2WD 4CYL in snow? Really need help. Tacoma SR
Discussion in '4 Cylinder' started by Breno805, Nov 19, 2022.
  1. Nov 21, 2022 at 7:05 AM
    FloTaco
    FloTaco Well-Known Member
    Bay Area, CA
    2021 SR DC 4X4
    That front diff would also have to be re geared to match his rear. This is not a cheap or easy conversion. The cost would be the delta between just buying a 4wd truck.
  2. Nov 21, 2022 at 9:03 AM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    G
    good point. Totally forgot about that
  3. Nov 21, 2022 at 9:30 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    side suggestion, get your truck undercoated with a non-rubber undercoating
    search for: Fluid Film, Wool Wax, Cosmoline threads
  4. Nov 22, 2022 at 11:49 PM
    Breno805
    Breno805 [OP] Member
    2016 Toyota Tacoma SR Utility Package
    Does that stay on there forever?
  5. Nov 23, 2022 at 6:09 AM
    CraigF
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    first 2 are yearly treatments
    the third can go years between applications but always best to check annually before the salt/brine starts going down, especially in the high splash zones
  6. Nov 27, 2022 at 10:30 AM
    Zerksees
    Zerksees Well-Known Member
    2017 Access Cab SR 2.7L M/T 4WD
    Weight in the bed, Blizzaks on the road, Surface Shield is also a great spray-on protectant.
  7. Nov 27, 2022 at 10:54 AM
    Hercanstein
    Hercanstein Well-Known Member
    Bryan
    State of Jefferson
    1999 2.7 SR5 4x4 5MT XC, 2020 3.5 TRD Sport 4x4 6MT AC
    ('99) Offset Aluminium Wheels, 31" BFG All-Terrains, Bushwacker Fender Flares, Window and Hood Wind Deflectors ('20) Stock
    This.
    I drove in Alaska (Kenai '85 to '89, Anchorage '91 to '01) and all my vehicles were 2wd. A little Ford Courier was my first, some Corollas, a Citation and a Bug.
    I would recommend a set of studded winter tires for wintertime. That saying "Slow and easy wins the race" should be at the forefront of your mind when driving in slick conditions. Always give yourself at least double the distance of what you think you need to stop. The sandbags are a superb idea, that way you have some to throw under the tire for traction in addition to the benefit of added weight. Chains or cables work well, but can be a pain to mount on your tires correctly. If you stick to maintained roads, I think you should be o.k. with 2wd.
    That said, I have owned nothing but 4wd vehicles, except for the old VW van I bought when I first arrived in Oregon in '01 (it did EXCELLENT in the snow by the way), not because 4wd is needed but because 4wd is FUN!
  8. Nov 27, 2022 at 10:58 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    My buddy drove a RWD Titan for 10 years with snow tires and some Quikcrete bags in the back. And he lives in Monument. Hills might be a bitch in some places.
  9. Nov 27, 2022 at 7:41 PM
    Quien es?
    Quien es? Well-Known Member
    Central TX
    2020 DCSB SR 4x4
    Armrest cushion, Glovebox divider, Toolbox
    In addition to all the other comments, having lived in Colorado Springs for 5 years, and with only two 2-wheel drive vehicles (minivan, 1/2 ton pickup):
    1) Colorado Springs (proper) is good about prepping the roads and removing snow.
    2) Stay away from Monument Hill (I-25 towards Denver) when it snows- knuckleheads abound.
    3) Yes, going up some hills may be a pain, but it is generally doable.
    4) an earlier post mentioned COTRIP website, I highly recommend the same.
    5) IMO: @Hercanstein says it best above—- you don’t NEED 4wd, but it is FUN to have it. If your budget doesn’t allow for it, you’ll be fine.
    Zerksees likes this.
  10. Nov 29, 2022 at 5:10 PM
    Tacoyeeyee
    Tacoyeeyee Member
    Al
    2023 SR 4x4
  11. Nov 29, 2022 at 5:18 PM
    Breno805
    Thanks for sharing but what’s your point? Not being rude thanks
  12. Nov 29, 2022 at 6:20 PM
    Tacoyeeyee
    Tacoyeeyee Member
    Al
    2023 SR 4x4
    Coming from California I thought road conditions would be of interest in your decision.
    I don’t know your experience with the conditions you’ll find there and thought it would be helpful to see and read about it. If you plan on heading into the high country I’d go 4x4 if not a bit of weight in a 2wd is fine. The main danger in my past has been other drivers. Colorado is a high tourism state and a lot of Texans and Okies are skiing in the winter/heading for cooler air in the summer. I lived in Security previously (next door to C.Springs) and usually go through there on my way up north in the summer. The traffic conditions have gotten worse due to drivers not driving for a multitude of reasons. I ditto the snow tires and studs, not so that you can maintain control but get the heck away from someone who has lost it. A lot of good advice has been given here in this thread.
    Best wishes on your move.
