2wd-4wd mode change failure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mchristou, Mar 5, 2019.
  1. Mar 5, 2019 at 2:32 PM
    mchristou
    mchristou [OP] Member
    2017 Grey Tacoma TRD Off-road
    7 inch BDS coilover lift 18x12 -44 Fuel Hostages 35x12.5 Toyo Mt’s True Duals 8pc Rock lights 2x 12inch kicker pro comp subs
    Okay guys I’ve had a problem similar to this before where I was unable to switch between 2wd and 4wd and the green light in the dashboard was constantly flashing. The dealer claimed my 6” bds lift was causing something to bind and make it unable to switch. After about 3 trips to the dealer they finally fixed the issue that was about 6 months ago. Today I went to do some off-roading with friends when I attempted to switch my truck into 4h and was shown this message. Not only are the modes unusable but I can’t clear the message from my screen. Any advice?
    Nunya Bizness likes this.
  2. Mar 5, 2019 at 2:34 PM
    sandiegohasthebesttacos
    sandiegohasthebesttacos Well-Known Member
    take it to a mechanic for another opinion. it's hard to diagnose a truck based on a picture and some words.
    Chew, GillyLink and SandyTaco4x4 like this.
  3. Mar 5, 2019 at 2:36 PM
    mchristou
    Already made an appt at my local dealer just wanted to know if anyone had experienced this issue
  4. Mar 5, 2019 at 2:41 PM
    Tacoma2020
    Tacoma2020 Well-Known Member
    Have you been doing the switch monthly since purchase?
    GreyBaldTaco likes this.
  5. Mar 5, 2019 at 2:47 PM
    mchristou
    Yes I use it fairly often atleast once or twice a month
  6. Mar 5, 2019 at 2:56 PM
    Beaner Taco
    Beaner Taco Well-Known Member
    WV
    '17 SR5
    Mine blinked and wouldn't engage the other day when I needed it. Did not have the failure notice like in the pic. I use my 4H everyday and it has only happened once. Concerned me but am waiting until it happens again to take it a dealer. If it doesn't happen sooner then I will mention at the next free service.
    Curious if others ever experienced the flashing green light.
  7. Aug 11, 2019 at 8:17 PM
    Kgrecurit88
    Kgrecurit88 Active Member
    Kyle
    2017 Tacoma TRD OR DCSB SWhite
    Drop in k&n Leveking kit Rago ditch lights
    Just started having this issue with my tacoma. Also bds 6". What was the outcome of your problem?
  8. Aug 11, 2019 at 8:24 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    What'd u do to get to this screen? U say u couldn't clear it but there's a back arrow on the top right that should clear it. Frequently the truck wont enter 4hi at a low speed. For me it takes switching back and fourth. We need aot more details.
    Junkhead likes this.
  9. Aug 11, 2019 at 8:29 PM
    Kgrecurit88
    Kyle
    I can clear the code on my screen but it just reappears seconds later. I have been having issues with mine. Randomly the rear locker light just started flashing sometimes. Like it's an electrical problem. Now that light wasnt on but the (!) Is on with it saying 2wd to 4wd mode isnt working. And I didnt even try to use 4wd I only just started the truck.
  10. Aug 11, 2019 at 8:29 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    It’s like the other dude said. Take it to place to be looked at, either a different dealer or a well vetted mech. It could be something stupid like you just need to go in reverse to unbind or there can be something not connected right. Then the extreme of something like the transfer case being damaged. No ones going to be able to tell with out being able to test it.
    When I had a 2018 OR I got a blinking light a lot when putting it into 4h, if it took to long, I’d just roll forward or backward little and it would usually kick on, then N and shift to 4L....wait and if it didn’t kick on, put it in drive and it would usually shift over.
    LeakyAC likes this.
  11. Aug 11, 2019 at 8:37 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Imo 6" is asking for trouble. Not trying to be a dick here.
    Irons, myn75, OffroadToy and 5 others like this.
  12. Aug 11, 2019 at 9:40 PM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    Modifies truck well beyond what it was designed to do. Then wonders why things stop working the way they were designed to work...
  13. Aug 11, 2019 at 9:44 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Flash1034 likes this.
  14. Aug 12, 2019 at 3:24 AM
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    What was the fix six months ago?
    faawrenchbndr likes this.
  15. Aug 12, 2019 at 5:27 AM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    So a little info. The flashing light is 'normal' when the actuator is having trouble cycling into position. However that error screen is displayed generally when an electrical issue is detected in the actuator, which is why it is essentially instantaneous. Truck has given up and failsafe locked out all mode changes.
    Several possible issues can cause it, but chances are it is internally a bad connection in either actuator, or the wires to them (chomp chomp chomped).
    Another possibility is if the actuator has been placed into an 'undefined' position past it's normal range of motion, but that is unlikely unless you failed to tell us that somebody was messing with or removed the actuators.
    If you want to diagnose, it will take Techstream or a multimeter (or maybe both).
    If it were I, i would shut off the truck, take my meter and check both actuators against the expected values in the thread below.
    https://www.tacomaworld.com/threads/4wd-actuator-troubleshooting-transfer-case-and-add.578262/
    Based on the error message, you are looking for an open coil or a set of feedback wiper resistance readings that isnt a valid combo per the tables.
    If you do try to troubleshoot, recommend starting a new thread.
    If you aren't up for using a meter or techstream, then stop and find a friend, mechanic, or dealer who is.
    HP11 likes this.
  16. Sep 5, 2019 at 7:29 PM
    Kgrecurit88
    Kyle
    Found out the installer of my gear kit had a loose connection. All soldered up and working flawlessly. Tested it on my trip and no glitches.
    FloridaFree and shakerhood like this.
  17. Sep 5, 2019 at 7:34 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Try switching it when you're in neutral
    Otterstuff likes this.
  18. Dec 14, 2019 at 8:24 AM
    MaxxTRD
    MaxxTRD Well-Known Member
    Maxx
    Seattle
    2016 Tacoma Off Road
    King Extended Travel Coilovers, Total Chaos UCAs, Rear Kings with Icon AAL, Cab mount Chop, 305/70/16 KO2s Moto metal wheels CBI Off Road Fab bumper and sliders Rad industries grill
    Hey man. I'm having the same issue that started after having my gears don . Where was this connection that was loose?
  19. Dec 30, 2019 at 7:25 AM
    Kgrecurit88
    Kyle
    Its inside the rear differential.
  20. Mar 13, 2020 at 8:04 PM
    k_j_souv
    k_j_souv Well-Known Member
    NorCal
    3G OR DCSB, Dual Case, 42s
    I had 5.29s and a front ARB locker installed, 3 months later I got the '2wd 4wd mode change failure' message. Below is a copy of what the dealer wrote up, I hope that helps
    AKGSD likes this.
