2TR-FE Reliability
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bromagen25, Feb 24, 2011.
  1. Jul 18, 2016 at 8:44 PM
    #61
    jibski
    jibski Well-Known Member
    Josh
    Arvada, CO
    2009 Silver 2.7 AC 4X4
    I've found that 5.5 quarts puts me right at the top notch on the dip stick every time. And the best way I've discovered for reading the dip stick is to pull it out and leave it out for a good while (15-30 mins?). That allows any oil clinging in the dip stick tube to drain down before you reinsert.
  2. Jul 18, 2016 at 8:52 PM
    #62
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Wait, people aren't putting 6 qts into their 2TR-FE? It says 6.1 in the manual, I could give a fuck what the dipstick says. I dumped in 6 qts, drove it once, and made my own mark on the stick at the high point after sitting and that's what I call full.
  3. Jul 18, 2016 at 9:04 PM
    #63
    jibski
    Josh
    Arvada, CO
    *You couldn't give a fuck.
  4. Jul 18, 2016 at 9:15 PM
    #64
    andrew61987
    I thought about it, and I lead the charge in suppressing "I could care less".
    But after writing it out I said fuck it, I like how "could" rolls off the tongue better.
    So,:luvya:
  5. Jul 18, 2016 at 9:20 PM
    #65
    TacomaZL
    TacomaZL Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    It is unlikely Toyota gave us a bullshit dipstick AND and bull shit capacity in the manual...I leave shit like that to Fiat/Chrysler :brianr::brianr::brianr:
  6. Jul 18, 2016 at 9:21 PM
    #66
    jibski
    Josh
    Arvada, CO
    It does have a better sound to it.
    I also like "I missed the boat to give-a-fuckistan"
  7. Jul 19, 2016 at 6:35 AM
    #67
    tgear.shead
    tgear.shead Well-Known Member
    Could be burning oil because he is doing like you and under filling it....
    You should really take a little bit of time and read the manual, which outlines it all;
    Code:
    Oil capacity (Drain and refill -reference) With filter 6.1 qt. (5.8 L, 5.1 Imp.qt.) Without filter 5.4 qt. (5.1 L, 4.5 Imp.qt.)
    The imperial quart is dead, most people will reference either US qt, or LITERS. With filter change (which you should ALWAYS do when changing your oil), capacity is 6.1 qt.
    Ref: http://www.toyota.com/t3Portal/document/om-s/OM35A34U/pdf/OM35A34U.pdf pp.492 at top of page.
  8. Jul 19, 2016 at 7:49 AM
    #68
    Taco Pete626
    Taco Pete626 Well-Known Member
    Peter
    Southern California
    2013 Regular Cab 5-spd (Sold )
    - Undercover Flex tonneau cover - Pop N Lock tailgate lock - Weathertech DigitalFit floor liner - Sick Speed Ol' Skool white shift knob - Bench seat mod - Wiper mod - Cruise control mod
    The manual also states to go by the dipstick. Just to play devil's advocate, maybe the reason why its burning so much oil is because he is over filling it, causing the crank to whip it up, resulting in more oil blow by through the PCV valve.
    Some related threads:
    https://www.tacomaworld.com/threads/2016-2tr-fe-oil-qty-owners-manual-changes.409007/#post-11558176
    https://www.tacomaworld.com/threads/dip-stick.38422/
    https://www.tacomaworld.com/threads/2-7l-oil-capacity.129597/
  9. Jul 19, 2016 at 7:58 AM
    #69
    tgear.shead
    You would have to be several qts overfilled before the level approaches the crankshaft.
    Also, 6 qts reads at the "full" tick on mine. I suspect that people with excessively high readings are doing one of two things (or both);
    1) taking reading after coating inside of tube with oil, causes reading to mess up.
    2) taking reading after letting engine sit too long -- oil level is supposed to be read immediately after RUNNING engine, not after letting it all drip back down.
  10. Jul 19, 2016 at 10:08 PM
    #70
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    Dude... Are you joking? The manual also says go by the dip stick (the mark that came on it from the factory, not your garage). This is why I don't buy used cars.
    cryptolime likes this.
  11. Jul 19, 2016 at 10:13 PM
    #71
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    i guess people dont realize theres residual oil left in the engine that can equate to a few tenths of a quart. id assume that 6.1qts is dry. i always go by the dipstick as the manual states and have never had an issue, and i'm not going to change now. :)
    cryptolyme and JeffreyB like this.
  12. Jul 19, 2016 at 10:17 PM
    #72
    Bishop84
    Bishop84 Well-Known Member
    I've done 200 1gr oil changes to every 2tr. They are super rare up in Canada.
    They are the only Toyota made engine that still uses a frost plug style block heater that we install on PDI's.
    I've changed more 22RE's due to headgaskets than 2TR's. Age is a big factor with that though.
  13. Jul 20, 2016 at 8:20 AM
    #73
    andrew61987
    If you believe my method is harming my engine in any way you're out of touch.
    A few tenths of a quart up or down isn't going to make a bit of a difference anyway.
  14. Jul 20, 2016 at 8:24 AM
    #74
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    The 22R had one camshaft and 2 valves per cylinder too.
  15. Jul 20, 2016 at 8:30 AM
    #75
    tgear.shead
    You're in Alberta though, where fuel is cheap. Try in Ontario, its about 50/50 here between 4 and 6 cyl.
  16. Jul 21, 2016 at 7:23 PM
    #76
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I work on these things every day. I've yet to have to add more than 5 to a 4 cylinder and it's always on the top dot of the full range. Maybe the manual's talking dry-fill capacity. You can never get all the old oil out of an engine without completely disassembling it down to every last nut and bolt. I no longer have a 4 cylinder, but my 2011 always took 5 as well. Never burned or used any oil between changes either.
    cryptolyme likes this.
  17. Jul 21, 2016 at 8:57 PM
    #77
    AJH387
    AJH387 Well-Known Member
    AJ
    Pittsburgh, PA
    '19 TRD OR DCLB
    Just got my truck with a 2TR-FE. I commute a lot of highway to work and I decided to go with that engine for a tad better fuel economy and also just for the reputation that the engine has (at least from who I have talked to that has owned either 4cyl motor).
  18. Aug 16, 2016 at 12:18 PM
    #78
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    I bought my 4-cyl (2TR-FE) reg. cab brand new in Feb. 2009 and it just rolled over 180,000 miles this morning. It's never been touched other than oil changes & tires (well, I did drop a set of new plugs in it about a year ago, just because I thought I should, but it was running fine). I commute about 100 miles/day round trip - 90% of which is cruising down the interstate, so I change the oil & filter myself every 10,000 miles (yes, 10,000) and put 6 quarts of Mobil-1 5w20 "High Mileage" in it every time along with a good filter. Doesn't burn a drop yet that I can tell - and I'm still on the original water pump/seal... no leaks. I run it pretty hard too - including some towing. If it blew up on the way home today, I'd say I've easily gotten my money's worth out of it... but I suspect it'll go another 100k. Maybe more! Awesome engine. Not very exciting/powerful, but reliable as an anvil.
  19. Sep 20, 2016 at 7:17 AM
    #79
    ajtaco
    ajtaco New Member
    Calgary, AB, Canada
    05 SR5 4cyl 4x4
    I have a 2005 Tacoma 4x4 access cab with the 2tr-fe engine and have just passed 310,000kms (193,000 miles). I got it pretty cheap on the used market and it's my daily driver commute vehicle. I drive it on gravel and rough roads during the summer and winter in the Canadian Rockies. I change the oil out roughly every 5000kms with whatever 5w30 is on sale, usually Quaker State or Castrol. Aside from that, all I have done is coolant flush with Toyota Super Long Life coolant, changed the battery out and air filter. I find I put approx. 5.3 liters per oil change and use the Toyota oil filters. I am happy with the reliability of the engine for sure!
  20. Feb 8, 2017 at 4:02 PM
    #80
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    Is there anyway to tell what country are 2.7 was manufactured in ?
