2TR-FE Reliability
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bromagen25, Feb 24, 2011.
  1. Jan 16, 2019 at 1:39 PM
    #101
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    My 06 has a little over 167k miles...no major issues.
  2. Jan 17, 2019 at 4:59 AM
    #102
    billybob50
    billybob50 Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
    Have you replace that cheap plastic heater pipe?
    Jimmyh likes this.
  3. Jan 21, 2019 at 10:02 PM
    #103
    kidthatsirish
    No. I did purchase the vehicle in jan of 08 ( it was built in Sept of 06).
    When I purchased it it had 36,000 miles. I have drained and filled the entire coolant system (radiator and block) at 100,000 miles.
    As far as I know the cooling system is completely stock
  4. Jan 22, 2019 at 7:20 AM
    #104
    billybob50
    Bob
    This is a weak link of this engine. Pipe will crack you'll notice a puddle of antifreeze on floor on driver side under/hidden around the powder steering area. When the pipe cracks it'll start sucking air, and stop drawing coolant from the reservoir, so the tank will look full. The temp gauge wouldn't show overheating cause there's no water in the head to measure the coolant! Toyota actually set this up for failure, the pipe they replace it with is medal. https://www.youtube.com/watch?v=jsBPLiwk9Vw
  5. Jan 22, 2019 at 7:32 AM
    #105
    kidthatsirish
    Hopefully my pipe will make it to 240,000 miles as well. I'll have to keep an eye on it and the radiator though.
  6. Jan 22, 2019 at 7:42 AM
    #106
    billybob50
    Bob
    Good luck you'll need it!
  7. May 5, 2019 at 6:30 AM
    #107
    MIKO
    MIKO Member
    MIKO
    2015 TACOMA 4X4, I4 MT ACCESS CAB
    NONE SO FAR
    I have a 2015 Taco w/2TR-FE, it doesn't burn a drop of 05W-20 syn during a 5k change interval. Mileage is excellent, getting 20mpg city. Power is OK. I have a CBR1000RR for when I'm feeling squirrely, so I don't mind that it's only 130HP. I think it's a great engine, and as was prev. mentioned here in this thread, the Toy trucks' structural steel and body panels fail far sooner than the engines ever will.
    sr5vic and taco woodeye like this.
  8. Mar 18, 2023 at 10:45 AM
    #108
    brightondale
    brightondale Active Member
    SE Michigan
    2012 Tacoma, Regular Cab, 5 Lug, 5 spd, Silver
    Ziebart ViperRS Undercover1pc Weathertech K&N Ziebart Body Panel Rustproof from new Lifetime Warranty Viper 2way Remote Start Undercover One Piece Tonneau Rubber bed mat Auto Ventshade Bugflector Roadmaster Active Suspension (amazing ride improvement) Stock steel rims painted black Tinted Windows Two Layer Weathertech Floor Mats Added intermittent wiper and cruise control CoverKing bench seat cover K&N Air Filter Oil Changed every 2500 miles, 0w20FS / OEM filter Curt Class 3 hitch and Trailer Wiring 4xInnovations hidden front hitch Vantop F&R Miror Dash Cam Original brakes lasted 150k
    A 2015 Taco with 2tr-fe has 161hp not 130. That’s up from my 2012 Taco with 2tr-fe that has 159hp. Wouldn’t even be noticeable; just say 160:hattip: Yes my responses is a little late but given the average taco lifespan…
    I’m at 232,000 miles now and it seems to have all the power it had when new. Clutch seems the same as well. I truly think it runs smoother now than it did when new. It has a small oil seep on the upper oil pan, or sifter plate as they called it. Would cost nearly 2k to fix. Otherwise it shows no oil consumption. Definitely not worth fixing at this point so I let it seep. Vehicle-wise, the Taco is the best money I’ve ever spent.
    IEsurfer and ecoterragaia like this.
