"2w-4w change malfunction" after ECGS install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bigmace, Sep 6, 2021.
  1. Sep 6, 2021 at 11:02 AM
    bigmace
    bigmace [OP] Well-Known Member
    Salem, OR
    2020 DCLB SR5 4x4
    Has anyone had any issues with this? Pretty sure I installed it correctly but now when I try to shift into 4h it throws this error. I am able to get it shift into 4l but has a hard to shifting back into 2w drive.
    Any tips? I also seemed to have messed up an ABS wire, could this be related? Going to fix / replace the wire asap.
  2. Sep 6, 2021 at 11:34 AM
    bigmace
    Salem, OR
    2020 DCLB SR5 4x4
    Update: Shifts into 4wd just fine if I put in 4 and the turn the truck off and then back on. Sounds like faulty ABS wire causes issues with shifting into 4wd.
