2TR-FE Rebuild/Refresh
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Loxsl, Mar 26, 2018.
  1. Jul 9, 2018 at 10:46 AM
    #201
    LocoLocal
    LocoLocal Aspiring Polymath
    39.081221472127545, -77.45538862919935
    Large American
    Great to read that this thing is up and running.
    I do have a question, though. By your examination, was there any indication of what exactly caused the head gasket to go? I mean, I know it's caused by extreme high temps, but was it just lack of maintenance on their part, bad radiator, lack of coolant, etc.? I have the exact same truck (same color and everything), and I am at 190k, so I am hoping to avoid such a situation.
  2. Jul 9, 2018 at 11:03 AM
    #202
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Great job @Loxsl! Glad to hear she runs good now, any idea what the final compression numbers ended up being?
  3. Jul 9, 2018 at 11:10 AM
    #203
    Loxsl
    Loxsl [OP] tHeMaChInIsT
    Lancaster PA
    06 2.7 Tacoma 4x4 SR5 access cab
    Add a leaf and air springs
    I did not see any defined failure point of the gasket. I have a feeling that the valves were at least as much of an issue as the gasket may have been. They did put stop leak in so it's possible that did its job making it hard for me to tell. But the vlaves were super gunked up and likely did not seal well.
    Compression was about 185-190 across the board. I'll do another check after break in. First oil change is today (50mi).
    BassAckwards and 05Taco4x4 like this.
  4. Jul 9, 2018 at 11:13 AM
    #204
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    That's outstanding :bowdown:
    Slashaar likes this.
  5. Jul 9, 2018 at 11:52 AM
    #205
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    @Loxsl Probably one of the best 11 pages I have read on TW. :cheers:
  6. Jul 9, 2018 at 1:08 PM
    #206
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I saw the same on mine, I think this motor would definitely benefit from a catch can
    TomTwo and Loxsl[QUOTED][OP] like this.
  7. Jul 9, 2018 at 1:28 PM
    #207
    TomTwo
    Bill
    I-85 Southbound
    It was real nice to read a thread and NO body brought up tire size :thumbsup: I get real tired of that crap.
  8. Jul 11, 2018 at 11:20 PM
    #208
    iniazy
    iniazy Active Member
    Ibrahim
    Dhahran, Saudi Arabia
    Toyota Fortuner SR5 1GR-FE V6
    Air-locker front, 72 Liter auxiliary fuel tank, ARB bumper, Warn Winch, OME 2.5" Lift, Rear tire carrier, Safari snorkel, Front Runner roof rack
    Awesome work documenting the engine rebuild, I really applaud you. I know how much effort it takes to think about taking photos after every step of the build, wash the hands, pull the phone, take the picture, and dive back in.
    crazy joker, PzTank, TomTwo and 2 others like this.
  9. Aug 7, 2018 at 4:26 AM
    #209
    Loxsl
    Lancaster PA
    Update! So far the truck is doing great! I've put over 700 miles on it and done the first two oil changes. The engine does have some noticeable vibration as a result of the balance shaft delete but it's not annoying. You just feel it more.
    The LCE pro clutch is nice. Grabs well with no major increase to clutch peddle weight. Clutch point is a little smaller but not bad. If anyone is doing a performance build I'd highly recommend a lighter flywheel. The stock one is very heavy and results in sluggish engine movement. Again not bad but compared to my 335i it's a snail.
    So far all is doing well. Just waiting on Toyota to do the recalls then gotta fix that ac!
  10. Aug 7, 2018 at 6:10 AM
    #210
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Man that is the kind of update that I like to hear. Time for "snail" boost??? :D
  11. Aug 7, 2018 at 6:10 AM
    #211
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  12. Aug 7, 2018 at 9:00 AM
    #212
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Just got the lightened flywheel. Cant wait to see what kind of difference it makes
    05Taco4x4 and BassAckwards like this.
  13. Aug 7, 2018 at 11:53 AM
    #213
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    I’m afraid to get that flywheel woth 33s but feel like it’d be better with my turbo
  14. Aug 7, 2018 at 4:40 PM
    #214
    MrCrowntown
    Alyn
    Ky
    I'm running 33's so i'll give you some feedback! Though, I am also not 4x4 so there is a weight difference
    Jcyr[QUOTED] and 05Taco4x4 like this.
  15. Aug 7, 2018 at 8:56 PM
    #215
    Loxsl
    Lancaster PA
    Should just make it rev and shift better since the engine has less inertia. Which can bite you on hills or rock crawling.
    No turbo for this. Just lift and 35s. Gonna make some bumpers and sliders. It sounds like Toyota may be replacing the frame as well!
    randd, Jcyr, MY50cal and 3 others like this.
  16. Aug 14, 2018 at 11:07 AM
    #216
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Awesome update!
    Made me smile reading about the clutch improvement. Like you say, if I stayed on pavement, I would go with a lighter flywheel. Off road, where I live, not so much.
  17. Aug 14, 2018 at 2:07 PM
    #217
    MrCrowntown
    Alyn
    Ky
    Lightened flywheel feels amazing! Takes away that transient response lag time
    :burnrubber:
    BassAckwards, Torspd and Loxsl[OP] like this.
  18. Aug 14, 2018 at 3:57 PM
    #218
    81shark
    81shark Well-Known Member
    Awesome job
  19. Oct 11, 2018 at 12:55 PM
    #219
    05Taco4x4
    2TR-FE Enthusiast
    Any update on the frame replacement?
  20. Oct 11, 2018 at 1:19 PM
    #220
    Loxsl
    Lancaster PA
    Yep!
    All done. Been driving it about a month now. Basically a new truck at this point.
