2Tr-fe cam kit
Discussion in 'Performance and Tuning' started by weldertaco, Mar 18, 2015.
  1. Aug 10, 2017 at 12:28 AM
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    I would love to see a 500hp supercharged 2tr. I went typical Turbo, but an Atypical approach. Also, check out my build. Some LCE 3rz parts like the balance shaft delete kit works on our motor too.
  2. Aug 10, 2017 at 5:08 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Dude?! Quite being stingy, and post up a dyno!
  3. Aug 10, 2017 at 4:57 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Holy moly! Which Rotrex supercharger are you running? The one that comes with URD's kit or a bigger one? My plan is to go FI next year after I finish my suspension upgrades. I'm debating URD SC or custom turbo setup. I'd like to see 3-400 whp when it's all said and done. Playing with the Borg-Warner turbo match tool, it looks like I can get in that ballpark with around 17 psi.
    BassAckwards, dcvt16 and Torspd like this.
  4. Aug 16, 2017 at 6:33 PM
    dcvt16
    dcvt16 Well-Known Member
    Ehren
    SCV, CA
    SOLD =( MGM Supercharged long travel 5lug
    Total Chaos 5 lug long travel kit, Fox coilovers. Mcneil fiberglass. Defined engineering sua, 14 in kings, Defined shock hoops rear. Weathertech digital liners and vent visors. Paint match grille and added fogs. 4.56 gears, detriot truetrac LSD (gear type), LCE header, URD 2TR supercharger.
    I'm really interested in hearing about the 300+ whp urd setup. What engine management?
    MrCrowntown likes this.
  5. Jul 7, 2018 at 12:24 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    :popcorn:
    Depoxy likes this.
  6. Sep 16, 2018 at 8:06 AM
    Boosted4
    Boosted4 Member
    Chad
    2011 tacoma 2.7
    URD supercharger l, header and exhaust, storage 3 clutch
    So is there any new news on a the cams?
  7. Sep 16, 2018 at 8:17 AM
    Boosted4
    Boosted4 Member
    Chad
    2011 tacoma 2.7
    Im running the only supercharger kit for the 2tr, 70mm pulley instead of the 85mm with bigger injectors. Pushes a little over 20lbs. Cai and Thorley Header and pretty much straight piped. Dual electric fans, Stage 3 Clutch from Action clutch.
    BassAckwards, Torspd and buyobuyo like this.
  8. Sep 16, 2018 at 8:19 AM
    Boosted4
    Boosted4 Member
    Chad
    2011 tacoma 2.7
    Anyone know of anyone thats proficient in tunning the 2tr with the urd supercharger kit.
  9. Sep 16, 2018 at 8:51 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Annnndddd what's the HP lol
  10. Sep 17, 2018 at 9:33 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    My friend has a 70mm waiting to go on. With the 80mm his peaks at 11- nearly 12 psi. Already to risky for his to go to the 70, as larger primaries are absolutely required. His does have an larger 5th.
    The Map-ECU3 is fairly easy to tune, however overly annoying to get the program installed and communicating properly without erasing your tune file. If you are past that, it will be easy for you to modify the fuel tables, as long as the AFR module is also wired in, so that you can tune the larger injectors.
    On that note, what size primaries are you using?
  11. Sep 17, 2018 at 9:33 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  12. Sep 20, 2018 at 5:29 AM
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    @Torspd Have you guys measured the diameter of the 2TR crank pulley? I was looking at the compressor maps on rotrex's website but didn't have the diameter to figure out pressure ratio / compressor RPM.
    BassAckwards likes this.
  13. Sep 20, 2018 at 5:51 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    We have not actually.
  14. Sep 20, 2018 at 5:57 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    Just supercharge it.
  15. Sep 20, 2018 at 6:09 AM
    #35
    weldertaco
    weldertaco [OP] Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
    I don’t even own that truck anymore lol
    Torspd likes this.
  16. Sep 20, 2018 at 4:46 PM
    #36
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    Okay. Thanks. If I ever get my truck back, I'll look into measuring it.
    BassAckwards and Torspd[QUOTED] like this.
  17. Nov 13, 2019 at 9:53 AM
    #37
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Any updates on this sir? I was trying to figure this out just this morning to determine the smallest pulley i can go with on the c30-94 without going past the 10.5K rpm maximum.
    Anyone have info on the size of the 2TR crank pulley?
  18. Nov 13, 2019 at 12:02 PM
    #38
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Should be a quick measurement to take, right?
  19. Nov 13, 2019 at 12:04 PM
    #39
    BassAckwards
    Yes should be straight forward, i just didnt feel like laying down in the cold to take it if someone already has it :D
    I will break out the digital caliper this weekend if we dont get an answer by then..
    Torspd[QUOTED] likes this.
  20. Nov 13, 2019 at 5:49 PM
    #40
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    Should be, but it requires removing skid plates and I just haven't done it. When I originally asked, I was thinking that maybe you had measured the pulley on your neighbor/friend's truck that you helped install the URD kit on.
