2TR-FE oil consumption issues
Discussion in '4 Cylinder' started by TYetti, Oct 23, 2018.
  1. Oct 24, 2018 at 4:12 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Yeah isn't that close if you convert the math?
    On the up and up, you never have to change the oil any more, just keep adding and changing the filter every now and then
    12TRDTacoma likes this.
  2. Oct 24, 2018 at 4:16 PM
    TYetti
    TYetti [OP] 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    My figures are in km not miles so she eats a quart every 987 miles
  3. Oct 24, 2018 at 4:21 PM
    TYetti
    Mat
    For example my last trip was 5000 miles loosing a quart every 987 miles I'd have lost 5quarts before the trip was over, I could hear the valve train after 4.4 if I didn't have oil with me well you get it. This is progressively getting worse like I said started with 1 quart over 5k miles, babytaco experienced this as well although his HG went to complicate matters. I don't see it being a liveable situation
  4. Oct 24, 2018 at 4:33 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Subbed. My 2.7 has 245k miles and burns about a quart every 3k. Curious what could be the root cause of this
  5. Oct 24, 2018 at 6:25 PM
    TYetti
    Mat
    Rings I mean every truck is different, but if it mysteriously disappeared and isn't coming out the exhaust is say it's the ring issue
    BassAckwards[QUOTED] likes this.
  6. Oct 24, 2018 at 6:35 PM
    BassAckwards
    Ill do a compression test on it this weekend.. i saw yours were all 160psi, do you know what the upper and lower limits are? And is it like the 4.0 v6 where there needs to be less than 15psi difference between cylinders?
  7. Oct 24, 2018 at 8:30 PM
    TYetti
    Mat
    10 psi difference upper tolerance is 170, the kicker is even though compression is on the money it's still consuming oil. Getting a snake cam into the spark plug tubes will reveal more, my pistons look like they've been in an engine that's never had an oil change even though I'm meticulous with my maintenance because I run the truck hard in the bush.
  8. Nov 3, 2018 at 7:51 PM
    TYetti
    Mat
    Just to update this for those who arent following my build. I took the truck by a trusted friends shop we consulted his engine builder, who knew exactly what we were describing before we finished explaining it. He ran a few tests and confirmed it's what I thought about the oil control ring. He's rebuilt 5 although mine has the least amount of kms of the ones he's rebuilt. Friggen 35s eh... Anyways I'm proceeding with a full rebuild
    MY50cal and T4RFTMFW like this.
  9. Nov 4, 2018 at 4:49 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Why not just carry an extra gallon (super mega liter for the canadians) of oil with you. Might also try running some marvel mystery oil or a quart of atf if you think the oil ring is gunked up. If your considering a rebuild I really doubt it would hurt anything your not already considering getting replaced.
    If it were me I would get a pullout motor to go in instead of a rebuild
    12TRDTacoma, 5 Lug Fury and TireFire like this.
  10. Jun 9, 2020 at 2:48 PM
    MrsPib
    MrsPib Well-Known Member
    Angie
    Texas
    TOYOTAS, TOYOTAS EVERYWHERE
    I hear you, Yetti. I just passed my 2qt/300-mile bench mark, and I'm on the phone with LKQ for a replacement. When I first got the truck, it was 1qt/1,500-miles, and as it turns out.....it refused to fix it's self. Rude!
    Tried all different oil types and viscosities to try to slow it down. The truck hated all of it.
    Now, mine does blow smoke, and the valves have been bent prior, so my top end is likely trashed in addition to the cylinders having issues. All of it's symptoms are pointing me towards just starting over with a lighter-used block instead of pecking away at valve seals, rings, honing, 'whoops, there goes the bottom end now', etc.
  11. Jun 9, 2020 at 3:15 PM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    The 2TR community is rather small, and I'm sure many people myself included would be interested in seeing your pistons and rings should you go through a rebuilt. I dont mean this as an insult, but we'd love to see the pics to see if this is caused by neglect of maintenance or if it's just a result of Toyota amongst other manufacturers switching to lighter tension rings for emissions/MPG gains.
    AxisCab, MY50cal and BassAckwards like this.
  12. Jun 9, 2020 at 4:53 PM
    BassAckwards
    I am getting ready to pull and replace mine and I'm gonna have the old one rebuilt. I will post pics of mine when that happens. I change my oil every 3-5k with full synthetic and have done maintenance meticulously. Mine drinks about a quart every 3k but the head gasket is starting to go at 268k which is the reason for replacing it
    I'm definitely interested in seeing other 2TRs as well though. Seems like this is a common issue
    EdgemanVA likes this.
  13. Jun 9, 2020 at 5:09 PM
    Sep1911
    2016 Taco
    Thats a little disappointing to hear. Sounds like this is a wear issue after all. With modern synthetics being as good as they are my bet is that your rings will be clean, though we'll know for sure once you take it apart. I was hoping I wouldnt have to deal with oil consumption since I've been using synthetic oil every 5k since I bought the truck new. Definitely keep us posted! Are you rebuilding it your self or having a shop do all the disassembly/assembly?
  14. Jun 9, 2020 at 6:33 PM
    BassAckwards
    I agree, definitely disappointing, I wanted to see 300k out of this motor, but the oil consumption issue would have probably gotten much worse by then. I am more than likely going to take my long block to LCE and have them rebuild it with upgraded internals, but I have been considering taking things apart and trying to learn something before sending it off so if I do that I'll take lots of pictures
  15. Jun 10, 2020 at 6:08 PM
    #35
    TYetti
    Mat
    So I'm around 20k km deep into the rebuilt engine it's been back in the truck for a year now. My block was bored 5tho over I got in contact with cp who make the pistons for lce went with the forged Teflon ones and Hastings race rings. Everything else is oem Toyota and new. I was able to pour oil out of my cats so I deleted them. Got a urd sim to correct the signal for the rear o2, also lce header and flowmaster delta 50 muffler
  16. Jun 10, 2020 at 6:40 PM
    #36
    BassAckwards
    Thanks for the info man, I appreciate it. I was wondering what rings to go with. What compression ratio did you go with on the pistons?
    I also running the LCE header, deleted my cats. I was worried about clogging mine up. I've got the stock catback still, it's pretty quiet still surprisingly.
    Did you do any other upgrades like the balance shaft delete or bigger valves?
  17. Jun 10, 2020 at 6:45 PM
    #37
    TYetti
    Mat
    Stock compression. Obviously it's slightly higher being over bored, but I didn't wanna bump it as I was thinking boost, but now I have other things I'm working on. I went straight oem spec on everything as I was happy with the engine the rings just said no more
  18. Jun 15, 2020 at 7:21 PM
    #38
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    i have NO info for Used vehicles
    the correct considerations are obliterated by the use/misuse of prev owners
    their beliefs & practices .............................
    i buy New
    i keep any & ALL my vehicles several 100k miles
    ive Never lost an engine
    ive Never had excessive oil consumption
    i race several different type engines
    ive looked into many really good hi-performance engines
    tho that rule o thumb does NOT exactly translate directly to street engines
    i would suggest buy the best synth oil best suited to the type o driving U do
    daily commute stop-go many cycles start go
    is a totally diferent creature than hi-way at legal speeds
    no less vastly diff than consistent towing
    i find that very few are truthful/factual
    brand new fleet diesels designed/engineered to pull upwards 80k- 100k pounds loaded
    are warranted for almost 1million miles .........oil changes 15-30k miles
    many go further
    idling is the biggest negative to those same engines ( drive 10hours .......sometimes sit/idle 8-12hours )
    the ' blow by ' contaminates the oil
    the difference in thermal ranges affects the rings greatly
    essentially the worst environment/scenario for oil
    save for a top fuel dragster
    deal is many thousands of engines over decades were manufactured
    sold
    driven
    without oil filters GM bulit quite a few.... NO OIL FILTERS for years )
    resulting in the proverbial>>>>>>>>>>>> Change every 3000 mile
    One day that ' ol saw ) will die !!!!
    gas is better
    tolerances inside an engine are great oil is better than EVER
    200k-300 expected & achieved
    i used extended drain intervals
    i change filters more often....................oil rarely wears out
    most recycled oil IS
    i do NOT changes brands or follow the hollow marketing
    never found a OEM filter that was surpassed
  19. Jun 15, 2020 at 7:42 PM
    #39
    TYetti
    Mat
    Put the Ganga down
    BassAckwards likes this.
  20. Jun 16, 2020 at 8:32 AM
    #40
    ROAD DOG
    FEW
    raced on mobil !
    amsoil
    redline
    i prefer ' ester ' synths as opposed to ' paraffin ' synths
    i can say im Not at all familiar with the new synths
    weve run24hours never lost power or an engine
    at teardown one ' reads ' an engine rather than wait for something to break
    allows that proper set up initially avoids issues
    HP gains are incremental rather than throwing a parts book at an engine
    no less a consistent often time consevative ' tune ' nets goods results
    allows the pilot not to overdrive yet rely on known parameters
