2trfe and code P0339
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gtrotter07, Jul 27, 2021.
  1. Jul 27, 2021 at 6:29 PM
    gtrotter07
    gtrotter07 [OP] Well-Known Member
    2007 Tacoma reg cab 4x4 on 37's; 2021 TRD Offroad, 6 speed
    37's,lockers, bumpers, bobbed etc.
    Has anyone on here with the 2trfe had to replace the crankshaft position sensor? No cel on the dash, but I've noticed lately I am down 1 to 1.5 mpg. So I pulled out my scanner and sure enough it has thrown P0339. I cleared the code, but it has come back. Other than the code( and no cel) it seems to run fine. Minus the slightly worse mpg.
    Is this a hard change out? Could it possibly just be a loose connection?
  2. Jul 27, 2021 at 7:30 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    A loose connection or faulty wiring is a possibility unfortunately the only proper way to test the sensor is with a scope, you can do a resistance check and a visual inspection but that's about it.
    Have you noticed an extended crank, that's pretty common to have if the crankshaft position signal is missing.
    Looks like it lives down behind the A/C compressor bracket.
    Steves104x4 and TnShooter like this.
  3. Jul 28, 2021 at 6:01 AM
    gtrotter07
    No extended cranks that I've noticed.
    I'll be honest, pulling all of that off to get to the sensor looks like a pita. I may just let it ride for the time being. Lol I will however check for loose connections and throw a little dielectric grease in there.
  4. Jul 28, 2021 at 10:50 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Don't. Dielectric means 'does not' conduct electricity.
