2tr-fe turbo from 2rz engine
Discussion in '4 Cylinder' started by 5 Lug Fury, Nov 2, 2015.
  1. Nov 2, 2015 at 12:07 AM
    5 Lug Fury
    5 Lug Fury [OP] Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    There is an ad near me for some turbo parts and one of them is an intake manifold from a 2rz engine. I have a 2tr-fe and was wondering if it is possible to use. I understand the engines are from two different families but they are both Toyota 4 cyl and it never hurts to ask.
  2. Nov 2, 2015 at 12:44 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    No the manifold will not work. The 2rz is a 2.4, the 3rz is 2.7 and its manifold wouldn't work on a 2tr either.
  3. Nov 2, 2015 at 9:32 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    I figured thanks
  4. Nov 2, 2015 at 12:28 PM
    tgear.shead
    tgear.shead Well-Known Member
    Well, to flip that remark upside down... everything can be made to work with anything else. You can make the manifold and turbo charger from a bulldozer work on a Tacoma, as long as you are patient and have good fabrication skills.
    But since the question that was MEANT probably involved a direct bolt up, other provided answers should stand.
