2TR Build
Discussion in '2nd Gen. Builds (2005-2015)' started by cbass8u, Dec 13, 2015.
  1. Dec 23, 2015 at 11:51 AM
    #41
    cbass8u
    cbass8u [OP] Well-Known Member
    Pittsburgh, PA
    10 SR5 4-Banger Hand Shaker
    TRD Rims, Pioneer Touch Screen and speakers
    If I could afford it, I would invest in properties. For now, I've got a savings account and a truck that is begging for modification.
  2. Dec 23, 2015 at 12:02 PM
    #42
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Rods, pistons, then URD S/C kit. :D
  3. Dec 23, 2015 at 12:12 PM
    #43
    cbass8u
    Pittsburgh, PA
    I don't see a point in rods. I do have a forged bottom end from the factory if what I've read is correct. The only reason I want to replace the pistons is to increase the bore. S/C would be badass though once the engine work is done.
  4. Dec 23, 2015 at 12:16 PM
    #44
    TwzteD
    TwzteD Well-Known Member
    Kyle
    St Lucie Fl
    2013 4x4 reg cab Auto
    2013 4x4 reg cab, 2011 4runner sr5 rims, 265 general grabber at2's, 5100's All 4 corners with fronts at .85, De badged, Egr Rainguards, Led tail lights, Int wipers, fog lights, Trailer Hitch, POwer locks+ keyless entry, Extang Solidfold Bed Cover, WeatherTech Mats, Stubbie Antenna, Trd Skid Plate, Tint, Scanguage, Cargo net in bed, Sound Ordnance B-8PT, FULID FILM Under Coat.
    if you plan on buying a new motor, who not drop a 2jz into it?
  5. Dec 23, 2015 at 5:26 PM
    #45
    cbass8u
    Pittsburgh, PA
    Don't you think that would be a bit of a nightmare?
  6. Dec 23, 2015 at 7:14 PM
    #46
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Weigh all of your options of what you want to do. Then execute the plan.
    Ask the questions of the technical aspects as you think of them or they come into play.
  7. Dec 23, 2015 at 7:30 PM
    #47
    Taco Nation
    Taco Nation Well-Known Member
    Zack
    Clinton, MS
    94.5 F350, 77 F150, 74 F100, 11 Jeep Grand Cherokee
    Lift, wheels, tires
    Why not do a 2UZ-FE swap
  8. Dec 24, 2015 at 11:34 AM
    #48
    cbass8u
    Pittsburgh, PA
    It would be cool, but again, a bit of a nightmare.
  9. Dec 24, 2015 at 11:56 AM
    #49
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Do you have any specific plans of what you want to be as the end goal for the truck as a whole, or right now just focused on the power plant at this point?
  10. Dec 24, 2015 at 12:02 PM
    #50
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    Something like this I bet!
    skiergd011013, 45acp and Taco Nation like this.
  11. Dec 24, 2015 at 1:45 PM
    #51
    cbass8u
    Pittsburgh, PA
    Just kinda focused on clarksoning. I'd like a truck that can pull on a corvette but I'm pretty sure that won't happen unless it's one of the 180 horse vettes from the late 70's.
    Torspd likes this.
  12. Jan 30, 2016 at 7:48 AM
    #52
    cbass8u
    Pittsburgh, PA
    Sorry for the lack of updates guys, work is running me into the ground. I purchased a head off of a wrecked truck, waiting to get with the machine shop and have it worked.
  13. Jan 30, 2016 at 7:53 AM
    #53
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
  14. Jan 30, 2016 at 8:14 AM
    #54
    cbass8u
    Pittsburgh, PA
    Don't want to go boosted yet.
  15. Jan 30, 2016 at 8:26 AM
    #55
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Go big or go home.
  16. Jan 30, 2016 at 8:33 AM
    #56
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Have you looked into if there are any dimensional commonalities between it and its 3RZ predecessor? I have 2mm over-sized stainless and inconel valves from LCE and they also did the machining mods to the head for the stage 5 valve train. The port/polish is pretty easy to do on your own, albeit time consuming.
    I still have the stock 3rz valve train components sitting in a box if you need any measurements.
  17. Jan 30, 2016 at 10:59 AM
    #57
    billybob50
    billybob50 Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
  18. Jan 30, 2016 at 12:02 PM
    #58
    cbass8u
    Pittsburgh, PA
    I haven't looked into any of the 3RZ ancestry, but it could yield some benefit for sure. I'll look into it when I get a chance. Also, I'm not sure how well that kit would work. "Runs fine on stock ECU with no tune" sounds a bit fishy for any form of forced induction.
    toytaco2007 likes this.
  19. Jan 30, 2016 at 1:36 PM
    #59
    jtm2358
    jtm2358 Well-Known Member
    2015 White Tacoma access cab
  20. Jan 30, 2016 at 4:30 PM
    #60
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I don't see why. At 5psi I don't think ping would be that much of an issue :notsure:
    Either way, from what I've read, you want a unicorn. Can't get the gains you are looking for without forced induction.
