2TR-FE Volumetric Efficiency
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Laurence243, Nov 17, 2015.
  1. Nov 17, 2015 at 1:57 PM
    Laurence243
    Laurence243 [OP] Active Member
    2010 Tacoma 2.7, 5-speed, 4wd
    Yellow wire mod, LCE header, 2.5" cat-back exhaust
    I'm trying to find this value for OBDLink on my smartphone. I can't seem to find this number anywhere, does anybody know what the volumetric efficiency for the stock intake on a 2010 Tacoma with the 2TR-FE is?
    EDIT: I'm also wondering what would be most accurate for calculating fuel mileage: mass air flow rate, Intake manifold absolute pressure, or direct fuel rate?
  2. Nov 18, 2015 at 1:35 AM
    Shepdog08
    Shepdog08 Well-Known Member
    265/70 R16 BF Goodrich A/T's Plasti-dipped factory wheels More to come...soon
    I have the torque app and an OBDLink adapter and it does instant mpg. Calculates it all and has tons of features. Fuel flow rate, trim, sensor voltages, data logging, engine load, etc...
    As far as average MPG I just do that every fill up.
    Volumetric efficiency, well isn't that something that's pretty variable? I don't know much about it.
  3. Nov 18, 2015 at 3:48 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    hwat ?
    fuel used per mile
  4. Nov 18, 2015 at 3:50 AM
    Shepdog08
    You mean what your mpg is at that exact moment? Or your average over the course of the tank?
  5. Nov 18, 2015 at 3:55 AM
    Shepdog08
  6. Nov 18, 2015 at 3:57 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    like a scangauge and decent app will calibrate itself
    you fill up
    you go drive
    fill up again
    app says how much it guessed you used, you tell it exactly how much
    if you use same pump, parking position, time of day and outside temp on fillups
    it will be extremely accurate after doing this 3 times
  7. Nov 18, 2015 at 4:16 AM
    Shepdog08
    Dunno. Torque does it completely different. It calculates it based on Gallons consumed over a trip setting using gps and odometer readings. Also logs all other vehicle sensor data for whatever trips are saved.
    I mostly just use instant mpg to monitor what my mileage could be at any given second to adjust my driving.
