2TR-FE low idle after steep descent in 4L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by andrew61987, Apr 30, 2016.
  1. May 3, 2016 at 8:43 AM
    andrew61987
    andrew61987 [OP] Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    I have had this experience as well, stalling out on super steep climbs that are too steep for the truck to climb and I start sliding back or start spinning the tires then stall out.
    It gets really pissed when I stall and creep backwards a bit in a forward gear, thus forcing the engine to rotate in the wrong direction. I've done that a couple times and it was real cranky for a minute or two.
    As long as nobody is reporting any serious issues with this it doesn't bother me. No codes and it always seems to go back to normal. A reason would be nice for my satisfaction but oh well.
  2. May 3, 2016 at 9:40 AM
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    There have been no long term issues that I have noticed.... hell at 206k km the oil is still clear lol
  3. May 3, 2016 at 10:20 AM
    andrew61987
    Ouch, wish i could say the same! 145k mi and my oil comes out on the darker side. Hopefully my 4 banger still has lots of life.
  4. May 3, 2016 at 7:02 PM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    These drive by wire systems can be wonky.sometimes. Mine has idle issues after descending mountains in WV and VA when keeping the gearing in 3rd or 4th for miles downhill. Also have issues with high revs between shifts, but it all goes away after driving normally for a bit, or after shutting the engine down for a few minutes.
    Edit- I have no idea why everything is underlined.
  5. May 3, 2016 at 7:50 PM
    andrew61987
    Do you ever notice sometimes when driving along in 4 low in 3rd or 4th gear on mostly flat ground that it feel like the truck closed the throttle slightly on you without you moving your foot? I swear it does this all the time, feels like I lifted my foot slightly but I know I didn't.
  6. Oct 1, 2019 at 9:31 PM
    andrew61987
    Gonna throw this back to the top just for the hell of it. My truck still does this. Not really any change except it's now stalled once on me before going back to normal behavior.
  7. Oct 1, 2019 at 9:57 PM
    andrew61987
    It's not like it only does it *while* I'm descending. Descending triggers it, and it will continue to act this way for several miles following, even if those are normal and level miles in 2HI.
