2TR rebuild
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco Nation, Jan 30, 2016.
  1. Jan 30, 2016 at 2:42 PM
    Taco Nation
    Taco Nation [OP] Well-Known Member
    Zack
    Clinton, MS
    94.5 F350, 77 F150, 74 F100, 11 Jeep Grand Cherokee
    Lift, wheels, tires
    Well I went balls to the wall and hydrolocked my engine. Now it's seized even with the plugs out. What are the chances it's the valve train seized and I can just put a new head on it?
  2. Jan 30, 2016 at 3:37 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Any auto recyclers with 2TR engines in your area? I'm guessing the answer to your question will require an engine teardown, sad to say.
  3. Jan 30, 2016 at 3:44 PM
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    Not that I know of sadly. I'm thinking about throwing a 2UZ in it now.
    Fenwick1993 likes this.
  4. Jan 30, 2016 at 4:26 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I have seen con rods sheared right off during a hydrolock. Pull the pan and have a look.
  5. Jan 30, 2016 at 4:58 PM
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    That's one of my theories is that when it hydro'd it snapped a rod and threw it through the cylinder wall. But it didn't sound like that happened.
  6. Jan 30, 2016 at 5:02 PM
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    It just felt like it stalled. It was a gradual loss of power and then died.
  7. Jan 30, 2016 at 8:08 PM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    you try turning the crank with ratchet?
  8. Jan 30, 2016 at 8:22 PM
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    Sure did. Put about a 18" breaker bar on it and pulled as hard as I could. Didn't budge
  9. Jan 30, 2016 at 8:58 PM
    vtdog
    vtdog Well-Known Member
    NH
    I am not an expert, but in my humble opinion you are screwed
  10. Jan 30, 2016 at 8:59 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Did you pull the plugs first?
  11. Jan 31, 2016 at 5:01 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    You can pull the head and have a look a dead give away would be one piston that does not match up in depth. There are a lot of forces at work in there and water does not compress.
  12. Jan 31, 2016 at 5:18 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    Sounds like you'll be looking for an engine. However if you ask this kind of question I wouldn't suggest trying any kind of crazy swaps unless you have piles and piles of cash, LOTS of time, and some serious skills. Putting a 350 in an old landcruiser is one thing. Doing an OBDII engine swap in an OBDII vehicle and actually having it run with no codes afterwards is another thing entirely.
    koditten and 95 taco like this.
  13. Jan 31, 2016 at 5:26 AM
    oldracer
    oldracer Well-Known Member
    Slim to none
    I have been involved with hydro-locked engines. If you were lucky, and didn't bend the rods. By taking out the spark plugs would release the water, when hand cranked.
    If it will not turn; you bent something in the engine. Rods would be first guess, pistons etc.
    That is assuming that you removed the water quickly; and rust did not form on the cylinder walls.
    oldracer
  14. Jan 31, 2016 at 7:01 AM
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    Of course
    It only say for about 8 hours. Doubt it's rusted up
    oldracer[QUOTED] likes this.
  15. Jan 31, 2016 at 7:15 AM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    Looks like it's probably time for a new engine. Since you took the plugs out, and it still won't budge (water should have come out from plug holes upon trying to bump engine) there is doubtlessly extensive damage in there. I would definitely tear this one down, at least for the learning experience.
    Good luck man.
  16. Jan 31, 2016 at 11:02 AM
    nighthawk33
    nighthawk33 Well-Known Member
    NJ
    Tacoma 4X4 TRD Off-Road
    On the list of potential issues here, I would think that rust is pretty low.
  17. Jan 31, 2016 at 12:39 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Swap one of these in:
    In all seriousness, most likely you bent rods to the point of them interfering with the block or webs of the crank. Tear it down and find out.
    AR15xAR10 and iwashmycar like this.
  18. Feb 2, 2016 at 2:52 PM
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    Dropped the pan. Bottom end looks good. Water pump and thermostat are good. Engine will not turn either way. I figured it overheated and the rings welded. But if the water pump and thermostat are fine and the radiator is full then that doesn't seem possible. There does seem do be a hole for lack of a better word where the engine and transmission mate. I guess it is could be possible a rock or something is jammed in the flywheel? I'm kind of at a lose right now. Anyone got a clue?
  19. Feb 2, 2016 at 4:08 PM
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
  20. Feb 2, 2016 at 4:37 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Internet diagnosis is going to be difficult on this one.
    I'm in for pics :popcorn:
