2WD-4WD mode change malfunction
Discussion in '3rd Gen. Tacomas (2016-2023)' started by YotaEmma, Jul 12, 2020.
  1. Jul 13, 2020 at 3:12 PM
    #41
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Front diff and transfer case breathers are already pretty high up in the engine compartment
  2. Jul 13, 2020 at 4:44 PM
    #42
    YotaEmma
    YotaEmma [OP] Member
    Emmanuel
    2020 Black TRD Tacoma
    Lift kit, wheels and tires
    It came back on, the 4L with the hazard light. Toyota is going to pick it up. Wish me luck fellas lol and thank you all for your comments and help! Appreciate you guys
    BigWhiteTRD likes this.
  3. Jul 13, 2020 at 4:45 PM
    #43
    YotaEmma
    Emmanuel
    Yeah it came back :/ I’m having them take it to the dealer.
    BigWhiteTRD[QUOTED] likes this.
  4. Jul 13, 2020 at 5:14 PM
    #44
    muskratX22
    muskratX22 Well-Known Member
    Dave
    Illinois
    Good Luck! Good thing you have warranty!
    BigWhiteTRD and YotaEmma[OP] like this.
  5. Jul 13, 2020 at 5:59 PM
    #45
    BigWhiteTRD
    Ted
    Good luck
    Let us know how it goes...
    YotaEmma[QUOTED][OP] likes this.
  6. Jul 13, 2020 at 6:00 PM
    #46
    YotaEmma
    Emmanuel
    I will sir and thanks!
  7. Jul 13, 2020 at 10:06 PM
    #47
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    not the rear diff though...
    Kev250R likes this.
  8. Jul 14, 2020 at 8:02 AM
    #48
    Ricky B
    Ricky B Well-Known Member
    Arkansas
    1998 XCAB
    I have driven tacomas for over 20 years and I have had all 3 generation trucks. The gen 1 and 2 both had the front actuator replaced because of the vent tube. You guys need to pull on these tubes every so often and make sure they are on because you don't know there is a problem until there is a problem. They will dry rot and fall off or just crack around the nipple and look like they are on but there not and if you get in high water they will leak.
    I was out at my deer lease this weekend and hit the 4wd hi knob and no 4wd. The indicator light blinked and it would never engage. I took off the skid plate and looked at the actuator and the vent hose is on and couldn't really see any problem's but I'm betting water is the culprit somehow. I have a 2019 with 38,500 so no warranty work. I will post up on here tomorrow when I find what caused the problem.
  9. Jul 14, 2020 at 9:16 AM
    #49
    YotaEmma
    Emmanuel
    Thanks for the help!!! Let’s us know!!!
    Matty0317 likes this.
  10. Jul 14, 2020 at 9:17 AM
    #50
    YotaEmma
    Emmanuel
    My truck was towed to the dealer today. When getting picked up the truck was back to its normal state (2WD) and I was able to engage at 4L and 4H.. and then back to 2WD , it is now at the dealer will keep you all posted!
  11. Jul 14, 2020 at 5:08 PM
    #51
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    This type of shit is why I really wish we had manual transfer levers. I don't know why everything has to be electronic.
    Matty0317, Rick111 and muskratX22 like this.
  12. Jul 14, 2020 at 7:19 PM
    #52
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    everyone knows you need to sometimes try more than once, right? Its even right in the manual. my second gen almost never went into 4lo on the first try, and my 3rd gen also never goes into 4lo on the first try. They should, but dont always.
  13. Jul 15, 2020 at 7:41 AM
    #53
    Ricky B
    Arkansas
    1998 XCAB
    Picked up my 2019 Tacoma yesterday and was told that the 4wd was hung up and the tech manually moved it to 4wd and everything works as it should. Now it did me little good taking with the service rep. I don't like fixes like this because I needed my 4wd and don't like knowing I don't have it when I need it. The service rep said I should move it to 4wd every so often which I replied I do more than you think. So they charged me 125.00 to tell me that basically they don't have a clue why it hung up but its working now.
    YotaEmma[OP] likes this.
  14. Jul 15, 2020 at 11:03 AM
    #54
    YotaEmma
    Emmanuel
    I got the call , they are replacing my computer (Ecu) and the actuator. It got damaged by the water. Luckily it’s under warranty.
    VirusCage and BigWhiteTRD like this.
  15. Jul 15, 2020 at 1:02 PM
    #55
    BigWhiteTRD
    Ted
    I really doubt it's the ECU's fault, but glad they are fixing.
    Make sure to drain and fill the front diff, it's cheap insurance and the actuator undoubtedly failed via water or corrosion. (Actuator is exposed to diff internal)
    Any word if the vent hose was breached?
  16. Jul 15, 2020 at 1:05 PM
    #56
    YotaEmma
    Emmanuel
    Really? Yeah that’s what the guy said that they are replacing the computer and actuator.
    not sure about the vent hose! I will ask when I pick up the truck. And keep you posted
  17. Jul 15, 2020 at 1:51 PM
    #57
    Rick111
    Rick111 Well-Known Member
    Rick
    2019 DCSB TRD OR 6M
    ARE Z series cap w/Bedrug
    Not always but fairly often the warning lights on my dash for the various 4WD systems usually flash on/off when I try to engage them if I am moving and there is a load on the drivetrain. And I am not talking about while driving fast or the engine/drivetrain heavily loaded. What usually happens is I have to come to a complete stop and reattempt whatever it is I am trying to do (2WD high to 4WD high; 4WD high to 4WD low; turning off ATRAC; engaging rear eLocker, ...). Same thing going the other way. Is it a manual transmission thing? I don’t know. Not a big deal regardless. However, the truck is only a year old and I don’t use 4WD a lot (usually once a month) so perhaps it needs a little more breaking in. Yeah, I prefer manual shifters as well.
  18. Jul 15, 2020 at 1:58 PM
    #58
    BigWhiteTRD
    Ted
    I am just guessing based on some anecdotal evidence. (I short circuited that ECU 12 ways to Sunday working on 2 wheel low, and tripped safeguard after safeguard but the ECU came back to life every time. Also there have been some cases where dealers have replaced ECU, but it took actuator to fix the issue. So now very leery to point finger at ECU)
    VirusCage likes this.
  19. Jul 15, 2020 at 3:59 PM
    #59
    YotaEmma
    Emmanuel
    Gotcha! Honestly not to tech savvy about all this stuff!!
    it just confuses me that I bought a off-road truck to do cool shit, and it gets wet I’m screwed doesn’t make sense!
  20. Jul 15, 2020 at 11:33 PM
    #60
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    it has 3 yr/36k bumper to bumper warranty..
