2TR-FE auto transmission
Discussion in '4 Cylinder' started by BenMara, Aug 6, 2014.
  1. Aug 6, 2014 at 7:50 PM
    BenMara
    BenMara [OP] That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
  2. Aug 6, 2014 at 10:09 PM
    Pool Runner
    Pool Runner Well-Known Member
    Nor Cal
    '14,TRD/OR, Entune & Nav '13 Subaru Outback
    Lowes Slimline Tool box, OEM Bug shield.
    The gearing in my 4SPD, 2TR-FE is a pit to tall for my liking, but it does well enough. It might be better in a much lighter buggy. But I think I would rather adapt a 5/spd manual if that's even possible.
  3. Aug 7, 2014 at 11:43 AM
    Fordless
    Fordless Well-Known Member
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    The 2TR 4x4 equipped trucks come with a A340F which is about as tough as 20 penny nails. Although the LandCruiser (pre-V8) comes with a A343F which may have more suitable gearing for your needs. The A343F should be about as tough as railroad spikes. Both "should" have the same bellhousing bolt pattern. The more modern version of the A340 is controlled by a trans control module. I'm not sure about the A343F, but I think it was controlled by the ECU so that *might* put you trying to find an independent trans controller for the A343 if you go that route.
  4. Aug 23, 2014 at 1:30 PM
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    not finding any concrete info, a call to marlin is in order
  5. Sep 8, 2020 at 10:28 PM
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    Trying to revive this thread.... Didnt get any answers from LC or MC.....
  6. Sep 9, 2020 at 3:43 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I did some research on the A340E (in my 2006 base) and learned that it's also used in more demanding applications including the Supra, Lexus SC 400 (V8), 4Runner and Tundra (V6/V8). So I assume it is plenty stout enough for the 2.7 even if your buggy has some upgrades. https://en.wikipedia.org/wiki/Toyota_A_transmission#A340E_(30-40LE)
    BenMara[OP] likes this.
  7. Sep 11, 2020 at 10:06 PM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    Out of curiosity, do you have the motor already? If not, 3rz might be a better choice, especially if you ever decide to boost it for your buggy, plus you’ll solve your adapter plate issue
  8. Sep 11, 2020 at 10:50 PM
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    Nope still in planning/research phase. Why a 3rz over a 2tr-fe? Isnt that going backwards.
  9. Sep 11, 2020 at 11:25 PM
    Sep1911
    2016 Taco
    Primarily because you’ll be able to use this as an adapter plate.
    https://www.lceperformance.com/Transmission-Adapter-Plate-Kit-2RZ-3RZ-To-Chevy-T-p/1033034.htm
    3rz engine management will also be a little easier to deal with, depending on which route you’re going.
    the difference in power between the 2tr and 3rz is 10hp. Though power curves will differ and probably put the 2tr in the lead since it has variable valve timing.
    3rz boost options are quite a bit more abundant as far as off the shelf kits are concerned and cheaper. If you plan on pumping more juice out of it eventually.
  10. Sep 11, 2020 at 11:28 PM
    Running Board Man
    Running Board Man Well-Known Member
    Use the a340 trans out of 95-02 trucks they sell controllers for them and are pretty bulletproof in my experience
  11. Sep 11, 2020 at 11:29 PM
    Running Board Man
    It is, just simpler and they make swap harnesses and aftermarket cams etc. for what you're doing
    The 3rz and 2trfe share the same bottom end btw
  12. Sep 29, 2020 at 11:32 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I have an A340F for sale if you are interested.
