2TR-FE Rebuild/Refresh
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Loxsl, Mar 26, 2018.
  1. May 6, 2018 at 9:06 PM
    #101
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    lol yeah
  2. May 7, 2018 at 9:30 AM
    #102
    05Taco4x4
    2TR-FE Enthusiast
    Please don't forget to take the spring measurements :playball:
  3. May 7, 2018 at 1:30 PM
    #103
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Is that basically a beefed up handheld laser engraver? Seems like its just burning off the layer it touches. I'd be curious if you used it on a gage block, if it would mic smaller after.
  4. May 7, 2018 at 1:34 PM
    #104
    Loxsl
    Loxsl [OP] tHeMaChInIsT
    Lancaster PA
    06 2.7 Tacoma 4x4 SR5 access cab
    Add a leaf and air springs
    I'd guess it's hot enough to burn off the crud but not enough to cut metal. Like a wood laser engraver cant do much to metal. If you lose a tenth no big deal really.
    Slashaar likes this.
  5. May 7, 2018 at 1:35 PM
    #105
    Slashaar
    Josh
    Kansas City, MO
    I just wanna know for Science!
  6. May 7, 2018 at 1:36 PM
    #106
    05Taco4x4
    2TR-FE Enthusiast
    There's plenty of videos online, explain how it works... all I know is it eats away everything but metal
  7. May 7, 2018 at 1:49 PM
    #107
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Love the bungees on that laser gun. Very high-tech!
  8. May 7, 2018 at 8:47 PM
    #108
    Loxsl
    Lancaster PA
    So here's something. I run wire EDM machines at work, and we use this light phosphoric acid cleaner to cut the burnt metal residue. It's mainly carbon build up.
    I tried it on some aluminum to see if it would stain it or anything. Looks pretty good. The cleaner is only like 10% acid.
    20180507_164722.jpg I flipped the dirty one to the other side for next pic
    Added acid and let sit for a couple min. Then, scrub with scotch brite and rinse with water
    Maybe the slightest pink tint but cant really say for sure.
    I'll find out what it is but should cut carbon well.
    dirty deeds and Torspd like this.
  9. May 8, 2018 at 10:15 AM
    #109
    05Taco4x4
    2TR-FE Enthusiast
    Did your kit come with a head gasket? If so, what's the quality like?
  10. May 8, 2018 at 10:47 AM
    #110
    Loxsl
    Lancaster PA
    It did but I didn't actually open the packet of gaskets and seals. I can look tonight. Seals I could see looked good
    05Taco4x4 likes this.
  11. May 15, 2018 at 3:21 PM
    #111
    05Taco4x4
    2TR-FE Enthusiast
  12. May 16, 2018 at 11:07 AM
    #112
    Loxsl
    Lancaster PA
    I've been trying to find time to post and as a result there's a lot to show. I'll try and break it up into posts about the same things.
    Let's start with the head. I took it to work, gave it an initial wash and cleaned the gasket surface then checked it. Its definitely within .0015 so all good.
    After that I pulled the valves and got to cleaning. The head came out reasonable and the valves are still soaking. I used that acid cleaner I tried on test blocks.
    20180513_164059.jpg 20180513_164050.jpg 20180513_163932.jpg 20180511_153445.jpg 20180513_174226.jpg 20180513_175333.jpg
    Careful here to not scuff the gasket surface!
    I'll post about the rest of my progress a little later.
    @05Taco4x4 I have half the spring measurements and an idea on how to get valve lift. I'll post those when I have them all.
    Torspd, MrCrowntown, Slashaar and 3 others like this.
  13. May 17, 2018 at 2:08 PM
    #113
    Loxsl
    Lancaster PA
    Ok here is a continuation of the work I did over the weekend and earlier this week.
    I installed the balance shaft delete from LCE
    20180513_173628.jpg 20180513_173831.jpg 20180513_181137.jpg 20180513_182234.jpg 20180513_182833.jpg
    Next up was the freeze plugs. I used a little sand paper to clean up the holes first. Using nice new brass plugs over the factory galvanized steel.
    I coated them in Permatex High Tack before installing
    While I was at work I used a pin mic to confirm that the new bearings are the right size compared to the old ones. Then put the new pistons on the rods. I actually reused the wrist pins and bushings as the new ones were like 3 tenths or .0003 smaller and I knew the old ones were in spec with the correct oil clearance.
    I definitely like that Lucas assembly lube.
    Last is a big one! I honed the block. Something to look into if you're ever building a high performance engine is what's called a honing plate or boring plate. It's basically a 2in block of metal that is head gasket shaped. The idea is you bolt the plate to the block with a gasket in the middle and torque to spec. Supposedly there can be minor distortion in the cylinder from torquing the head down. Then you bore and hone through it so the cylinders are correct when the head is installed.
    If everything is very flat this would be extremely minimal but hey, when doing performance it might be worth it. Since I am not boring and only honing for surface finish I decided to not make one. However, ball hones can mark up the top of a hole as they are used, so I made a block from some plastic to protect the gasket surface while honing.
    That is a ball hone or flex hone and is great for getting a few tenths out or for surface finish. Use a 240-280 grit for cylinders. It was really fast. Had to run the drill slow and move quickly.
    I will need to clean it again just to make sure all the grit is out of there but looking good and almost ready for assembly.
  14. May 17, 2018 at 3:47 PM
    #114
    05Taco4x4
    2TR-FE Enthusiast
    Looks good
    Loxsl[OP] likes this.
  15. May 17, 2018 at 11:38 PM
    #115
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Also known as a "torque plate."
    That plate makes a world of difference, when boring. Ask BMW.... Makes sure the the cylinders are concentric under torque. A very worthy investment.
    Your engine is coming along well , and I respect your acute attention to detail.
  16. May 18, 2018 at 8:35 AM
    #116
    Loxsl
    Lancaster PA
    I dont know if I'd say a world of difference. If your gasket surfaces are flat within. 001 you'll likely see only a few tenths .0003 max change in bore. There'll be more warpage around the bolts then in the bore. People have been making high performance engines for years without this by making sure everything is dead nuts first.
    That being said, if it's a high performance engine and you're doing all that already it's a good way to ensure a couple extra tenths. Not going to make or break your engine but may make it last a little longer.
  17. May 18, 2018 at 12:22 PM
    #117
    DGXR
    Friend
    Sacramento, CA
    I'm no machinist but I have been working on motors for a long time and those cylinder scores look extremely, almost excessively deep. May just be the camera angle or maybe it will clean up to look better before final assembly.
    Running Board Man likes this.
  18. May 18, 2018 at 12:34 PM
    #118
    Loxsl
    Lancaster PA
    I think it's mostly the lighting. I used the flash on my phone as it showed the marks better. I used the recommended size and grit hone fpr this so it should be good.
    I will do some extra checking though to confirm.
  19. May 18, 2018 at 1:03 PM
    #119
    Loxsl
    Lancaster PA
    http://hotrodenginetech.com/dart-blocks-honed-to-perfection/
    It's a ways down the page but that talks a good bit about honing and finish measurements. I think the picture is making it look really deep but like I said I'll double check. A 30 to 40 microinch finish is the goal.
    I did that late at night so I'm kinda questioning myself. You've got me all nervous now.
  20. May 18, 2018 at 1:07 PM
    #120
    DGXR
    Friend
    Sacramento, CA
    Don't be nervous, you obviously have far more experience with this stuff than I do. My statement was just an observation, and I can see how a flash photo could exaggerate the appearance of the hone marks. And if I could see the cylinders in person I would likely retract my statement. Carry on with confidence.
