2tr-fe pistons question
Discussion in '4 Cylinder' started by ChristopherMolina, Nov 1, 2013.
  1. Nov 1, 2013 at 10:29 AM
    ChristopherMolina
    ChristopherMolina [OP] New Member
    Christopher
    Puerto Rico
    12 Sr5
    In process
    I have a question about my 2tr-fe pistons spec, I'm doing a project to make 2tr-fe engine turbo, the pistons of the 3rz-fe is the same spec as my 2tr-fe?
    because wiseco makes 3rz-fe forged pistons, if they match then i buy them.:confused::confused:
  2. Nov 1, 2013 at 11:44 AM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    The specifications for both engines is 95mm bore and 95mm stroke, so at least the diameter of the pistons would be the same. I don't know if the heads of the pistons are the same.
  3. Nov 1, 2013 at 6:49 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Call the dealer and see if the two part numbers are the same. Are you turbo'ing a 2tr
  4. Nov 2, 2013 at 11:45 AM
    ChristopherMolina
    Christopher
    Puerto Rico
    12 Sr5
    In process
    thanks, I'm calling now. yes, Im making my 2tr turbo I'm doing my homework finding parts and buying the accessories to start.
  5. Nov 4, 2013 at 7:12 PM
    toyodajeff
    jeff
    06 reg cab sr5
    Did you find the right pistons?
