2TR-FE Reliability
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bromagen25, Feb 24, 2011.
  1. Oct 31, 2013 at 12:21 PM
    #41
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) The steel lines provide oil pressure to the cams, and to the intake cam. On the front of the intake cam is the device that will let the variable valve system work. It uses the oil pressure to engage and disengage the device. A lot of variable valve engines work like this.
  2. Oct 31, 2013 at 3:09 PM
    #42
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Louisiana
    Old Toyota's, Power Wagon, and a Tacoma
    Traded the 2015 TRD Pro 6spd Supercharged on a PowerWagon and could not be happier. My 2011 Tacoma with the TX Baja package (Added by me) is still treating me great. My 1985 Toyota never skips a beat.
    I may just be the only person who has this picture.
    this is a comparison of the 22r (tall deck) and 2tr-fe
    as you can imagine the 2tr-fe is a heavy SOB
    Dalandser likes this.
  3. Oct 31, 2013 at 10:35 PM
    #43
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    Ah, I mistakenly assumed the lines distributed oil directly onto each lobe.
  4. Oct 31, 2013 at 10:50 PM
    #44
    Konvict KROG
    Louisiana
    Its been awhile but I am pretty sure the steel line/loom has a hole for each cam lobe like your picturing.
  5. Nov 1, 2013 at 7:29 AM
    #45
    taco woodeye
    taco woodeye Well-Known Member
    san jose CA
    2018 SR 4x2 Utility Delete Midnight Black Metallic.
    Great read on oil pressure/VVTi. I wrecked my Tacoma at 671,000. I would be closing on one million now. This was the best and most low maintenance vehicle I have ever owned.
    The 2TR-FE will start to burn oil at 350k miles. It's a $1000.00 valve stem seal repair or frequent top off. Good luck with smog check issues at half a million miles. Current specs call for GF-5 0W20 oil. Do yourself a favor and use Toyota Genuine motor oil. It is amongst the very lightest oils on the market and is one of the best. You will enjoy the best possible performance at $5-6/qt.
  6. Nov 1, 2013 at 7:55 AM
    #46
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    My 2.7 gen 1 was bombproof. Also sounded little like a time bomb when you first started it- ticking. But 230k miles without touching it once. Just oil and filters. Towing a lot too.
  7. Dec 2, 2014 at 1:44 PM
    #47
    window
    window Active Member
    NW Wisconsin
    07 Tacoma, 4Cyl,4WD
    Mine started ticking when it's cold. It goes away after driving it a minute. What is it since the valves aren't adjustable? 2007 with 193,000 miles.
  8. Dec 2, 2014 at 2:10 PM
    #48
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    You are probably hearing piston slap...
    The pistons are rocking very slightly in their bores until the engine has run long enough to generate enough heat to expand the metals and take up the bit of gap that is allowing the pistons to rock. That is my understanding anyway.
    What I don't understand is, why can I distinguish a single slap as being louder than the others, when all 4 pistons are slapping? Or is it just one piston that is slapping? Doesn't really matter, I'm just curious. These things will run a *very* long time after the pistons start slapping.
  9. Dec 3, 2014 at 5:32 AM
    #49
    window
    NW Wisconsin
    07 Tacoma, 4Cyl,4WD
    So, no big deal. Let it warm up a little and press on. Thanks.
  10. May 6, 2016 at 10:50 AM
    #50
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    Any updates how are those 2.7's are they still hanging in there
  11. May 6, 2016 at 11:02 AM
    #51
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Thanks to this thread I bought one with 130k on it mid last year. Been daily driving it and wheeling it ever since, 145k now, seems legit. I get this weird low idle condition after stalling it on steep hills every now and then but no codes and it goes away soon so I'd have to say all is good!
  12. May 6, 2016 at 3:28 PM
    #52
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    96,xxx miles and still going strong. Other than regular PM, it had a water pump leak at 18,000 miles, replaced under warranty. Great engine.
  13. May 6, 2016 at 5:37 PM
    #53
    bromagen25
    bromagen25 [OP] Well-Known Member
    Stock
    Rear Breather
    73K so far. Had to replace one of the pulleys but other than that:thumbsup:
  14. May 6, 2016 at 8:23 PM
    #54
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Put 55k on my old one, not a single problem. Expecting the same long life out of my V6 now. Any Tacoma engine lasts forever! Had an older 3rd generation 4Runner in the shop today with the 2.7 and it had 420,970 miles on the odometer still running like a champ. The body was rusted and beat, definitely had seen better days but that old engine stilled hummed like a sewing machine.
  15. Jul 17, 2016 at 4:41 PM
    #55
    von racer
    von racer Member
    2005 tacoma
    I've one at 236,000 miles, uses a lot of oil but going ok, up the mountains in 3rd with 3000 rpm
  16. Jul 17, 2016 at 9:36 PM
    #56
    TacomaZL
    TacomaZL Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    How do you guys find that you start burning oil? I have found the dipstick on the 2TR-FE to be utterly unreadable....
    When changing oil I put in between 5.5 and 6 qts.....I hope I am not screwing anything up..
    50,000 miles right now.
  17. Jul 17, 2016 at 10:05 PM
    #57
    Taco Pete626
    Taco Pete626 Well-Known Member
    Peter
    Southern California
    2013 Regular Cab 5-spd (Sold )
    - Undercover Flex tonneau cover - Pop N Lock tailgate lock - Weathertech DigitalFit floor liner - Sick Speed Ol' Skool white shift knob - Bench seat mod - Wiper mod - Cruise control mod
    smells and smoke from the exhaust. I agree the dipstick did not do its job very well. I don't know how Toyota screwed that up.
  18. Jul 18, 2016 at 9:44 AM
    #58
    tgear.shead
    tgear.shead Well-Known Member
    When you are getting to the truck in the morning to go to work, check the oil before anything else. Just pull it straight out and read it. That is your best reading, since the tube isn't coated with oil yet.
    Easiest way to "see" oil consumption, is to measure how much comes OUT of it. Catch the oil oil in your (empty) oil catch bucket, put in the new oil (6qt), and then pour the old oil back into the containers that the new oil came in.
    I've ALWAYS noticed that it comes out short of what goes in, and no, I haven't been increasing the oil going in between changes. From the first oil change to now. 12 changes in total, it is consistently down by a bit more than 1 qt. I do my oil at 10,000 km intervals (6250 miles), and I'm at 126000 km total.
    I usually buy a 5 qt jug and a 1. Adds up to 6. That all goes in, what comes out doesn't quite fill the 5qt jug.
    Don't worry about it though, ALL engines (regardless of owner claims to "never burn a drop of oil" -- technical impossibility) will use SOME oil. You just want to make sure it doesn't use excessive oil.
  19. Jul 18, 2016 at 8:34 PM
    #59
    2004TacomaSR5
    Jon
    Montana
    Why is it burning that much oil?
    I seriously hope you guys aren't putting 6 quarts in an engine that only takes 5...
  20. Jul 18, 2016 at 8:39 PM
    #60
    Taco Pete626
    Peter
    Southern California
    Oi, that's another discussion for another thread
