2TR-FE Intake manifold spacer kit! Sold out!
Discussion in '4 Cylinder' started by tjhall36, Feb 23, 2018.
  1. Mar 13, 2018 at 4:04 PM
    #181
    dillonk1602
    dillonk1602 Well-Known Member
    dillon
    san diego
    tacoma 5 lug
    Vehicle Modifications: TACOMA 2007 FRONT TOTAL CHAOS 5LUG ,LONG TRAVEL KIT 13" OF TRAVEL KING COIL OVER (550 POUND SPRING RATE) (18 INCH COIL) REAR BED CAGE 16" SMOOTH BODY FOX SHOCKS 2.5 2.0 / 2.5 BUMP STOPS FOX ICON ADD LEAF PACK WITH OEM SPRING 11" OF TRAVEL TRUCK COMES SPRING UNDER BY MANUFACTURE TOYOTA REGEAR TO 4.0 WITH AUBURN UNIT ENGINE 2TR-FE WITH AFE COLD AIR IN TAKE DOUG THORLEY HEADER MAGNAFLOW EXHAUST TIRE S NEW KO2 32/11.5 METHOD RIM 15" WITH -20MM OFF SET
  2. Mar 13, 2018 at 4:08 PM
    #182
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
  3. Mar 13, 2018 at 4:11 PM
    #183
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    What does that gas pedal thing even do?
  4. Mar 13, 2018 at 4:14 PM
    #184
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
    Pedal Commander is a throttle response controller that removes response delays on any vehicle with an electronic gas pedal (most vehicles made after 2005). This is achieved by amplifying the signal being sent from the sensor on your gas pedal to the vehicle's ECU (computer). Today’s newer vehicles lack the responsiveness that came with older throttle cables. It doesn’t matter how fast you push your gas pedal to the floor, you don’t have access to all the power your vehicle has to offer. We are your solution!
    One of our most frequently asked questions is “how much horsepower does it add?” Pedal Commander doesn’t add any horsepower, but it does let you use the existing horsepower of your engine by allowing you to access it quicker with the amplified signal.
    This performance increase cannot be achieved with your typical aftermarket tune or programmer. Pedal Commander is the only device that lets YOU choose how you want your throttle to respond and change it on the fly. There are 4 different modes, with 9 sensitivity levels for each mode. This gives you a total of 36 levels of response to choose from, ensuring there is something for every driver in every vehicle.
    While there may not be anything else out there like it, Pedal Commander is completely compatible with any other aftermarket parts you may already have. And since we don’t use the OBDII port, this means it’s a perfect match to compliment your existing tune or programmer to maximize your driving experience.
  5. Mar 13, 2018 at 4:17 PM
    #185
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
    got mine at offroadwarehouse $250
    tjhall36[OP] likes this.
  6. Mar 13, 2018 at 4:19 PM
    #186
    McDangle
    McDangle Known Booper
    Mc Dangle
    33" 07 5 Lug
    All of Themz
  7. Mar 13, 2018 at 4:22 PM
    #187
    tjhall36
    tjhall36 [OP] Well-Known Member
    Travis
    Anywhere we park it, USA
    No worries man, just let me know and I'll see where we're at with them.
  8. Mar 13, 2018 at 4:23 PM
    #188
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
    last weekend i went out to oc wells and man it helped out alot in the dirt.Plus it help my truck on the freeway keeps it in gear vs shifting all the time making the truck work less and keeping its rpms in place vs lugging all the damm time and it does change the shift point to as well
    you just need to buy one really and mess with it, i keep mine in city+3 and off road put it in sport
    SamGoingHam and tjhall36[OP] like this.
  9. Mar 13, 2018 at 5:02 PM
    #189
    Nomad_Pilot
    Clay
    Ft Collins
    Man the list just keeps grown for the stuff I have to do to my truck when I get back from down under.
  10. Mar 13, 2018 at 6:48 PM
    #190
    Early B.
    Early B. Well-Known Member
    Brad
    metro Atlanta
    2014 2.7L, 5 lug Tacoma
    18" tires and rims, 2.75" Procomp lift, Fox shocks in rear.
    Just grabbed one, as well...
    dillonk1602 likes this.
  11. Mar 13, 2018 at 6:50 PM
    #191
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
  12. Mar 13, 2018 at 6:53 PM
    #192
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
  13. Mar 13, 2018 at 6:56 PM
    #193
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    Sub'd! Will read tomorrow!
    tjhall36[OP] and Bocsy44[QUOTED] like this.
  14. Mar 13, 2018 at 7:57 PM
    #194
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    In for a Penny, in for a Pound, as the Brit's say.
    Thankfully, i'm at the end-run of wants and needs. This merely compliments what now already exists.
    Maybe a $250 final piece of the puzzle, will stave away temptation to something else, much more ambitious and expensive.
    @tjhall36 switch me up to firm.. i'm in.
    dillonk1602 and tjhall36[OP] like this.
  15. Mar 14, 2018 at 8:11 AM
    #195
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
    here u go
    SamGoingHam likes this.
  16. Mar 15, 2018 at 2:19 PM
    #196
    Fleischwagen
    Fleischwagen 2.7 > 3.5
    North Jersey
    2017 SR 5MT 4X4
    5.29's, ARB locker, 6112/5100, Deaver AAL, LCE Header, aFe dry-flo filter, Hurst/Core shifter, CBI T3 Front, Warn Winch, CB/UHF Radio equipment, Backrack, KC fogs and spots
    My bad I've been missing for the past 2 weeks, hah do you still need those pictures of the 2.7 manifold?
  17. Mar 15, 2018 at 2:48 PM
    #197
    tjhall36
    Travis
    Wow! I had to really think about this one, it's been awhile!! Lol No, I don't need the pics. The engine is the same except the exhaust valves are variable now (changed in 2015), like the intake valves. I personally don't think that adding a spacer will hurt anything at all.
  18. Mar 16, 2018 at 9:25 AM
    #198
    McDangle
    Mc Dangle
    33" 07 5 Lug
    All of Themz
    good man
  19. Mar 16, 2018 at 6:01 PM
    #199
    SamGoingHam
    SamGoingHam IG: SamGoingHam
    Sam
    Phoenix, Arizona
    2014 TACO 5LUG LOCKED
    Any updates? I'm having Mod-withdrawls.
    tcBob, tjhall36[OP] and 05Taco4x4 like this.
  20. Mar 16, 2018 at 6:12 PM
    #200
    tjhall36
    Travis
    Lol Not really. I am waiting to hear from the machine shop as to when we can make the spacers. I hope to have an update Sunday. That's the only downside, it has to be done during down time. Once he gets some time though, I'm hoping he'll be able to run all of them at once. Regardless, we will get them all ran ASAP, no worries.
    Also, these spacers WILL definitely be available. The program is made and the machine shop owner is on board and aware there are approximately 20 people interested in purchasing the spacers currently. We just have to be a little patient with him as he has much bigger orders on the table he has to fulfill also. I'm guessing it shouldn't be more than a couple weeks, and I will definitely keep everyone posted. Feel free to contact me if you have any questions at all.
