transmission which is electronic.
    While the 2RZ ECM will likely run the 3RZ since they are wired nearly identical it probably won't run very well since fuel and timing tables would be calibrated for a 2.4L instead of a 2.7L, The ECMs won't be a plug and play interchange because the 96 2.4L has 3 connectors and the 98 2.7L has 4 connectors because of the electronic transmission.
    The only way I could see it being a drop in replacement would be if you could find a 96 3RZ ECM from a manual trans truck but those are getting to be pretty rare and expensive.
  3. Jan 31, 2025 at 6:41 PM
    Broke Okie Ty
    Ty
    I was afraid of that. I'm just trying to get something to drive. I guess if I had an extra cab 4x4 frame that would solve the problem.
  4. Jan 31, 2025 at 7:02 PM
    Broke Okie Ty
    Ty
    I would have the whole truck from the 3rz if that makes a difference
  5. Jan 31, 2025 at 7:14 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    As I said I'm not too well versed in 1st gens but from what I can gather you would essentially need to swap the whole drivetrain, associated wiring harnesses, ECM, and possibly other related components or find a 3RZ M/T ECM from another 96 to be able to just swap the engine.
    @Speedytech7 May have a better idea of what's involved.
  6. Jan 31, 2025 at 7:34 PM
    Broke Okie Ty
    Ty
    I was just putting it out there
  7. Jan 31, 2025 at 8:07 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    I have 98 that they just stuck in a 3rz out of 4runner.....
    it ran just fine with the stock 98 2rz ecm......no problemo....no wild fuel trims...sun rose the next day......
    it has the a43d tranny
    everything just bolted up the same.........at least auto to auto....
    Using replacement heads....which they all come with cam sensor drilled out now....
    most just use a dummy cam sensor to plug that hole....no problemo
    ....if used on pre 98's
    all new heads you have to plug the distributor port.....if you have 98 or later anyways
    so there should always be a dist port available
    toyota is some tough shit......you 'all dont give it enough credit.....
    big question is......is that a good engine to go thru all that
    many things to check 1st........like is there a distributor port on that 3rz
    head cracked....rings shot...ect...
    I suspect the later ecm(3rz) will not work with a43d as stated earlier......but it might...
  8. Jan 31, 2025 at 8:31 PM
    O'Silver_Taco
    MD
    You can also buy a reman short block with a warranty for around a grand....
    and a new head for less than a grand......with a warranty
  9. Jan 31, 2025 at 8:52 PM
    Broke Okie Ty
    Ty
    Ya but that's more than I got to get this thing going.
  10. Jan 31, 2025 at 8:54 PM
    Broke Okie Ty
    Ty
    The 3rz is good. The truck still drives even though it's smashed up. It seems like the easiest thing is to just find an extra cab 4x4 frame and put everything on that
  11. Feb 23, 2025 at 2:24 PM
    Dirty Dude
    Dirty Dude Well-Known Member
    2004 Tacoma SR5 Xtra cab 5-lug
    Dirt, miles, and wear.
    I've been looking at doing the same thing with my '04 and it sounds like you can swap just the engine without much issue. One thing that comes to mind is having to put the 2RZ oil pan and pickup on the 3RZ.
