2tr-fe all coils code, low voltage at coil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rola2010, May 15, 2025.
  1. May 15, 2025 at 3:48 PM
    Rola2010
    Rola2010 [OP] Well-Known Member
    Honolulu, HI
    2010 Tacoma 2wd base RC
    I’ve seen similar threads and the recommended diagnostics but haven’t been able to figure out my issue. Admittedly my searching abilities are limited by my lack of expertise.
    My truck: 2010, 2tr-fe, manual, 95kmi.
    Issue: cranks but doesn’t start. Has fuel to throttle body, relays and fuses look good, battery good. Checked cam and crank sensors and ohms in spec. Showing codes P0351-354; did DM93's diagnostic
    (https://www.tacomaworld.com/threads/2nd-gen-information-diagnostics.784008/#post-28042157) with the exception of the J12 connector. What’s weird is the power at pin 1 of the coil mostly shows 0.5v but once did show 12v, then went back to 0.5v after cranking. Truck ran fine when parked a couple days ago (no misfire, rough idle, or stumbling) but hasn’t started since.
    Possibly unrelated: I have an electric fan controller that may have shorted out on that last drive home a couple of days ago (mid-wire connector of main power wire is black and bubbled right where it rests near the aft post of battery hold down bracket). Prev owner also had a bypass wire that is connected at pin 4 of EA1 which is ignition on (so fan runs once key is turned), but voltage at that bypass wire (which should be battery voltage) is also showing around 0.5v.
    I feel like there is a short someplace, but I don’t know where to look. Any help?
  2. May 15, 2025 at 4:09 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    So you have no power at the coils or Connector EA1 Pin 4 (Black/Red)?
  3. May 15, 2025 at 4:30 PM
    Rola2010
    Honolulu, HI
    Yes, no power.
  4. May 15, 2025 at 4:39 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Check your AM2 fuse (30A) in the underhood fuse box, if it's good then go to the ignition switch and check for power in on Pin 5 (White/Red) and power out on Pin 6 (Black/Red) with the key in the run position.
  5. May 15, 2025 at 5:13 PM
    Rola2010
    Honolulu, HI
    AM2 fuse good, pin 5 (off white/red) showing 12.39v, ignition switch on, pin 6 (blk/red) showing 0 volts.
    Harness is unplugged to check for pin 5 and 6, is that ok?
  6. May 15, 2025 at 5:16 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    No you need it plugged in and then backprobe it with a needle or other suitable tool.
  7. May 15, 2025 at 5:26 PM
    Rola2010
    Honolulu, HI
    Got it, backprobed and pin 6 showing 12.26v. Pin 5 showing similar volts.
  8. May 15, 2025 at 5:31 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Still nothing at EA1 Pin 4?
  9. May 15, 2025 at 5:35 PM
    Rola2010
    Honolulu, HI
    Yes, nothing at EA1 pin 4(0.48v).
  10. May 15, 2025 at 5:52 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    So you need to check it at Connector 1B on the Drivers Side Junction Box Pin 9 (Black/Red) (in) and Pin 10 (Black/Red) (out).
  11. May 15, 2025 at 6:08 PM
    Rola2010
    Honolulu, HI
    Both showing 12v with ignition in on position.
    thank you for all the help, by the way
  12. May 15, 2025 at 6:12 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    So if you have it there and not at EA1 then it has to be broken between there and EA1 or the pin in EA1 is bad, there are no other intermediate connectors.
  13. May 15, 2025 at 6:27 PM
    Rola2010
    Honolulu, HI
    So I pulled the harness at EA1 and tested voltage at 4 pin itself - shows 12v. With harness in and backprobed at pin 4, shows 0.5v. So it’s the harness then, yes? What’s the best way to fix it?
  14. May 15, 2025 at 6:29 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    So you have power on one side of the connector but not on the other with it plugged in?
  15. May 15, 2025 at 6:40 PM
    Rola2010
    Honolulu, HI
    Correct. I’m not sure if it’s just that wire (since it’s been spliced in) or if it’s the whole harness. Can I safely run t he same check on other pins in that harness?
  16. May 15, 2025 at 6:46 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Got any pics of what your talking about where it's spliced and the connector?
    What do you mean?
  17. May 15, 2025 at 6:53 PM
    Rola2010
    Honolulu, HI
    Here’s the “splice”:
    Regarding testing, i was wondering if I could do the backprobe on another pin in the EA1 harness (and which one) to check if it’s just pin 4 that has wonky connection.
  18. May 15, 2025 at 6:54 PM
    Rola2010
    Honolulu, HI
    It looks like they crimped the green wire to the blk/red wire in pin 4.
  19. May 15, 2025 at 7:00 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Eww, I'd get rid of that. It's fine to use an ignition source to turn a relay on to power a load but you really don't want to add anything that draws more than about 3 amps to factory wiring.
    What does the inside of the connector look like?
    I mean you can but they are gona be different circuits so probably won't tell you much, you could check Pin 7 (Black/Red) it's a different set of wires but it's coming from the same source.
  20. May 15, 2025 at 7:07 PM
    Rola2010
    Honolulu, HI
    it’s pretty clean I think. Just that outside crimp is really crusty. I’ll get to work on removing it. Once power can make its way back thru that pin, will everything work again?
