2TR Performance Parts!!!
Discussion in 'Performance and Tuning' started by LsuMeDesigner, Dec 4, 2012.
  1. Dec 10, 2012 at 9:29 AM
    LsuMeDesigner
    LsuMeDesigner [OP] Well-Known Member
    Yeah I can only see this working with dual AFR sensors. One before turbo and one after.
    Im almost positive they are running a second set of fuel injectors right before the turbo essentially turning it into a turbine.
    Tuning of the AFR and controlling the temp of the turbine is what is really puzzling me.
    Burning unspent fuel in the turbo would cause some extreme temps and I imagine it would be glowing red in a matter of seconds.
  2. Dec 10, 2012 at 9:42 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Venturi and Fibonacci make a great team, regardless. ;)
    Time to make one for my truck. :D
  3. Dec 10, 2012 at 11:58 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    http://www.xr-underground.com/forum/showthread.php?t=51383
    Did some looking around and found that the stroke on the 2TR & 1GR are both 95mm. I would very much bet that they both use the exact same rods.
    Once your spare engine comes in, you should send a rod out to Dezod and have them compare the two. If it is, you should get in the group buy. :thumbsup:
  4. Dec 11, 2012 at 6:49 AM
    LsuMeDesigner
    Yeah I was aware of that.
    Also the 2tr has the same stroke and bore as the 3rz 4 cylinder.
    If anything I'm kind of hoping that these two are close enough to use3rz parts.
    I want people to be able to replicate this build. The rods are supposedly forged from factory, so I will be going pistons, turbo, and tune. Whenever that lets go...then all bets are off and I'm turning her into a beast.
  5. Dec 11, 2012 at 7:00 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    According to Wikipedia, the rods in the 1GR are forged. That is clearly not the case. Make sure to check on the rods. You will be able to tell upon first look if they are powder cast or forged.
  6. Dec 11, 2012 at 8:59 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    What, you dont trust wikipedia?!?? Lol
  7. Dec 11, 2012 at 10:52 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Someone needs to add some corrections in there for our engine. Been uncorrected for a long time.
  8. Dec 11, 2012 at 11:03 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    I think wiki has open editing. Did anything else look bad on the wiki page?
  9. Dec 11, 2012 at 11:06 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I believe the sleeves that they listed were wrong as well.
  10. Dec 17, 2012 at 12:40 PM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    Just any beat a gm without forced induction muwahahahahahahah
  11. Jan 3, 2013 at 6:21 PM
    DOUBLEJTACOMA
    DOUBLEJTACOMA Active Member
    Jeremy
    Jasper, Alberta
    Blacked out SR5
    -Black Halo Projector Headlights with HIDs -Black Billet Grille -Night Shaded Tail Lights -Exhaust (Magnaflow) -URD 2.7L Supercharger (soon, may need help)
    Any updates on this?
  12. Jan 11, 2013 at 9:05 AM
    LsuMeDesigner
    Hey sorry for no updates lately, but I've been extremely busy.
    Soo just to fill everyone in with what has been going on. I ordered a spare 2TR from eBay, but when I took it to my machinist he noticed a hairline crack in the block which was prob caused during a wreck.
    Soo after fighting with that for two weeks I was a little annoyed and aggregated and have not ordered another yet.
    But I have been focusing on other parts of the truck and getting those worked out.
    I'm going to be putting the 7.5 rear to the test and ordering a LSD today for it today.
    This thread will prob be abandoned for a build thread soon.
  13. Jan 15, 2013 at 8:17 AM
    LsuMeDesigner
    Alright I need some help!
    If everyone can look in their local pull a part or local engine resellers, I'm in search of a 2Tr engine.
    No one has them locally and eBay is pretty expensive.
    Also if anyone has a 3RZ piston and rod they can send me to compare with 2TR piston and rods I'd really appreciate it. We can work out some sort of deal an ill mail the parts back to you.
  14. Jan 15, 2013 at 9:12 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    By any chance, have you tried contacting LC Engineering, to see if they have done a comparison?
  15. Jan 15, 2013 at 12:39 PM
    #35
    nik.moretto
    nik.moretto Active Member
    nathan
    regina sk
    18 ltd
    count me in for this i need some go fast..and yea the sts kit on our trucks dont seem like the method of choice
  16. Jan 16, 2013 at 5:36 AM
    #36
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Definitely do no do the STS. you will waste time and money. Been there. Done that.
  17. Jan 16, 2013 at 6:26 AM
    #37
    LsuMeDesigner
    Yeah no STS turbo kit for me!!
    No I have not talked to any companies, alot of companies are willing to help customers, but not as willing to help someone who is pioneering and designing their own parts.
    If you think they would be cool, then Id give them a shout.
    It has literally rained for like 20 days straight here...its getting really bad. But when the weather clears im going to get a couple photos of the truck and start my build thread.
    Ive also been very busy with work and helping a friend build his race car. Im also working with an engineer at a very well known Honda Performance company to design some new parts for the 9th gen civic.
  18. Jan 16, 2013 at 6:31 AM
    #38
    LsuMeDesigner
    Im currently working on a AC line relocation kit. This will make manifold and turbo placement a lot easier. Does anyone have pics of under hood with the 4.0 V6 AC lines? It might be possible to use the V6 model lines.
    Also....im a little new to Toyota performance, but are all R-series transmissions interchangeable?? Im curious about upgrading to a R154 compared to my R155 transmission. How do you think the power rating of these two transmissions compare to one another??
  19. Jan 16, 2013 at 6:32 AM
    #39
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yup. Talk with LC Engineering. They are all Toyota. They might know if the rods are the same between the 2TR and the 1GR or 2/3RZ. I hope that the rods are the same as the 1GR. Because Dezod is starting a group buy for new rods from Molnar(?), for about ~$660+ or -.
    You know as well as I that it is just easier if some parts are the same.
  20. Jan 20, 2013 at 4:14 PM
    #40
    LsuMeDesigner
    Okay guys....sorry to dissapoint but the 2TR has been abandoned.
    My work schedule just does not allow me to research, design, and build one off parts for this engine.
    The good news is.....im still building the Tacoma, just not with the 2Tr. Im pretty sure this will be the first swap of its kind in the 2nd gen Taco though.
