2wd in snow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Redneck Ron, Nov 9, 2011.
  1. Nov 9, 2011 at 4:40 PM
    Redneck Ron
    Redneck Ron [OP] Member
    Ron
    bucks county (the light side) pa
    white 5 lug
    I have a base model 2wd regular cab tacoma. We have bad winters where i live and i was wondering how do your 2wds handle in the snow.:confused:
  2. Nov 9, 2011 at 4:42 PM
    AlphaEcho2k5
    AlphaEcho2k5 Well-Known Member
    Adam
    Hurlburt Field, FL
    '02 4Runner
    slower is faster, common sense will get you pretty far (no offense to OP).
  3. Nov 9, 2011 at 4:42 PM
    Fiolo
    Fiolo Senior member
    98 Regular cab lifted 4wd
    Lost track many mods ago
    Yes it would be better 4x4 ftw baby
  4. Nov 9, 2011 at 4:48 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Good tires and weight in the back take you a long way. I usually have nothing in my bed, but with my Duratracs I usually get through a lot of snow before I actually need to switch into 4wd.
  5. Nov 9, 2011 at 6:24 PM
    jsutter
    jsutter Well-Known Member
    Jim
    Southeast Ohio
    08 Reg. Cab 4cyl 2wd
    cruise and intermittent wipers
    Purchase a set of dedicated snow tires and keep the tank full (19 gallons is about 120lbs) and maybe a couple tubes of sand and you should be OK.
  6. Nov 9, 2011 at 6:31 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    this^^^
    get some good snow tires mounted on some rims. then just swap them on in the winter. get some weight in the back, carry some sand and a shovel incase you get stuck
  7. Nov 9, 2011 at 8:42 PM
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    i too am looking at prerunners (i.e. RWD), ...but i'm not too worried about it, i figure it's got to be a hell of a lot easier to get around in than what i've been driving the past 10yrs..
  8. Nov 10, 2011 at 1:38 AM
    jrgroucho
    jrgroucho Well-Known Member
    Jeremy
    Michigan
    2010 AC SR5 BSP
    Hose Clamp, No Seatbelt Chime, Husky Floor Liners, BHLM, sockmonkey Tailgate Decal, Wet Okole Covers/Armrests,
    Just use common sense and you should be fine. I bought my 5 lugger last February and even with the factory Dunlop tires it was fine in the snow, though I may get some new tires for this winter...
  9. Nov 10, 2011 at 5:36 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Good tires will go a long ways! If it's within your means, get a set of dedicated snows (maybe even studded), tall and narrow for better traction. Throw some weight over or in front of the rear axle (do not put weight behind the axle, it's more important that you can steer and stop than accelerate). Sand bags are nice because if you do get stuck you can put the sand under the tires if need be.
  10. Nov 10, 2011 at 7:21 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    I agree with what's already posted: Good tires, extra weight, common sense for the conditions, 4x4 is still better.
  11. Nov 10, 2011 at 7:29 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Yeah agreed at good set of tires will go a long way. I go over donner summit a lot durning chain control in 2wd just to test my DuraTracks and they do awesome in the snow if you want a good all year tire DuraTracks are great.
  12. Nov 10, 2011 at 7:36 AM
    Goober
    Goober Earthlings are fun to watch!
    Utah - Why just have only one?
    '11 TRD Off-Planet AccessCab
    Here's a trick I learned back when I had my '47 GMC. Keep a few roof shingles in the back. Serveral times I was in a rut on ice and throwing a roof shinge face down under the back tire would get me unstuck. The grit on the shingle grips the ice and the tire sticks to the tar side.
  13. Nov 10, 2011 at 7:48 AM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    I'm in the same boat as you, first winter with 2wd. I just bought some tube sand for the back and hopefully that will be fine.
  14. Nov 10, 2011 at 7:50 AM
    Pugga
    Massachusetts
    I hope you have good tires!
  15. Nov 10, 2011 at 8:03 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    x2. With Malloy cutting funding for plows this winter is going to be fun for sure. October snow showed that. Plows did not come out until several hours of snow, by then road was littered with 2wd in ditches. :D
  16. Nov 10, 2011 at 11:01 AM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    I get stuck far more with 4wd than I ever did with 2 :D
    2wd: "Ohh, that looks deep I'll just stay on the straight and narrow!"
    4wd with locker that i can engage in 4-Hi: "NO PROBLEM GIV ER SHIT"...snow past the bumper and 3 out of 4 wheels spinning "Whuuups!".
  17. Nov 10, 2011 at 11:03 AM
    JLee
    Jerry
    Bay Area NorCal
    Ha so true :thumbsup:
  18. Nov 10, 2011 at 11:04 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    if you are worried about it just get some chains
  19. Nov 10, 2011 at 11:08 AM
    tacomaprerunner
    tacomaprerunner Dang liberals.
    1995 Ford F350 7.3L PowerStroke Diesel
    I've driven the last two winters in 2WD. Drive slow and smart. Use weight in the bed. When going up hills with snow/ice on them, don't lose your momentum. Honestly, it's damn hard to get stuck in the snow - with enough effort, you can get yourself out. Last winter I spent an hour simply turning the truck 180 degrees. After that, it was no problem. 4x4 just makes it a lot easier.
  20. Nov 10, 2011 at 11:16 AM
    BlueT
    NorthEast
    :D That is so true. If I had 2wd I would not leave my house in bad weather. With 4x4 you get easily tempted, plus when 2wd gets stuck usually shovel and good push is enough. When 4x4 gets stuck you need another 4x4 to pull him out. And if 4x4 w/F&R lockers gets stuck usually you need a buggy to pull him out.
