2TR Build
Discussion in '2nd Gen. Builds (2005-2015)' started by cbass8u, Dec 13, 2015.
  1. Dec 13, 2015 at 6:36 PM
    cbass8u
    cbass8u [OP] Well-Known Member
    Pittsburgh, PA
    10 SR5 4-Banger Hand Shaker
    TRD Rims, Pioneer Touch Screen and speakers
    Hi guys. I'm toying with the idea of doing some pretty serious engine modification to my 2TR, such as port/polish head, get a custom grind from comp cams, oversize valves and maybe increasing the bore if getting oversize pistons machined isn't stupid money. I know "I can get more power easier with a V6", but I like my truck and don't feel that it's worth trading my truck for one. Plus a high power 2TR is pretty unique, at least to me. Anyone have experience with this kind of modification on these trucks?
  2. Dec 13, 2015 at 6:49 PM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
  3. Dec 13, 2015 at 6:54 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    URD supercharger or a turbo kit is gonna be the best bang for the buck.
  4. Dec 13, 2015 at 7:31 PM
    cbass8u
    Pittsburgh, PA
    I want to stay N/A for now, with eventual plans to boost it. Honestly I'm just curious to see what this engine is capable of.
  5. Dec 14, 2015 at 3:02 AM
    TacoTaco15
    TacoTaco15 Well-Known Member
    Jake
    VA
    2015 MGM DCSB PreRunner 2.7
    No idea, but subbed.
    :popcorn:
  6. Dec 14, 2015 at 4:20 AM
    pinchetaco
    pinchetaco Well-Known Member
    Winston Salem, NC
    06 Taco 6 inch ProComp Lift 35's
    6 inch ProComp Lift, 35s, ProComp Wheels, 4.88 gears, Debadged, BHLM, Dome Light Mod, Trailer Plug Relocated
    I'm sure that it's plenty capable NA. It all depends on how deep your pockets are. Give any engine more air and fuel and itll make more power. Idk if anyone has modded these engines, but it would be good. Stock heads might only be so capable tho.
  7. Dec 14, 2015 at 7:13 AM
    cbass8u
    Pittsburgh, PA
    Well, we will find out soon enough. I'm thinking of buying a whole engine out of a junk truck and going from there.
    pinchetaco likes this.
  8. Dec 14, 2015 at 9:28 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Do it!!!
  9. Dec 14, 2015 at 9:31 AM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    :popcorn:
    Nope, but I'm subbed!
  10. Dec 14, 2015 at 9:46 AM
    MikeCB600F
    MikeCB600F 4 Cylenders of angry fury
    Plainfield, IL.
    2012 Reg Cab 2.7L 4x4
    Extang Trifecta Tonneau cover
    LCE header
  11. Dec 14, 2015 at 1:46 PM
    cbass8u
    Pittsburgh, PA
    LCE header, URD fuel pump upgrade, MAF calibrator already done. Going to fab up a CAI since I think 300-400 dollars for a piece of bent exhaust tubing with a couple ports on it is just straight retarded. And a short throw as of a few days ago. I've been in contact with a machine shop and it seems relatively cheap to get the head worked over, although they're not sure about oversized valves. I'm almost terrified to call comp cams to get an estimate from them, but I'll do it tomorrow. Also going to have a local shop bend me a test pipe and a 2.5" cat back. Need to find a shop in Pittsburgh that will tune a Toyota too, which should be fun.
  12. Dec 14, 2015 at 3:58 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If the valves are the same dimensions between the 2TR and the 1GR, then SuperTech has them. You could even check right now, and they might have your engine's valves listed. I have not looked.
    For the 1GR, over-sized is the normal option. Regular sized is what they consider "custom." I have their valves in my stroker engine's heads.
    Ferrea also makes valves for the 1GR. You can check there as well. They offer the stock size, but they are still more expensive than the Super Tech brand.
  13. Dec 14, 2015 at 4:02 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    By the way, the bucket shims for the 2AZ-FE are the exact same as in the 1GR. I had to use one from one of my heads, to have the proper valve lash on the 2AZ head. By this information, it makes me feel like the valves, buckets, or more might also be the same for your engine... Possibly.
  14. Dec 14, 2015 at 4:15 PM
    cbass8u
    Pittsburgh, PA
    Worth looking into. Thank you.
  15. Dec 14, 2015 at 7:39 PM
    cbass8u
    Pittsburgh, PA
    One problem: can't find any info on stock valve size. If someone has that info I would be much obliged.
  16. Dec 14, 2015 at 9:07 PM
    MikeCB600F
    Plainfield, IL.
  17. Dec 14, 2015 at 9:11 PM
    Shepdog08
    Shepdog08 Well-Known Member
    265/70 R16 BF Goodrich A/T's Plasti-dipped factory wheels More to come...soon
    How would a custom cam grind work with VVTI?
  18. Dec 15, 2015 at 6:07 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It would have to be just subtle enough to not cause valve to piston interference under the various phase angles of the VVT actuation.
  19. Dec 15, 2015 at 6:11 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Either that or go the much more involved route of locking out VVT actuation, and have aggressive cams. Like me. :D
    Wheelspinner likes this.
  20. Dec 15, 2015 at 6:26 AM
    cbass8u
    Pittsburgh, PA
    I don't know that I'm quite ready to make that plunge yet lol. It's still my daily.
